<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[A word on product spec&#x27;s]]></title><description><![CDATA[<p dir="auto">**Zapco's take on specs</p>
<p dir="auto">Specifications You Can Hear**<br />
Our dedication to sonic purity, and to the concept of cumulative<br />
error demands that we design and build our amplifiers and processors to be<br />
the cleanest in the industry. ZAPCO amplifiers are the standard by which all<br />
other amplifiers are measured. However, it concerns us when one<br />
specification THD (Total Harmonic Distortion) that can’t be heard in most<br />
modern, high-end amplifiers becomes the only meaningful specification<br />
manufacturers seem to publish. THD is only one of a number of<br />
specifications that make ZAPCO amplifiers sound better than other brands.<br />
Of the four primary specifications, it is probably the least obvious in normal<br />
use.<br />
<strong>Damping Factor:</strong><br />
The most common misconception about ZAPCO amplifiers is that<br />
we drastically under-rate our power output. Not true, it just sounds that way.<br />
Today’s music, of all genres, has a great deal of bass content. Damping<br />
describes the amps ability to control a woofer. An amp with poor damping<br />
will leave bass notes sounding soft and undefined, regardless of its power.<br />
In most amp lines, the largest units have damping factors between 100 and<br />
200. Since rock solid bass is perceived as a function of power, our 100-watt<br />
amp sounds like other brands 300-watt amps.<br />
<strong>Slew Rate:</strong><br />
A similar situation exists in the higher frequencies. Ever turn up the<br />
volume and hear cymbals sounding like fingernails on a blackboard? That’s<br />
because the amplifier simply wasn’t fast enough to accurately reproduce the<br />
high frequency tonality of the cymbals. A higher slew rate means a faster<br />
amplifier, which means crystal clear high frequency reproduction. ZAPCO<br />
amps have the highest slew rates in the industry. Once again, clear defined,<br />
sound is perceived as a function of power.<br />
<strong>Signal to Noise Ratio:</strong><br />
Noise is an ever-present problem in auto sound reproduction.<br />
ZAPCO approaches this problem in two ways. The first is at the input<br />
source. All Reference amplifiers can use the SymbiLink<img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/2122.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--tm" style="height:23px;width:auto;vertical-align:middle" title="™" alt="™" /> balance line<br />
inputs, which drastically reduce the noise coming into the amp. Secondly,<br />
ZAPCO amps are built with the highest quality, lowest noise components<br />
available. We have the highest signal to noise ratios in the industry. The<br />
extra money we spend on better components is directly rewarded with better<br />
sound.<br />
9<br />
<strong>Stereo Separation:</strong><br />
The ability of an amplifier to maintain the separation between the<br />
right and left channels is what allows an amplifier to reproduce an accurate<br />
sound stage. Music is recorded with each instrument in its own location on a<br />
sound stage. You should hear it the same way in your vehicle.<br />
<strong>Results:</strong><br />
To assure that no ZAPCO product ever fails to meet our level of<br />
expectation, we must build all products to exceed our specifications by a<br />
comfortable margin. Our superior design and construction give our<br />
amplifiers advantages that go beyond power output and provide a sound<br />
quality difference you will hear the moment you turn your system on.<br />
<strong>A WORD ABOUT “WEIGHTED” SPECIFICATIONS</strong><br />
Most of the time, when you see specifications, they will be preceded<br />
by the term “A” weighted. “A” weighting is a way of coloring numbers to<br />
make specifications look better.<br />
About the only place you can find specs that aren’t “A” weighted is<br />
in ZAPCO manuals and literature. We publish only “raw” specs at ZAPCO. <strong>If<br />
we don’t like the specifications of one of our products we’ll make it better,<br />
not try to make the numbers look better.</strong></p>
]]></description><link>https://fargostreet.com/topic/10010/a-word-on-product-spec-s</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 12:31:17 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/10010.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Mar 2007 14:39:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to A word on product spec&#x27;s on Fri, 30 Mar 2007 15:23:45 GMT]]></title><description><![CDATA[<p dir="auto">I thought I would throw this out, not to bash other companies, not to promote Zapco, but because there is a TON of truth to what they have said.  It also explains how all amplifiers are NOT created equally and how one 1000 watt amp is not as loud as someone elses 500 watt amp.  In essence you get what you pay for.  There are other high end amplifiers out there that perform great as well, and this was just put out there to show what separates the men from the boys.</p>
]]></description><link>https://fargostreet.com/post/151777</link><guid isPermaLink="true">https://fargostreet.com/post/151777</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 30 Mar 2007 15:23:45 GMT</pubDate></item></channel></rss>
