<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Car Audio Equipment FS]]></title><description><![CDATA[<p dir="auto">PHOENIX GOLD R9.0:5 4x125W+1x400W OCTANE-R AMPLIFIER</p>
<p dir="auto"><img src="http://www.partsexpress.com/imageslarge/263-944L.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">The all-new Octane-R Series Amplifiers are big-power amplifiers with street racing cosmetics. Overbuilt and indestructible power supplies provide rock solid stability and reliability. Phoenix Gold took a look at what's happening on the streets and came out with a new line of amps that have all the answers. Not just another pretty face (but they ARE beautiful!), these new amps can also take anything you can throw at them. Count on Phoenix Gold's engineers to deliver the goods. Features: *Fully complementary output stage *5 channel power amplifier *400 watt sub channel!<br />
Specifications: *Power output, front and rear stereo channels: 50 watts RMS/125 watts max x 4 (4 ohm load), 75 watts RMS/200 watts max x 4 (2 ohm load), 150 watts RMS x 2 (bridged mono, 4 ohm load) *Power output, mono subwoofer channel: 150 watts RMS/250 watts max x 1 (4 ohm load), 250 watts RMS/400 watts max x 1 (2 ohm load) *Frequency response: 20 Hz-20 kHz *THD 1% *Signal to noise ratio: greater than 110 dB *Dimensions: 19.75" L x 10.875" W x 2.25" H.        - Carbon fiber badge, backlit with blue LED</p>
<ul>
<li>
<p dir="auto">Optional neon inserts for all amp models</p>
</li>
<li>
<p dir="auto">Overload and comparator circuitry</p>
</li>
<li>
<p dir="auto">Remote Monitoring Display (RMD) port, remote sold separately</p>
</li>
<li>
<p dir="auto">Two/four channel amplifiers stability = 2 ohms stereo/4 ohms bridged</p>
</li>
<li>
<p dir="auto">Full-range thru output</p>
</li>
<li>
<p dir="auto">Twin</p>
</li>
<li>
<p dir="auto">12 dB Low pass continuously variable crossover (40-400 Hz<br />
Used for 2 seasons but has less than 100 hours of use on it.  Works great.  Only reason I am replacing it is because I no longer sell Phoenix Gold equipment.</p>
</li>
</ul>
<p dir="auto">**$175 obo  NEW PRICE</p>
<p dir="auto">**[COLOR=Black]Phoenix Gold ZR10D4 10" subwoofers</p>
<p dir="auto">[/COLOR]<strong>[SIZE=1]OCTANE-ZR                                       SUBWOOFER SPECS:</strong>[/SIZE]        • Injection                                   molded aluminum plated grained polypropylene                                   cone        • 3                                   peice injection molded dust cap with aluminum                                   plating        • Carbon                                   fiber inlay and blue LED backlight        • Computer                                   optimized large bumped motor assembly        • Large                                   roll butyl rubber surround        • Injection                                   molded rubber motor housing        • Integrated rubber mounting gasket        • 2 inch high temperature voice                                 coil        • 30mm Peak to Peak excursion        • Cast aluminum basket<br />
<img src="http://phoenixgold.com/2004/images/octane_zr/zrwooferfamily.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">**$50 each (I have 1 pair) obo</p>
<p dir="auto">**</p>
<pre><code>        **OCTANE-ZR                                         6.5 COMP
</code></pre>
<p dir="auto">**• Injection                                   molded aluminum plated grained polypropylene                                   cone        • Butyl                                   rubber surround        • Flat                                   linear roll spider        • 25mm                                   silk dome tweeter        • External                                   24dB/octave acoustic crossover<br />
<img src="http://phoenixgold.com/2004/images/octane_zr/octanezrcomp.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<strong>$100 obo [B] SOLD</strong></p>
<p dir="auto">[/B]</p>
<pre><code>        **OCTANE-R                                         5.0c COAX
</code></pre>
<p dir="auto">• 5.25 inch (130mm) Coaxial<br />
• Frequency response: 90Hz-20kHz<br />
• Sensitivity: 89dB (1W/1M)**<br />
<strong><img src="http://phoenixgold.com/2004/images/octane_r/speakers/r5.0c.jpg" alt="legacy image" class=" img-fluid img-markdown" /></strong><br />
<strong>[COLOR=Red]$30 obo[/COLOR]</strong><br />
**<br />
Chuck Schwan<br />
701-541-3484<br />
**</p>
]]></description><link>https://fargostreet.com/topic/10030/car-audio-equipment-fs</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 10:18:41 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/10030.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Apr 2007 18:31:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Car Audio Equipment FS on Wed, 30 May 2007 03:54:03 GMT]]></title><description><![CDATA[<p dir="auto">Everything has now sold except for the 5.25" PG Coax's and the Clarion 4" Coaxials.</p>
]]></description><link>https://fargostreet.com/post/161204</link><guid isPermaLink="true">https://fargostreet.com/post/161204</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Wed, 30 May 2007 03:54:03 GMT</pubDate></item><item><title><![CDATA[Reply to Car Audio Equipment FS on Sun, 22 Apr 2007 22:00:25 GMT]]></title><description><![CDATA[<p dir="auto">Bump again...also have clarion 4" coaxials (used one season) and a pair of sub boxes that are a direct drop in to a wrx (10")</p>
]]></description><link>https://fargostreet.com/post/155467</link><guid isPermaLink="true">https://fargostreet.com/post/155467</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sun, 22 Apr 2007 22:00:25 GMT</pubDate></item><item><title><![CDATA[Reply to Car Audio Equipment FS on Fri, 13 Apr 2007 02:07:51 GMT]]></title><description><![CDATA[<p dir="auto">everything is sold now except the 5.25" speakers and the subs.</p>
]]></description><link>https://fargostreet.com/post/153691</link><guid isPermaLink="true">https://fargostreet.com/post/153691</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 13 Apr 2007 02:07:51 GMT</pubDate></item><item><title><![CDATA[Reply to Car Audio Equipment FS on Tue, 10 Apr 2007 03:29:05 GMT]]></title><description><![CDATA[<p dir="auto">Amp tentatively sold!</p>
]]></description><link>https://fargostreet.com/post/153210</link><guid isPermaLink="true">https://fargostreet.com/post/153210</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 10 Apr 2007 03:29:05 GMT</pubDate></item><item><title><![CDATA[Reply to Car Audio Equipment FS on Mon, 09 Apr 2007 22:59:24 GMT]]></title><description><![CDATA[<p dir="auto">Bump, 6.5" components are sold</p>
]]></description><link>https://fargostreet.com/post/153196</link><guid isPermaLink="true">https://fargostreet.com/post/153196</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 09 Apr 2007 22:59:24 GMT</pubDate></item><item><title><![CDATA[Reply to Car Audio Equipment FS on Tue, 03 Apr 2007 17:29:56 GMT]]></title><description><![CDATA[<p dir="auto">bump....all this MUST GO!  No reasonable offer refused</p>
]]></description><link>https://fargostreet.com/post/152162</link><guid isPermaLink="true">https://fargostreet.com/post/152162</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 03 Apr 2007 17:29:56 GMT</pubDate></item></channel></rss>
