<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Dear Old Dad&#x27;s Garage Experiment]]></title><description><![CDATA[<p dir="auto">Any Mopar guys on here?  I have a 99 Dakota that I'm working on and I'm gonna chance the tranny fluid.  The manual specifies Mopar Manual Transmission oil.  Is this something that I can only get from the stealership?</p>
<p dir="auto">Also I have to replace the exhaust manifold gaskets on this truck as the bolts rusted right off.  Anyone else seen this problem before?</p>
]]></description><link>https://fargostreet.com/topic/10082/dear-old-dad-s-garage-experiment</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 05:14:52 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/10082.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Apr 2007 18:37:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Dear Old Dad&#x27;s Garage Experiment on Mon, 09 Apr 2007 13:54:24 GMT]]></title><description><![CDATA[<p dir="auto">As promised, here are pictures because I like stories with pictures.</p>
<p dir="auto">Seats before I cleaned them<br />
<img src="http://mistercmk.com/album/albums/userpics/10002/DSC01575.JPG" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Seats after I cleaned them<br />
<img src="http://mistercmk.com/album/albums/userpics/10002/DSC01588.JPG" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">w00t, the topper lights work again<br />
<img src="http://mistercmk.com/album/albums/userpics/10002/DSC01584.JPG" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">sweet stainless hardware<br />
<img src="http://mistercmk.com/album/albums/userpics/10002/DSC01585.JPG" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://mistercmk.com/album/albums/userpics/10002/DSC01586.JPG" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">And the awesome cone air filter I had laying around<br />
<img src="http://mistercmk.com/album/albums/userpics/10002/dakotamotor.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/153098</link><guid isPermaLink="true">https://fargostreet.com/post/153098</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Mon, 09 Apr 2007 13:54:24 GMT</pubDate></item><item><title><![CDATA[Reply to Dear Old Dad&#x27;s Garage Experiment on Sun, 08 Apr 2007 22:04:33 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">MisterCMK;163044 wrote:<br />
I ended up having to replace the drivers side hub assembly as it was siezed onto the spindle.  We've got 3 of these dakotas and I've replaced half the hub assemblies in the last 2 months.  It seems that this is a VERY common part to replace after 150k.  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f4a3.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--bomb" style="height:23px;width:auto;vertical-align:middle" title=":bomb:" alt="💣" /></p>
<p dir="auto">I'll post up some pics of stuff cause I like stories with pictures.</p>
<p dir="auto">unfortunately the hubs, ball joints, tie-rods, etc etc are extremely common on almost all trucks/suvs.</p>
]]></description><link>https://fargostreet.com/post/152995</link><guid isPermaLink="true">https://fargostreet.com/post/152995</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Sun, 08 Apr 2007 22:04:33 GMT</pubDate></item><item><title><![CDATA[Reply to Dear Old Dad&#x27;s Garage Experiment on Sun, 08 Apr 2007 17:17:49 GMT]]></title><description><![CDATA[<p dir="auto">Alrighty.  Thanks a lot for the info guys.  I finished up the exhaust manifold gasket but was only able to use 3 out of 4 bolts since the 4th one is behind some brake lines and I couldn't get to it with the drill.  So far it seems to seal just fine and I've heat cycled it a few times.  I also changed the oil and pull wire to the front for the interior topper lights.  Apparently whoever put the topper on liked to use crimp connectors on the truck so the wire corroded and got left on the road somewhere.  15" of #14, a fuse holder and my soldering gun and I'm back in business.</p>
<p dir="auto">I am going to hold off on the tranny fluid until later as I am sick of dealing with this thing.  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" />  I ended up having to replace the drivers side hub assembly as it was siezed onto the spindle.  We've got 3 of these dakotas and I've replaced half the hub assemblies in the last 2 months.  It seems that this is a VERY common part to replace after 150k.  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f4a3.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--bomb" style="height:23px;width:auto;vertical-align:middle" title=":bomb:" alt="💣" /></p>
]]></description><link>https://fargostreet.com/post/152958</link><guid isPermaLink="true">https://fargostreet.com/post/152958</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sun, 08 Apr 2007 17:17:49 GMT</pubDate></item><item><title><![CDATA[Reply to Dear Old Dad&#x27;s Garage Experiment on Sun, 08 Apr 2007 15:53:21 GMT]]></title><description><![CDATA[<p dir="auto">i believe that the nv1500 is in the 4 cyl only.  and if the dealer told you that you need specific fluid, then you more likely than not need the chrysler specific fluid.  if you are able to, drain out the fluid and see how thick it is.  it should look like gear lube, but probably (at least hopefully) cleaner than used diff fluid.  Your diffs build up more heat than your tranny which is why they smell burned most of the time.  Manual tranny fluid is primarily just to lubricate the bearings and gears.  Being a 2wd, there is no 90degree turn in the line of power like the diffs, which burns up the fluid even more.</p>
<p dir="auto">long story short, call the parts dep at corwin and see which fluid they say you need.</p>
]]></description><link>https://fargostreet.com/post/152940</link><guid isPermaLink="true">https://fargostreet.com/post/152940</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Sun, 08 Apr 2007 15:53:21 GMT</pubDate></item><item><title><![CDATA[Reply to Dear Old Dad&#x27;s Garage Experiment on Sat, 07 Apr 2007 16:21:17 GMT]]></title><description><![CDATA[<p dir="auto">How do I know which tranny it has?  There is nothing in the door sticker, glovebox sticker or the Haynes that says anything about which one.</p>
<p dir="auto">Its a 1999 3.9 V6 longbed 2wd truck</p>
]]></description><link>https://fargostreet.com/post/152870</link><guid isPermaLink="true">https://fargostreet.com/post/152870</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sat, 07 Apr 2007 16:21:17 GMT</pubDate></item><item><title><![CDATA[Reply to Dear Old Dad&#x27;s Garage Experiment on Sat, 07 Apr 2007 13:31:04 GMT]]></title><description><![CDATA[<p dir="auto">taken from all data.  need to know which transmission you have but here are the options.  looks like the only fluid you can use is MMT or 75w-90 depending on which one is yours.  i highly recommend not using anything other than oem fluid in transmissions.  the 75-90 is a general gear lube, nothing special, but the other one is specific.  good luck!:</p>
<p dir="auto">Required lubricant for the NV3500 is Mopar(R) Manual Transmission Lubricant, P/N 4761526. This is the only lubricant to be used in NV3500 transmissions. No other lubricants are acceptable, or recommended.</p>
<p dir="auto">Recommended lubricant for AX15 transmissions is Mopar(R) 75W-90, API Grade GL-5 gear lubricant, or equivalent.</p>
<p dir="auto">Required lubricant for the NV1500 is Mopar(R) Manual Transmission Lubricant, P/N 4761526. This is the only lubricant to be used in NV1500 transmissions. No other lubricants are acceptable, or recommended.The NV1500 is available in 4-cyl. equipped 2WD models.</p>
]]></description><link>https://fargostreet.com/post/152863</link><guid isPermaLink="true">https://fargostreet.com/post/152863</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Sat, 07 Apr 2007 13:31:04 GMT</pubDate></item><item><title><![CDATA[Reply to Dear Old Dad&#x27;s Garage Experiment on Sat, 07 Apr 2007 13:24:07 GMT]]></title><description><![CDATA[<p dir="auto">sorry, didn't realize it was a manual.  ill get back to ya.</p>
<p dir="auto">edit: reading owns me.</p>
]]></description><link>https://fargostreet.com/post/152862</link><guid isPermaLink="true">https://fargostreet.com/post/152862</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Sat, 07 Apr 2007 13:24:07 GMT</pubDate></item><item><title><![CDATA[Reply to Dear Old Dad&#x27;s Garage Experiment on Sat, 07 Apr 2007 00:10:51 GMT]]></title><description><![CDATA[<p dir="auto">Even for a manual trans?</p>
]]></description><link>https://fargostreet.com/post/152818</link><guid isPermaLink="true">https://fargostreet.com/post/152818</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sat, 07 Apr 2007 00:10:51 GMT</pubDate></item><item><title><![CDATA[Reply to Dear Old Dad&#x27;s Garage Experiment on Sat, 07 Apr 2007 00:03:37 GMT]]></title><description><![CDATA[<p dir="auto">ATF+4 i believe is the fluid of choice for that year.  At least that is what I was always told to put in regular dodge trucks when I worked there.</p>
]]></description><link>https://fargostreet.com/post/152817</link><guid isPermaLink="true">https://fargostreet.com/post/152817</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Sat, 07 Apr 2007 00:03:37 GMT</pubDate></item><item><title><![CDATA[Reply to Dear Old Dad&#x27;s Garage Experiment on Fri, 06 Apr 2007 20:33:35 GMT]]></title><description><![CDATA[<p dir="auto">Lol...good luck with that. hahahaha rusted bolts are always a pain in the ass. I had a guy in my Auto shop class once break a grade 8 bolt tighting up a crankshaft main...That ended in lots of four letter words...Funny as hell to watch.</p>
]]></description><link>https://fargostreet.com/post/152791</link><guid isPermaLink="true">https://fargostreet.com/post/152791</guid><dc:creator><![CDATA[JN607]]></dc:creator><pubDate>Fri, 06 Apr 2007 20:33:35 GMT</pubDate></item><item><title><![CDATA[Reply to Dear Old Dad&#x27;s Garage Experiment on Fri, 06 Apr 2007 19:45:38 GMT]]></title><description><![CDATA[<p dir="auto">Bah, the front 2 came out without even moving the torch out of the corner.  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" />  The rear 2 will need to be drilled and tapped though.\</p>
]]></description><link>https://fargostreet.com/post/152780</link><guid isPermaLink="true">https://fargostreet.com/post/152780</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Fri, 06 Apr 2007 19:45:38 GMT</pubDate></item><item><title><![CDATA[Reply to Dear Old Dad&#x27;s Garage Experiment on Fri, 06 Apr 2007 18:42:23 GMT]]></title><description><![CDATA[<p dir="auto">go the parts store and get what ever it says in there computer for tranny fluid. for the bolts, have fun with that. Take a torch to them before you attempt to loosen them</p>
]]></description><link>https://fargostreet.com/post/152771</link><guid isPermaLink="true">https://fargostreet.com/post/152771</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Fri, 06 Apr 2007 18:42:23 GMT</pubDate></item></channel></rss>
