<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[High boost?]]></title><description><![CDATA[<p dir="auto">would the cold weather make my boost be 20psi+ with no boost control??</p>
]]></description><link>https://fargostreet.com/topic/1028/high-boost</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 01:18:59 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/1028.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Dec 2004 00:58:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to High boost? on Sat, 25 Dec 2004 20:15:14 GMT]]></title><description><![CDATA[<p dir="auto">with the stock turbo, in my opinion, more hardware besides the datalogger isn't necessary (unless you're bringing in more complex devices than the afc</p>
]]></description><link>https://fargostreet.com/post/18763</link><guid isPermaLink="true">https://fargostreet.com/post/18763</guid><dc:creator><![CDATA[out there]]></dc:creator><pubDate>Sat, 25 Dec 2004 20:15:14 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Fri, 24 Dec 2004 22:21:37 GMT]]></title><description><![CDATA[<blockquote>
bah, you don't need a dyno to tune such a small turbo.  just a datalogger to see where you're getting knock and/or losing timing; keep your o2 nice and smooth around .88-.94, i've seen different numbers for different years, so you should ask around</p>
<p dir="auto">..to do it? or to do it right?</p>
]]></description><link>https://fargostreet.com/post/18476</link><guid isPermaLink="true">https://fargostreet.com/post/18476</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Fri, 24 Dec 2004 22:21:37 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Thu, 23 Dec 2004 02:11:15 GMT]]></title><description><![CDATA[<p dir="auto">bah, you don't need a dyno to tune such a small turbo.  just a datalogger to see where you're getting knock and/or losing timing; keep your o2 nice and smooth around .88-.94, i've seen different numbers for different years, so you should ask around</p>
]]></description><link>https://fargostreet.com/post/18054</link><guid isPermaLink="true">https://fargostreet.com/post/18054</guid><dc:creator><![CDATA[out there]]></dc:creator><pubDate>Thu, 23 Dec 2004 02:11:15 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 22:54:31 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">When I had nothing but a fuel pump, a bigger turbo, stock injectors, and a boost controller, I fuel cut on cold days, a quick tune and that was all gone...</p>
<p dir="auto">That is actually exactly what I have. I got the 450cc's (auto came with 390) But I also got a manual ECU so it has the proper fuel maps. Thinking of getting a SAFC here soon but i need to wait till summer so i can dyno tune it.</p>
]]></description><link>https://fargostreet.com/post/18032</link><guid isPermaLink="true">https://fargostreet.com/post/18032</guid><dc:creator><![CDATA[-GSX-Falcon]]></dc:creator><pubDate>Wed, 22 Dec 2004 22:54:31 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 16:00:31 GMT]]></title><description><![CDATA[<p dir="auto">yeah actually mine was doing a similair thing, luckily i was still tuned for about 24psi, but it being so cold i ran extremely rich, like around 9:1, and i got a fuel cut, i think it may just be a miss, simpley 'cause it can't burn it all, i'm honestly not 100% sure why i was doing it, but at least i know i wasn't leaning out (nice to have a wideband in the car)  But my fix was easy, just turn down the boost, and the fuel too, and just retune in the summer.</p>
]]></description><link>https://fargostreet.com/post/17986</link><guid isPermaLink="true">https://fargostreet.com/post/17986</guid><dc:creator><![CDATA[Phats]]></dc:creator><pubDate>Wed, 22 Dec 2004 16:00:31 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 13:32:33 GMT]]></title><description><![CDATA[<p dir="auto">if you hit fuel cut, your car hesitates and "cuts" off really bad, you'll know if it you feel it, just like the engine stops for a slight period of time.</p>
<p dir="auto">if your popping when you stomp the gas, check your plugs and wires.</p>
<p dir="auto">if he's got nothing but "free mods" and he's got uncontrollable boost, there's a good chance that the stock fuel system wouldnt be able to provide enough fuel, the stock intercooler would get pretty hot, and that he's picking up a fair amount of knock</p>
]]></description><link>https://fargostreet.com/post/17976</link><guid isPermaLink="true">https://fargostreet.com/post/17976</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Wed, 22 Dec 2004 13:32:33 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 13:15:32 GMT]]></title><description><![CDATA[<p dir="auto">because he has nothing but free mods, i'm sure that it will be just fine because the ecu will be giving enough fuel.  i'm guessing he is probably hitting fuel cut, but they should be able to tell because it's a lot more than "popping" at high rpms <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://fargostreet.com/post/17971</link><guid isPermaLink="true">https://fargostreet.com/post/17971</guid><dc:creator><![CDATA[out there]]></dc:creator><pubDate>Wed, 22 Dec 2004 13:15:32 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 12:56:36 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">bluejays wrote:<br />
bcs= boost control sylenoid i think<br />
*solenoid <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://fargostreet.com/post/17970</link><guid isPermaLink="true">https://fargostreet.com/post/17970</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Wed, 22 Dec 2004 12:56:36 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 09:53:33 GMT]]></title><description><![CDATA[<p dir="auto">bcs= boost control sylenoid     i think</p>
]]></description><link>https://fargostreet.com/post/17967</link><guid isPermaLink="true">https://fargostreet.com/post/17967</guid><dc:creator><![CDATA[bluejays]]></dc:creator><pubDate>Wed, 22 Dec 2004 09:53:33 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 07:32:24 GMT]]></title><description><![CDATA[<blockquote>
no, those mods would not make you run 20+ psi of boost...   cold weathers have been known to cause boost spikes... just be careful... if you have a datalogger available, make sure you're not knocking too bad, if so may you should richen it up or stay off the throttle when it's too cold.</p>
<p dir="auto">&lt;- you could should heed to that.</p>
<p dir="auto">What is BCS?  Boost Control System? what?   I take it that he's just using the stock wastegate actuator.  Having boost go up is a normal problem with internal wastegate's... it's called boost creep.</p>
<p dir="auto">-GSX-Falcon wrote:<br />
It will make it go a little higher because of the denser air but 20PSI+ is excessive. Does he hit Fuel Cut? I have my MBC @15psi and if I get on it I fuelcut all over hell. Reminds me I had better turn that down.</p>
<p dir="auto">The reason you are prob fuel cutting is becuase your running to rich without any sort of fuel control.  You have a Walbro pump, bigger injectors and no S-AFC if I'm remembering correctly...</p>
<p dir="auto">LT1 wrote:<br />
yea mine fuel cuts too when i full throttle it in cold weather</p>
<p dir="auto">LT, if your still running like 25+psi of boost, there's something wrong, no matter how much you richen / lean it out... somethign else is messed up...  if your constantly hitting fuel cut, you should get it fixed before after time it goes kaboom.</p>
<p dir="auto">Anyway, running 20psi on a 14b isn't terrible, you'll prob blow it up eventually (the turbo) but it doesnt matter.  The one thing you don't want to do is be running it too lean though... if its a matter of its fuel cutting because its to rich, you should see if you can control the boost / replace the wastegate actuator, and get somes sort of tuning device; if its running lean, everytime you romp on the gas your most likely causing it to knock, lucky for us, our dsm's can pull timing to adapt... but theres only so much timing that the ecu will pull and then your fucked... hello new engine.</p>
]]></description><link>https://fargostreet.com/post/17953</link><guid isPermaLink="true">https://fargostreet.com/post/17953</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Wed, 22 Dec 2004 07:32:24 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 06:22:19 GMT]]></title><description><![CDATA[<p dir="auto">yea mine fuel cuts too when i full throttle it in cold weather</p>
]]></description><link>https://fargostreet.com/post/17936</link><guid isPermaLink="true">https://fargostreet.com/post/17936</guid><dc:creator><![CDATA[LT1]]></dc:creator><pubDate>Wed, 22 Dec 2004 06:22:19 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 06:08:50 GMT]]></title><description><![CDATA[<p dir="auto">not sure, it does pop alittle at higher rpms</p>
]]></description><link>https://fargostreet.com/post/17933</link><guid isPermaLink="true">https://fargostreet.com/post/17933</guid><dc:creator><![CDATA[King Ricer]]></dc:creator><pubDate>Wed, 22 Dec 2004 06:08:50 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 06:07:37 GMT]]></title><description><![CDATA[<p dir="auto">It will make it go a little higher because of the denser air but 20PSI+ is excessive. Does he hit Fuel Cut? I have my MBC @15psi and if I get on it I fuelcut all over hell. Reminds me I had better turn that down.</p>
]]></description><link>https://fargostreet.com/post/17932</link><guid isPermaLink="true">https://fargostreet.com/post/17932</guid><dc:creator><![CDATA[-GSX-Falcon]]></dc:creator><pubDate>Wed, 22 Dec 2004 06:07:37 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 06:05:07 GMT]]></title><description><![CDATA[<p dir="auto">ok, i'll let him know that, i just think the boost is going up because of the cold weather and i've told him that and he thinks it is another reason.</p>
]]></description><link>https://fargostreet.com/post/17930</link><guid isPermaLink="true">https://fargostreet.com/post/17930</guid><dc:creator><![CDATA[King Ricer]]></dc:creator><pubDate>Wed, 22 Dec 2004 06:05:07 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 06:03:48 GMT]]></title><description><![CDATA[<blockquote>
he has the stock bcs</p>
<p dir="auto">Good, running with the wastegate not opening would be bad. Try and borrow another BCS for a few mins and drive it around see if it fixes it.</p>
]]></description><link>https://fargostreet.com/post/17929</link><guid isPermaLink="true">https://fargostreet.com/post/17929</guid><dc:creator><![CDATA[-GSX-Falcon]]></dc:creator><pubDate>Wed, 22 Dec 2004 06:03:48 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 06:02:06 GMT]]></title><description><![CDATA[<p dir="auto">he has the stock bcs</p>
]]></description><link>https://fargostreet.com/post/17928</link><guid isPermaLink="true">https://fargostreet.com/post/17928</guid><dc:creator><![CDATA[King Ricer]]></dc:creator><pubDate>Wed, 22 Dec 2004 06:02:06 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 05:55:45 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">frntwhllaser wrote:<br />
<p dir="auto">In no boost control are you talking no MBC/EBC or no control at all. As in the stock BCS has been disconnected? If the BCS is disconnected with no other control it would be easy to hit 20PSI in this weather. If the BCS is still connected I would try and steal one from another DSM and see if it fixes it....BCS may be bad.</p>
]]></description><link>https://fargostreet.com/post/17924</link><guid isPermaLink="true">https://fargostreet.com/post/17924</guid><dc:creator><![CDATA[-GSX-Falcon]]></dc:creator><pubDate>Wed, 22 Dec 2004 05:55:45 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 05:50:12 GMT]]></title><description><![CDATA[<p dir="auto">no, those mods would not make you run 20+ psi of boost...   cold weathers have been known to cause boost spikes... just be careful... if you have a datalogger available, make sure you're not knocking too bad, if so may you should richen it up or stay off the throttle when it's too cold.</p>
]]></description><link>https://fargostreet.com/post/17922</link><guid isPermaLink="true">https://fargostreet.com/post/17922</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Wed, 22 Dec 2004 05:50:12 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 04:54:43 GMT]]></title><description><![CDATA[<p dir="auto">that could have something to with it</p>
]]></description><link>https://fargostreet.com/post/17903</link><guid isPermaLink="true">https://fargostreet.com/post/17903</guid><dc:creator><![CDATA[My NOva]]></dc:creator><pubDate>Wed, 22 Dec 2004 04:54:43 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 04:23:36 GMT]]></title><description><![CDATA[<p dir="auto">all he has done to it is 2g pistons,ss springs,ss retainers, stock valves, shaved crank and the free mods. that's it</p>
]]></description><link>https://fargostreet.com/post/17898</link><guid isPermaLink="true">https://fargostreet.com/post/17898</guid><dc:creator><![CDATA[King Ricer]]></dc:creator><pubDate>Wed, 22 Dec 2004 04:23:36 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 04:19:47 GMT]]></title><description><![CDATA[<p dir="auto">or it could be just that his car blows? lol j/k...its gotta be the weather <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
]]></description><link>https://fargostreet.com/post/17896</link><guid isPermaLink="true">https://fargostreet.com/post/17896</guid><dc:creator><![CDATA[Pony_Racer]]></dc:creator><pubDate>Wed, 22 Dec 2004 04:19:47 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 04:14:31 GMT]]></title><description><![CDATA[<p dir="auto">i noticed that kind of thing would happen when driving around and the temp is near or below freezing.  has he done any sort of mods to the fuel system, intake, ecu, whatnot?  if he only has free mods, then the ecu will still be giving it plenty of fuel and it should be just fine</p>
]]></description><link>https://fargostreet.com/post/17895</link><guid isPermaLink="true">https://fargostreet.com/post/17895</guid><dc:creator><![CDATA[out there]]></dc:creator><pubDate>Wed, 22 Dec 2004 04:14:31 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 04:07:46 GMT]]></title><description><![CDATA[<p dir="auto">i told him it might be doing this because it's cold out</p>
]]></description><link>https://fargostreet.com/post/17892</link><guid isPermaLink="true">https://fargostreet.com/post/17892</guid><dc:creator><![CDATA[King Ricer]]></dc:creator><pubDate>Wed, 22 Dec 2004 04:07:46 GMT</pubDate></item><item><title><![CDATA[Reply to High boost? on Wed, 22 Dec 2004 04:07:23 GMT]]></title><description><![CDATA[<p dir="auto">yes it's potter and no he isn't using a stock boost gauge</p>
]]></description><link>https://fargostreet.com/post/17891</link><guid isPermaLink="true">https://fargostreet.com/post/17891</guid><dc:creator><![CDATA[King Ricer]]></dc:creator><pubDate>Wed, 22 Dec 2004 04:07:23 GMT</pubDate></item></channel></rss>
