<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Lil update]]></title><description><![CDATA[<p dir="auto">I havent been on here forever but a member from here PMd me on HT and saw what i have been up to and then I figured why not come show you guys even though no one really liked me.  lol</p>
<p dir="auto">ANyways not sure if i ever posted that I blew the d15z1 in my hatch and now I got a JDM d15b with trans, stage 2 clutch, 8lbs flywheel, and a chipped p28.  Then I got a DC sports header and full exhaust and now i am at the point of the newest mods.  My car is finally boosted.  yes i know the d15b bottom ends are weak but its getting taken care of as we speak Right now. I am only at 8psi for now.  The setup is pretty ghetto but it works and to me that is all that matters this moment.</p>
<p dir="auto">Setup is:<br />
JDM d15b<br />
Chipped p28<br />
VX mani<br />
<a href="http://BMCrace.com" rel="nofollow ugc">BMCrace.com</a> adapter plate<br />
14b w/interal WG<br />
1G DSM bov<br />
no name black FMIC<br />
2" ghetto fabbed IC piping<br />
blox 12:1 FMU<br />
Fastturbo vaccuum manifold<br />
auto meter boost/vac, oilpsi gauge<br />
I made a pod out of ABS plastic where the factory radio DIN is and got a HOP center console<br />
2.5" DP to 18" resonator to oval style straight thru muffler(yes i know its robbin me of power but i wanted a quite and comfortable ride)</p>
<p dir="auto">DSM 450s, walbro 255lph pump and crome are all in the works also</p>
<p dir="auto">We used the AEM intake tube but thats coming off this weekend cuz its collapsing and i need to redo my air filter setup cuz its in a SHITTY location.</p>
<p dir="auto">Its nothing special but for 600 bucks if that it is not to bad. I beat an 06 WRX with 3" DP and full cat-delete exhaust and cobb access port and 15psi from a 25 roll. I pulled a good 3 cars by the top of 2nd and ketp on pulling til 120ish</p>
<p dir="auto">On with the pics<br />
<img src="http://i33.photobucket.com/albums/d56/EG_GSR_HB/Matt009.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i33.photobucket.com/albums/d56/EG_GSR_HB/Matt004-1.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i33.photobucket.com/albums/d56/EG_GSR_HB/Matt006.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i33.photobucket.com/albums/d56/EG_GSR_HB/Matt007-2.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i33.photobucket.com/albums/d56/EG_GSR_HB/Matt008-1.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i33.photobucket.com/albums/d56/EG_GSR_HB/Matt011-1.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i33.photobucket.com/albums/d56/EG_GSR_HB/Matt012-1.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i33.photobucket.com/albums/d56/EG_GSR_HB/Matt018-1.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i33.photobucket.com/albums/d56/EG_GSR_HB/Matt021-1.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i33.photobucket.com/albums/d56/EG_GSR_HB/Matt023.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
Almost stock looking exhaust</p>
]]></description><link>https://fargostreet.com/topic/10318/lil-update</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 08:46:58 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/10318.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 Apr 2007 01:06:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Lil update on Thu, 26 Apr 2007 13:31:38 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">krzydrftr93;166251 wrote:<br />
You could of used the lil PM button.   Works pretty good.  I found that out a while ago</p>
<p dir="auto">Good for you......</p>
<p dir="auto">wannabe;166287 wrote:<br />
9.7:1. I also have a very nice clutch, aluminum flywheel, drag radials, SKunk2 intake manifold and TB, full exhaust....</p>
<p dir="auto">Sounds like a good set up, in an EF i spose you could hit that cuz of weight. Good luck.</p>
]]></description><link>https://fargostreet.com/post/156158</link><guid isPermaLink="true">https://fargostreet.com/post/156158</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Thu, 26 Apr 2007 13:31:38 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Thu, 26 Apr 2007 02:43:06 GMT]]></title><description><![CDATA[<p dir="auto">9.7:1. I also have a very nice clutch, aluminum flywheel, drag radials, SKunk2 intake manifold and TB, full exhaust....</p>
]]></description><link>https://fargostreet.com/post/156095</link><guid isPermaLink="true">https://fargostreet.com/post/156095</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Thu, 26 Apr 2007 02:43:06 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Wed, 25 Apr 2007 22:08:28 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">inspector01;166240 wrote:<br />
Im gonna completely hijack this thread and say, is it high comp? low comp? or close to stock?? because i don't think unless you do high compression that you will see mid 13's, but if you do high compression, it will make boosting harder..... jw what your set up was</p>
<p dir="auto">You could of used the lil PM button.   Works pretty good.  I found that out a while ago</p>
]]></description><link>https://fargostreet.com/post/156059</link><guid isPermaLink="true">https://fargostreet.com/post/156059</guid><dc:creator><![CDATA[krzydrftr93]]></dc:creator><pubDate>Wed, 25 Apr 2007 22:08:28 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Wed, 25 Apr 2007 21:07:23 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">wannabe;166152 wrote:<br />
Its actually a built LS/vtec. I plan on running 13.5-13.7 N/A and the motor is capable on a perfect tune to hold 550, so I'de say I wanna try to make 400 wheel. Thats when I boost it, so I'de say next year.</p>
<p dir="auto">Im gonna completely hijack this thread and say, is it high comp? low comp? or close to stock?? because i don't think unless you do high compression that you will see mid 13's, but if you do high compression, it will make boosting harder..... jw what your set up was</p>
]]></description><link>https://fargostreet.com/post/156048</link><guid isPermaLink="true">https://fargostreet.com/post/156048</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Wed, 25 Apr 2007 21:07:23 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Wed, 25 Apr 2007 11:27:50 GMT]]></title><description><![CDATA[<p dir="auto">Its actually a built LS/vtec. I plan on running 13.5-13.7 N/A and the motor is capable on a perfect tune to hold 550, so I'de say I wanna try to make 400 wheel. Thats when I boost it, so I'de say next year.</p>
]]></description><link>https://fargostreet.com/post/155960</link><guid isPermaLink="true">https://fargostreet.com/post/155960</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 25 Apr 2007 11:27:50 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Wed, 25 Apr 2007 05:30:25 GMT]]></title><description><![CDATA[<p dir="auto">those 4 holes in the bumper arent shit.  I have a dent around the fuel door froma fucking deer.  The car needs to see a body shop bad</p>
]]></description><link>https://fargostreet.com/post/155917</link><guid isPermaLink="true">https://fargostreet.com/post/155917</guid><dc:creator><![CDATA[krzydrftr93]]></dc:creator><pubDate>Wed, 25 Apr 2007 05:30:25 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Wed, 25 Apr 2007 05:24:57 GMT]]></title><description><![CDATA[<p dir="auto">Why did you put your plate on the side like that and still have 4 ugly ass holes?  gay</p>
]]></description><link>https://fargostreet.com/post/155915</link><guid isPermaLink="true">https://fargostreet.com/post/155915</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Wed, 25 Apr 2007 05:24:57 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Wed, 25 Apr 2007 04:29:37 GMT]]></title><description><![CDATA[<p dir="auto">Joel i bet you spent double what i spent on your NA build...no i dont know what you have exactly but i seen apost about a built b16 or something;)</p>
]]></description><link>https://fargostreet.com/post/155900</link><guid isPermaLink="true">https://fargostreet.com/post/155900</guid><dc:creator><![CDATA[krzydrftr93]]></dc:creator><pubDate>Wed, 25 Apr 2007 04:29:37 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Wed, 25 Apr 2007 03:28:13 GMT]]></title><description><![CDATA[<p dir="auto">come to fargo and I'll race u N/A</p>
]]></description><link>https://fargostreet.com/post/155884</link><guid isPermaLink="true">https://fargostreet.com/post/155884</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 25 Apr 2007 03:28:13 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Wed, 25 Apr 2007 01:20:02 GMT]]></title><description><![CDATA[<p dir="auto">looks good</p>
]]></description><link>https://fargostreet.com/post/155851</link><guid isPermaLink="true">https://fargostreet.com/post/155851</guid><dc:creator><![CDATA[homie_hoges]]></dc:creator><pubDate>Wed, 25 Apr 2007 01:20:02 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Tue, 24 Apr 2007 20:48:35 GMT]]></title><description><![CDATA[<p dir="auto">Looks great!</p>
]]></description><link>https://fargostreet.com/post/155829</link><guid isPermaLink="true">https://fargostreet.com/post/155829</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Tue, 24 Apr 2007 20:48:35 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Tue, 24 Apr 2007 18:58:37 GMT]]></title><description><![CDATA[<p dir="auto">The dip in the return is getting taken care of this weekend along with the slow annoying drip from it.</p>
<p dir="auto">and i know my piping is nice....free too:icon_santa:</p>
]]></description><link>https://fargostreet.com/post/155809</link><guid isPermaLink="true">https://fargostreet.com/post/155809</guid><dc:creator><![CDATA[krzydrftr93]]></dc:creator><pubDate>Tue, 24 Apr 2007 18:58:37 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Tue, 24 Apr 2007 18:06:45 GMT]]></title><description><![CDATA[<p dir="auto">Still say you should get that "U" bend for your oil return probly changed...</p>
<p dir="auto">FMU FTW</p>
<p dir="auto">ps. nice pipes. :rolleyes:</p>
]]></description><link>https://fargostreet.com/post/155796</link><guid isPermaLink="true">https://fargostreet.com/post/155796</guid><dc:creator><![CDATA[DelSlow]]></dc:creator><pubDate>Tue, 24 Apr 2007 18:06:45 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Tue, 24 Apr 2007 14:39:59 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">youngin2nr;165967 wrote:<br />
I like the plates to.</p>
<p dir="auto">LoL...thanks.  I guess thats what you do when you are bored as shit and have 25 bucks to spend:icon_scratch:</p>
]]></description><link>https://fargostreet.com/post/155779</link><guid isPermaLink="true">https://fargostreet.com/post/155779</guid><dc:creator><![CDATA[krzydrftr93]]></dc:creator><pubDate>Tue, 24 Apr 2007 14:39:59 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Tue, 24 Apr 2007 14:32:45 GMT]]></title><description><![CDATA[<p dir="auto">Lookin nice matt. I like the plates to.</p>
]]></description><link>https://fargostreet.com/post/155776</link><guid isPermaLink="true">https://fargostreet.com/post/155776</guid><dc:creator><![CDATA[youngin2nr]]></dc:creator><pubDate>Tue, 24 Apr 2007 14:32:45 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Tue, 24 Apr 2007 14:19:42 GMT]]></title><description><![CDATA[<p dir="auto">Joel...WEll if someone did they must have some good puke cuz it made my car faster.  I know it doesnt look the greatest.  Wasnt going for looking pretty.</p>
<p dir="auto">ANd I know the charge piping is ghetto.  If you read my post you will see that its getting changed and you also see where i said i need to relocate my air filter cuz I KNOW its not in a good location but for our 10 min piping setup it works</p>
]]></description><link>https://fargostreet.com/post/155774</link><guid isPermaLink="true">https://fargostreet.com/post/155774</guid><dc:creator><![CDATA[krzydrftr93]]></dc:creator><pubDate>Tue, 24 Apr 2007 14:19:42 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Tue, 24 Apr 2007 12:45:06 GMT]]></title><description><![CDATA[<p dir="auto">matt, someone threw up in your engine bay, might wanna check on that...</p>
]]></description><link>https://fargostreet.com/post/155766</link><guid isPermaLink="true">https://fargostreet.com/post/155766</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Tue, 24 Apr 2007 12:45:06 GMT</pubDate></item><item><title><![CDATA[Reply to Lil update on Tue, 24 Apr 2007 09:06:28 GMT]]></title><description><![CDATA[<p dir="auto">that is a pretty rough charge piping set up, and i like the intake right by the exhaust mani.</p>
]]></description><link>https://fargostreet.com/post/155758</link><guid isPermaLink="true">https://fargostreet.com/post/155758</guid><dc:creator><![CDATA[GarageAlchemist]]></dc:creator><pubDate>Tue, 24 Apr 2007 09:06:28 GMT</pubDate></item></channel></rss>
