<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[136 PSI turbocharger.....]]></title><description><![CDATA[<p dir="auto"><a href="http://videos.thefourwheelerpage.com/video/56783655-0322-4de7-8bd2-987c0000ede6.htm" rel="nofollow ugc">http://videos.thefourwheelerpage.com/video/56783655-0322-4de7-8bd2-987c0000ede6.htm</a></p>
<p dir="auto">Discuss....</p>
]]></description><link>https://fargostreet.com/topic/10387/136-psi-turbocharger.....</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 09:52:11 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/10387.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Apr 2007 22:50:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Wed, 02 May 2007 04:31:46 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">MisterCMK;167460 wrote:<br />
What kind of truck do you have?</p>
<p dir="auto">a 95 12valve with 5" exhaust and fuel plate</p>
]]></description><link>https://fargostreet.com/post/157256</link><guid isPermaLink="true">https://fargostreet.com/post/157256</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Wed, 02 May 2007 04:31:46 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Wed, 02 May 2007 04:17:57 GMT]]></title><description><![CDATA[<p dir="auto">Typically the 24 valves are putting down 425-460hp and 800-860 ft lbs w/ just a programmer and exhaust.</p>
<p dir="auto">I ran my truck twice last year stock 16.3, programmer and exhaust 14.7.  7200lbs w/ me in it, definate drastic power increase w/ minimal mods.</p>
]]></description><link>https://fargostreet.com/post/157253</link><guid isPermaLink="true">https://fargostreet.com/post/157253</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Wed, 02 May 2007 04:17:57 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Wed, 02 May 2007 03:55:55 GMT]]></title><description><![CDATA[<p dir="auto">What kind of truck do you have?</p>
]]></description><link>https://fargostreet.com/post/157250</link><guid isPermaLink="true">https://fargostreet.com/post/157250</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Wed, 02 May 2007 03:55:55 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Wed, 02 May 2007 03:33:59 GMT]]></title><description><![CDATA[<p dir="auto">hahaha zach on his tangents</p>
]]></description><link>https://fargostreet.com/post/157244</link><guid isPermaLink="true">https://fargostreet.com/post/157244</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 02 May 2007 03:33:59 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Wed, 02 May 2007 03:24:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Fitzy;167246 wrote:<br />
Most of the big power diesels are stock blocks just head studs and headgaskets.</p>
<p dir="auto">yes he is exactly correct....+ oringed head</p>
<p dir="auto">sorry got excited a little... but that is the other thing i like aside from rotarys..... mechanical pump cummins</p>
]]></description><link>https://fargostreet.com/post/157242</link><guid isPermaLink="true">https://fargostreet.com/post/157242</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Wed, 02 May 2007 03:24:12 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Wed, 02 May 2007 03:21:31 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">KA-T_240;167431 wrote:<br />
^It would not suprise me.</p>
<p dir="auto">I talked to my dad, he said both the hardcore modded trucks in the area are running fully built motors(custom built injection pumps, camshafts....) one is 630whp and the other is 718whp. He also said even at that level you need a built motor.</p>
<p dir="auto">uhh i def dont know about that..... i read religiously on a hardcore cummins forum.... and 450  is no problem even on a tiny ass 9cm2 hx35</p>
<p dir="auto">my pickup would be at 550 wheel easily with a set of injectors, delivery valves, and governor springs and no head work or anytyhing... i cant do this becasue the converter and trany will not support the TQ created</p>
]]></description><link>https://fargostreet.com/post/157240</link><guid isPermaLink="true">https://fargostreet.com/post/157240</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Wed, 02 May 2007 03:21:31 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Wed, 02 May 2007 03:14:53 GMT]]></title><description><![CDATA[<p dir="auto">that is the same motor used in the 3/4 and 1 ton 12 valve dodges.... (94-98.5)<br />
the first gen motors (89-93) were nearly identical cept small changes like the position of the top piston ring and they didnt use an inline Bosh pump like the 2nd 12 valve pickups did,  they used a rotary style pump</p>
<p dir="auto">In 98.5 they switched to the 24 valve which is essentially the same block with a 24valve head and different fueling</p>
<p dir="auto">and i would not be suprised in the least if that is a stock block .... at all</p>
<p dir="auto">usually what is done is flow work on the head and O-ringing the head, and studs</p>
<p dir="auto">do you realize how easy it is to get 800hp/1200fts + out of a 12 valve or 24 valve??  the problem is building your drivetrain to sustain this</p>
<p dir="auto">once more is learned about the common rail system the power potential will be that much more</p>
<p dir="auto">stock equipment in the f650 and a 3/4 ton dodge...... seems like an easy choice:icon_scratch:</p>
]]></description><link>https://fargostreet.com/post/157238</link><guid isPermaLink="true">https://fargostreet.com/post/157238</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Wed, 02 May 2007 03:14:53 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Wed, 02 May 2007 01:57:16 GMT]]></title><description><![CDATA[<p dir="auto">^It would not suprise me.</p>
]]></description><link>https://fargostreet.com/post/157221</link><guid isPermaLink="true">https://fargostreet.com/post/157221</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Wed, 02 May 2007 01:57:16 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Tue, 01 May 2007 23:56:47 GMT]]></title><description><![CDATA[<p dir="auto">Anyone know if he was running propane in that rig?</p>
]]></description><link>https://fargostreet.com/post/157206</link><guid isPermaLink="true">https://fargostreet.com/post/157206</guid><dc:creator><![CDATA[2gTSIGUY]]></dc:creator><pubDate>Tue, 01 May 2007 23:56:47 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Tue, 01 May 2007 15:40:52 GMT]]></title><description><![CDATA[<p dir="auto">There are 2 trucks in the area that I know about that have built motors with a bunch of goodies.</p>
<p dir="auto">You can make power really really quick for a cheaper price on a diesel then a gas truck(chip, intake, exhaust). But when you want to start going for the like 500ish+ it get extremely expensive extremely fast. I know modding anything is expensive especailly when going for lots of power. You have to remember diesels dont rev near as high as gas motors so it takes more of the factors that gain power then other cars.</p>
]]></description><link>https://fargostreet.com/post/157106</link><guid isPermaLink="true">https://fargostreet.com/post/157106</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Tue, 01 May 2007 15:40:52 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Tue, 01 May 2007 09:37:25 GMT]]></title><description><![CDATA[<p dir="auto">Most of the big power diesels are stock blocks just head studs and headgaskets.</p>
]]></description><link>https://fargostreet.com/post/157036</link><guid isPermaLink="true">https://fargostreet.com/post/157036</guid><dc:creator><![CDATA[Fitzy]]></dc:creator><pubDate>Tue, 01 May 2007 09:37:25 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Tue, 01 May 2007 03:56:47 GMT]]></title><description><![CDATA[<p dir="auto">that is probably because it is easier, but i never knew they put that motor in the f650s, that would probably explain why when i was looking under the hood of a 02 f250 and they had the belt configuration printed on the radiator shroud for a 5.9l cummins...</p>
]]></description><link>https://fargostreet.com/post/156948</link><guid isPermaLink="true">https://fargostreet.com/post/156948</guid><dc:creator><![CDATA[beachbum_jon]]></dc:creator><pubDate>Tue, 01 May 2007 03:56:47 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Mon, 30 Apr 2007 15:52:18 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">bubba;166903 wrote:<br />
^ I always thought diesel's would be a lot easier to make that kind of power. One thing i've always wanted to build is a 2500 Ram with a 24V cummins and 6 spd.</p>
<p dir="auto">Same here. I always though it was WAY more easier to make turbo deisels with big power.</p>
]]></description><link>https://fargostreet.com/post/156763</link><guid isPermaLink="true">https://fargostreet.com/post/156763</guid><dc:creator><![CDATA[94NDTA]]></dc:creator><pubDate>Mon, 30 Apr 2007 15:52:18 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Mon, 30 Apr 2007 06:51:40 GMT]]></title><description><![CDATA[<p dir="auto">^ I always thought diesel's would be a lot easier to make that kind of power. One thing i've always wanted to build is a 2500 Ram with a 24V cummins and 6 spd.</p>
]]></description><link>https://fargostreet.com/post/156711</link><guid isPermaLink="true">https://fargostreet.com/post/156711</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Mon, 30 Apr 2007 06:51:40 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Mon, 30 Apr 2007 06:27:57 GMT]]></title><description><![CDATA[<p dir="auto">^Would highly doubt it. Those are tough motors, but I dont think they are that tough, 1000hp in a diesel is way more impressive to me then 1000hp in a gas car.</p>
]]></description><link>https://fargostreet.com/post/156704</link><guid isPermaLink="true">https://fargostreet.com/post/156704</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Mon, 30 Apr 2007 06:27:57 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Mon, 30 Apr 2007 05:44:28 GMT]]></title><description><![CDATA[<p dir="auto">Is this on totally stock longblocks nick?</p>
]]></description><link>https://fargostreet.com/post/156698</link><guid isPermaLink="true">https://fargostreet.com/post/156698</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Mon, 30 Apr 2007 05:44:28 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Mon, 30 Apr 2007 02:56:50 GMT]]></title><description><![CDATA[<p dir="auto">Oh, my bad.</p>
]]></description><link>https://fargostreet.com/post/156680</link><guid isPermaLink="true">https://fargostreet.com/post/156680</guid><dc:creator><![CDATA[94NDTA]]></dc:creator><pubDate>Mon, 30 Apr 2007 02:56:50 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Mon, 30 Apr 2007 02:27:11 GMT]]></title><description><![CDATA[<p dir="auto">No, last years winner went 10.23.</p>
]]></description><link>https://fargostreet.com/post/156673</link><guid isPermaLink="true">https://fargostreet.com/post/156673</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Mon, 30 Apr 2007 02:27:11 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Mon, 30 Apr 2007 02:23:39 GMT]]></title><description><![CDATA[<p dir="auto">What cummins? SLS's cummins?</p>
]]></description><link>https://fargostreet.com/post/156672</link><guid isPermaLink="true">https://fargostreet.com/post/156672</guid><dc:creator><![CDATA[94NDTA]]></dc:creator><pubDate>Mon, 30 Apr 2007 02:23:39 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Mon, 30 Apr 2007 02:22:07 GMT]]></title><description><![CDATA[<p dir="auto">Not uncommon boost level for big power diesel.  Last years Diesel shootout the Cummins went 10.23.</p>
]]></description><link>https://fargostreet.com/post/156671</link><guid isPermaLink="true">https://fargostreet.com/post/156671</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Mon, 30 Apr 2007 02:22:07 GMT</pubDate></item><item><title><![CDATA[Reply to 136 PSI turbocharger..... on Mon, 30 Apr 2007 00:17:49 GMT]]></title><description><![CDATA[<p dir="auto">that the same motor they use in all of the dodges?...and is that a stock longblock i wonder???...hmmm...thats fast lol...especially considering it's about as aerodynamic as a brick.</p>
]]></description><link>https://fargostreet.com/post/156652</link><guid isPermaLink="true">https://fargostreet.com/post/156652</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Mon, 30 Apr 2007 00:17:49 GMT</pubDate></item></channel></rss>
