<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[condensation in tail lights]]></title><description><![CDATA[<p dir="auto">Just wondering if anyone on here knows a good way to get condensation out of a tail light?  Cause my eveslow has some condensation in it, but its more like a lake in my tail light.</p>
]]></description><link>https://fargostreet.com/topic/10518/condensation-in-tail-lights</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:56:43 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/10518.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 May 2007 13:25:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to condensation in tail lights on Wed, 09 May 2007 02:58:24 GMT]]></title><description><![CDATA[<p dir="auto">more than likely to pull it all apart, u will need to stick it in the oven to heat up the adhesive.</p>
]]></description><link>https://fargostreet.com/post/158406</link><guid isPermaLink="true">https://fargostreet.com/post/158406</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 09 May 2007 02:58:24 GMT</pubDate></item><item><title><![CDATA[Reply to condensation in tail lights on Tue, 08 May 2007 22:20:52 GMT]]></title><description><![CDATA[<p dir="auto">good write up colin <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/158346</link><guid isPermaLink="true">https://fargostreet.com/post/158346</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Tue, 08 May 2007 22:20:52 GMT</pubDate></item><item><title><![CDATA[Reply to condensation in tail lights on Tue, 08 May 2007 13:54:30 GMT]]></title><description><![CDATA[<p dir="auto">Pull back your trunk lining,<br />
remove all the bulbs,<br />
un-bolt your tailight,<br />
remove tailight from car.<br />
Set it somewhere to drain/dry.<br />
If there's dirty/dust inside anyway you can clean it out .<br />
Go buy some ureathane caulk at a autoparts/hardware store.<br />
Remove the existing sticky black stuff from around your tailight housing.<br />
Re-apply the urethane caulk around the same line.<br />
replace tailight housing on car.<br />
Check all the little sealing rings around your bulb sockets.<br />
replace any that need it.<br />
plug everything back in.</p>
]]></description><link>https://fargostreet.com/post/158269</link><guid isPermaLink="true">https://fargostreet.com/post/158269</guid><dc:creator><![CDATA[Colin]]></dc:creator><pubDate>Tue, 08 May 2007 13:54:30 GMT</pubDate></item></channel></rss>
