<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[need clutch and flywheel help]]></title><description><![CDATA[<p dir="auto">So yesterday I ran into some problems.  I'm pretty sure my clutch finally went.  I havent dropped the tranny yet so i dont know for sure what I need.  I just had a new clutch line put on at tintmasters but that didnt help my problem.  Here's what I need help with.</p>
<ol>
<li>
<p dir="auto">Anybody know of a good shop that can drop my transmission for a good price.  I want to drop it so I can check the spec on the flywheel because it's probably off and causing my problems.  I just need it dropped so we can find out what is for sure wrong with it.  I don't think I could do it myself either.  Any help here is greatly appreciated.</p>
</li>
<li>
<p dir="auto">I plan on making somewhere in the 340ish range for hp on my talon.  I want some suggesstions of a good clutch and flywheel set up with some prices.  I have looked around and what not but I havent decided on what to get yet.</p>
</li>
</ol>
<p dir="auto">So any help with the dropping of my transmission or the clutch and flywheel situation would be great.  Money is sort of a problem, but I dont want to cheap out.  I want it to be a daily driver but still be a good clutch for my power.  I dont rip on my car very much.  I just want to do this right since I'll be pulling the tranny here pretty soon.  I have replaced my slave and master cylinders also.   Thanks a lot guys.</p>
]]></description><link>https://fargostreet.com/topic/10871/need-clutch-and-flywheel-help</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 10:18:54 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/10871.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Jun 2007 00:07:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to need clutch and flywheel help on Thu, 07 Jun 2007 03:35:21 GMT]]></title><description><![CDATA[<p dir="auto">You will find that that you will find the best pricing at SLS for ACT!!</p>
<p dir="auto">Call and talk to mike 701.282.2902</p>
<p dir="auto">Id just use a stock flywheel resurfaced with a xtreme HD 6 puck sprung disk if you race and a street disk if you dont..  also known as 2600</p>
<p dir="auto">also you will want to by-pass the restrictor between the master cylinder and slave cylinder.. I could show you  if you want..</p>
<p dir="auto">If you pull it your self be prepared to work on it for 8 or so hours</p>
]]></description><link>https://fargostreet.com/post/162252</link><guid isPermaLink="true">https://fargostreet.com/post/162252</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Thu, 07 Jun 2007 03:35:21 GMT</pubDate></item><item><title><![CDATA[Reply to need clutch and flywheel help on Thu, 07 Jun 2007 00:23:06 GMT]]></title><description><![CDATA[<p dir="auto">use a stock flywheel and a act 2600 clutch</p>
]]></description><link>https://fargostreet.com/post/162228</link><guid isPermaLink="true">https://fargostreet.com/post/162228</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Thu, 07 Jun 2007 00:23:06 GMT</pubDate></item></channel></rss>
