<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[in dash lcd]]></title><description><![CDATA[<p dir="auto">ok so i bought an indash tv for my car and had a quick question wondering if anyone could answer,  at the moment i was just going to have it installed at site on sound which i didnt ask but am assuming will do it the legal way, so wondering if anyone else know if someone knows of anyone or can do it so it can play dvds while driving? which i am assuming they wont do</p>
]]></description><link>https://fargostreet.com/topic/11112/in-dash-lcd</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 04:38:08 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/11112.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Jun 2007 21:34:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to in dash lcd on Fri, 29 Jun 2007 05:02:43 GMT]]></title><description><![CDATA[<p dir="auto">When you get the unit, the install manual will tell you what needs to be done, if Chuck's options dont work.</p>
]]></description><link>https://fargostreet.com/post/164950</link><guid isPermaLink="true">https://fargostreet.com/post/164950</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Fri, 29 Jun 2007 05:02:43 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Thu, 28 Jun 2007 19:14:59 GMT]]></title><description><![CDATA[<p dir="auto">thanks a ton that will definatly help!</p>
]]></description><link>https://fargostreet.com/post/164901</link><guid isPermaLink="true">https://fargostreet.com/post/164901</guid><dc:creator><![CDATA[killer69penguin]]></dc:creator><pubDate>Thu, 28 Jun 2007 19:14:59 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Thu, 28 Jun 2007 14:21:59 GMT]]></title><description><![CDATA[<p dir="auto">option 1 is for newer units, option 2 is for the older ones.</p>
]]></description><link>https://fargostreet.com/post/164872</link><guid isPermaLink="true">https://fargostreet.com/post/164872</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 28 Jun 2007 14:21:59 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Thu, 28 Jun 2007 14:21:31 GMT]]></title><description><![CDATA[<p dir="auto">Depending on the model of Jensen you have one of the follwing should work:</p>
<p dir="auto">OPTION 1The parking brake bypass procedure is as follows:</p>
<p dir="auto">1: Go into AM/FM mode<br />
2: Hit "setup" on the remote control<br />
3: Enter 543210 on the remote, listening for the beep for each number entered<br />
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.<br />
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.<br />
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another</p>
<p dir="auto">Option 2:</p>
<p dir="auto">Once you have everything hooked up pop in a dvd and when it starts playing do the following</p>
<p dir="auto">Take the pink parking break wire and touch it to ground for 2 seconds, then remove it from ground for 2 seconds, then put it back on ground if at this time the screen starts showing the movie then keep it grounded, if not try to remove for 2 seconds again and then back to ground, you might have to ground/unground for 2 times or 3, ok now that you are grounded and the movie is showing use the remote and hit ( stop, stop, 1264) this should bring up a menu and one of the options in that menu will say something about the parking break bypass. if it is off turn it on if its on turn it off. I cant remember which one it is set at so which ever its on when you see that menu turn it to the opposite</p>
<p dir="auto">wait for a few seconds and the menu should go away if not just hit tuner or tv or one of those buttons of the head unit</p>
<p dir="auto">you should now be able to unground it and not even worry about that parking braek wire and everything is good to go</p>
]]></description><link>https://fargostreet.com/post/164871</link><guid isPermaLink="true">https://fargostreet.com/post/164871</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 28 Jun 2007 14:21:31 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Thu, 28 Jun 2007 08:30:15 GMT]]></title><description><![CDATA[<p dir="auto">haha yep it was acctually i returned that one though because i found a different one i liked on ebay and bought it but its still also a jensen</p>
]]></description><link>https://fargostreet.com/post/164867</link><guid isPermaLink="true">https://fargostreet.com/post/164867</guid><dc:creator><![CDATA[killer69penguin]]></dc:creator><pubDate>Thu, 28 Jun 2007 08:30:15 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Thu, 28 Jun 2007 05:59:19 GMT]]></title><description><![CDATA[<p dir="auto">im betting the jensen that u get at walmart..if so ill get u a sheet that tells you how exactly to do it..</p>
]]></description><link>https://fargostreet.com/post/164860</link><guid isPermaLink="true">https://fargostreet.com/post/164860</guid><dc:creator><![CDATA[blindsp1]]></dc:creator><pubDate>Thu, 28 Jun 2007 05:59:19 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Thu, 28 Jun 2007 05:42:45 GMT]]></title><description><![CDATA[<p dir="auto">any chance you know about a jensen?</p>
]]></description><link>https://fargostreet.com/post/164857</link><guid isPermaLink="true">https://fargostreet.com/post/164857</guid><dc:creator><![CDATA[killer69penguin]]></dc:creator><pubDate>Thu, 28 Jun 2007 05:42:45 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Thu, 28 Jun 2007 03:13:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">killer69penguin;175288 wrote:<br />
and what does it take to be hooked up the legal way thats kinda what i was askin might  get a little help though at some time</p>
<p dir="auto">That depends on which unit you get.  Some just need to have the e-brake wire grounded out, some need to see a certain sequence of the brake pedal and parking brake.  There are ways around all of it.</p>
]]></description><link>https://fargostreet.com/post/164836</link><guid isPermaLink="true">https://fargostreet.com/post/164836</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Thu, 28 Jun 2007 03:13:11 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Thu, 28 Jun 2007 02:50:34 GMT]]></title><description><![CDATA[<p dir="auto">and what does it take to be hooked up the legal way thats kinda what i was askin might  get a little help though at some time</p>
]]></description><link>https://fargostreet.com/post/164832</link><guid isPermaLink="true">https://fargostreet.com/post/164832</guid><dc:creator><![CDATA[killer69penguin]]></dc:creator><pubDate>Thu, 28 Jun 2007 02:50:34 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Thu, 28 Jun 2007 02:18:34 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">3_Series;175262 wrote:<br />
You do know it's illegal to be watching a movie while driving don't you?</p>
<p dir="auto">Who cares?  Do you have any idea how many people do it anyway?  If you get pulled over, just switch to the radio, no problem <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://fargostreet.com/post/164827</link><guid isPermaLink="true">https://fargostreet.com/post/164827</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Thu, 28 Jun 2007 02:18:34 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Thu, 28 Jun 2007 00:22:09 GMT]]></title><description><![CDATA[<p dir="auto">But of course, I am blind.</p>
]]></description><link>https://fargostreet.com/post/164818</link><guid isPermaLink="true">https://fargostreet.com/post/164818</guid><dc:creator><![CDATA[3_Series]]></dc:creator><pubDate>Thu, 28 Jun 2007 00:22:09 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Thu, 28 Jun 2007 00:13:02 GMT]]></title><description><![CDATA[<p dir="auto">I'm sure he does, since he refered to it as "the legal way"^^^</p>
]]></description><link>https://fargostreet.com/post/164815</link><guid isPermaLink="true">https://fargostreet.com/post/164815</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 28 Jun 2007 00:13:02 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Wed, 27 Jun 2007 23:06:11 GMT]]></title><description><![CDATA[<p dir="auto">You do know it's illegal to be watching a movie while driving don't you?</p>
]]></description><link>https://fargostreet.com/post/164806</link><guid isPermaLink="true">https://fargostreet.com/post/164806</guid><dc:creator><![CDATA[3_Series]]></dc:creator><pubDate>Wed, 27 Jun 2007 23:06:11 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Wed, 27 Jun 2007 22:59:12 GMT]]></title><description><![CDATA[<p dir="auto">i can do it, tjamz can do it, tintmasters can do it, team can do it....</p>
]]></description><link>https://fargostreet.com/post/164804</link><guid isPermaLink="true">https://fargostreet.com/post/164804</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Wed, 27 Jun 2007 22:59:12 GMT</pubDate></item><item><title><![CDATA[Reply to in dash lcd on Wed, 27 Jun 2007 21:40:10 GMT]]></title><description><![CDATA[<p dir="auto">just have them do it, and usualy you just pull the ebrake one click, wont do anything</p>
]]></description><link>https://fargostreet.com/post/164795</link><guid isPermaLink="true">https://fargostreet.com/post/164795</guid><dc:creator><![CDATA[DelSlow]]></dc:creator><pubDate>Wed, 27 Jun 2007 21:40:10 GMT</pubDate></item></channel></rss>
