<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Seats!!!]]></title><description><![CDATA[<p dir="auto">So I was finishing up putting in my harness's today and i got to the passenger one and started to unbolt the brackets so i could put the lap belt in for the harness. I started to bolt it all back together and i stripped out the left rear bracket.... So now I cant bolt the seat down and i cant finish up putting the belts in!!! What a night!! Any advice on what to do with the stripped out thing!! I dont own a tap so i couldnt retap the whole thing!! Any advice?? I know there is a lot of non technical terms in here...</p>
]]></description><link>https://fargostreet.com/topic/11272/seats</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:11:51 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/11272.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 15 Jul 2007 04:38:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Seats!!! on Wed, 18 Jul 2007 05:14:54 GMT]]></title><description><![CDATA[<p dir="auto">Well I took care of this little seat thing!! Heli Coil FTW!!!</p>
]]></description><link>https://fargostreet.com/post/167121</link><guid isPermaLink="true">https://fargostreet.com/post/167121</guid><dc:creator><![CDATA[DWeigs]]></dc:creator><pubDate>Wed, 18 Jul 2007 05:14:54 GMT</pubDate></item><item><title><![CDATA[Reply to Seats!!! on Sun, 15 Jul 2007 19:49:47 GMT]]></title><description><![CDATA[<p dir="auto">If you chewed up the threads on the car, a tap probably won't help unless you drill it out to the next size up and tap it larger.  You could also use a helicoil on it.</p>
]]></description><link>https://fargostreet.com/post/166685</link><guid isPermaLink="true">https://fargostreet.com/post/166685</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sun, 15 Jul 2007 19:49:47 GMT</pubDate></item><item><title><![CDATA[Reply to Seats!!! on Sun, 15 Jul 2007 19:32:11 GMT]]></title><description><![CDATA[<p dir="auto">Threads on the car...</p>
]]></description><link>https://fargostreet.com/post/166681</link><guid isPermaLink="true">https://fargostreet.com/post/166681</guid><dc:creator><![CDATA[DWeigs]]></dc:creator><pubDate>Sun, 15 Jul 2007 19:32:11 GMT</pubDate></item><item><title><![CDATA[Reply to Seats!!! on Sun, 15 Jul 2007 19:24:43 GMT]]></title><description><![CDATA[<p dir="auto">Did you strip out the bolt or the threads on the car?</p>
]]></description><link>https://fargostreet.com/post/166678</link><guid isPermaLink="true">https://fargostreet.com/post/166678</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sun, 15 Jul 2007 19:24:43 GMT</pubDate></item><item><title><![CDATA[Reply to Seats!!! on Sun, 15 Jul 2007 19:09:30 GMT]]></title><description><![CDATA[<p dir="auto">I dont think i am going to be able to get to it... I think I might just go invest in a tap set later today!!</p>
]]></description><link>https://fargostreet.com/post/166676</link><guid isPermaLink="true">https://fargostreet.com/post/166676</guid><dc:creator><![CDATA[DWeigs]]></dc:creator><pubDate>Sun, 15 Jul 2007 19:09:30 GMT</pubDate></item><item><title><![CDATA[Reply to Seats!!! on Sun, 15 Jul 2007 15:06:43 GMT]]></title><description><![CDATA[<p dir="auto">Drill it out larger and put a nut underneath the car. Then weld the nut to the car. That is if you can get to it.</p>
]]></description><link>https://fargostreet.com/post/166659</link><guid isPermaLink="true">https://fargostreet.com/post/166659</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Sun, 15 Jul 2007 15:06:43 GMT</pubDate></item><item><title><![CDATA[Reply to Seats!!! on Sun, 15 Jul 2007 05:52:05 GMT]]></title><description><![CDATA[<p dir="auto">Not even sure!! Its a 12 millimeter bolt.... I dont think that helps any!! Plus im in Grand Forks!!</p>
]]></description><link>https://fargostreet.com/post/166634</link><guid isPermaLink="true">https://fargostreet.com/post/166634</guid><dc:creator><![CDATA[DWeigs]]></dc:creator><pubDate>Sun, 15 Jul 2007 05:52:05 GMT</pubDate></item><item><title><![CDATA[Reply to Seats!!! on Sun, 15 Jul 2007 05:41:08 GMT]]></title><description><![CDATA[<p dir="auto">i've got a pretty extensive metric tap &amp; die set.  What size fastener?</p>
]]></description><link>https://fargostreet.com/post/166632</link><guid isPermaLink="true">https://fargostreet.com/post/166632</guid><dc:creator><![CDATA[thrash]]></dc:creator><pubDate>Sun, 15 Jul 2007 05:41:08 GMT</pubDate></item><item><title><![CDATA[Reply to Seats!!! on Sun, 15 Jul 2007 05:39:25 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">DWeigs;177129 wrote:<br />
Thinking about just forcing a bigger bolt in there or something for now....</p>
<p dir="auto">you can try, but i can almost garranty that you will regret it later when you go to remove it. trust me, i have done it in the past (when i started fixing cars as a profession) and learned my lesson.  You'll have a much harder time removing the broken bolt in that hole than to rethread the hole.</p>
]]></description><link>https://fargostreet.com/post/166631</link><guid isPermaLink="true">https://fargostreet.com/post/166631</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Sun, 15 Jul 2007 05:39:25 GMT</pubDate></item><item><title><![CDATA[Reply to Seats!!! on Sun, 15 Jul 2007 05:36:58 GMT]]></title><description><![CDATA[<p dir="auto">Thinking about just forcing a bigger bolt in there or something for now....</p>
]]></description><link>https://fargostreet.com/post/166630</link><guid isPermaLink="true">https://fargostreet.com/post/166630</guid><dc:creator><![CDATA[DWeigs]]></dc:creator><pubDate>Sun, 15 Jul 2007 05:36:58 GMT</pubDate></item><item><title><![CDATA[Reply to Seats!!! on Sun, 15 Jul 2007 05:31:04 GMT]]></title><description><![CDATA[<p dir="auto">buy a tap. about all you can do.</p>
]]></description><link>https://fargostreet.com/post/166629</link><guid isPermaLink="true">https://fargostreet.com/post/166629</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Sun, 15 Jul 2007 05:31:04 GMT</pubDate></item></channel></rss>
