<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CL overheating issue]]></title><description><![CDATA[<p dir="auto">So, my Acura 2.3 CL tempature gauge climbs almost into the red when I'm sitting at stop lights or in drivethrus a majority of the time. As soon as I start moving again it drops back down to a normal level. I haven't seen any coolant leaks or puddles, and the coolant level is normal. Any clues at too what the problem is? thanks.</p>
]]></description><link>https://fargostreet.com/topic/11357/cl-overheating-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 22:49:51 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/11357.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Jul 2007 01:07:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CL overheating issue on Fri, 27 Jul 2007 04:19:58 GMT]]></title><description><![CDATA[<p dir="auto">[QUOTE][Yeah um.......dont get me started on saturns!/QUOTE]<br />
:icon_cheers:</p>
]]></description><link>https://fargostreet.com/post/168083</link><guid isPermaLink="true">https://fargostreet.com/post/168083</guid><dc:creator><![CDATA[CRX_Civic]]></dc:creator><pubDate>Fri, 27 Jul 2007 04:19:58 GMT</pubDate></item><item><title><![CDATA[Reply to CL overheating issue on Thu, 26 Jul 2007 04:01:25 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">7ormore;178517 wrote:<br />
on my saturn the fan doesn't kick on till its in the red but they say that's nomal</p>
<p dir="auto">Yeah um.......dont get me started on saturns! <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":(" alt="😞" /></p>
]]></description><link>https://fargostreet.com/post/167987</link><guid isPermaLink="true">https://fargostreet.com/post/167987</guid><dc:creator><![CDATA[ruthless351]]></dc:creator><pubDate>Thu, 26 Jul 2007 04:01:25 GMT</pubDate></item><item><title><![CDATA[Reply to CL overheating issue on Thu, 26 Jul 2007 03:56:22 GMT]]></title><description><![CDATA[<p dir="auto">on my saturn the fan doesn't kick on till its in the red but they say that's nomal</p>
]]></description><link>https://fargostreet.com/post/167985</link><guid isPermaLink="true">https://fargostreet.com/post/167985</guid><dc:creator><![CDATA[7ormore]]></dc:creator><pubDate>Thu, 26 Jul 2007 03:56:22 GMT</pubDate></item><item><title><![CDATA[Reply to CL overheating issue on Thu, 26 Jul 2007 02:13:43 GMT]]></title><description><![CDATA[<p dir="auto">my civic did the same thing so i replaced the thermostat and no change, new radiator cap..problem solved.</p>
]]></description><link>https://fargostreet.com/post/167973</link><guid isPermaLink="true">https://fargostreet.com/post/167973</guid><dc:creator><![CDATA[CRX_Civic]]></dc:creator><pubDate>Thu, 26 Jul 2007 02:13:43 GMT</pubDate></item><item><title><![CDATA[Reply to CL overheating issue on Wed, 25 Jul 2007 17:27:58 GMT]]></title><description><![CDATA[<p dir="auto">If your car is cooling correctly while driving,  it is not a major issue....  usually.  first thing i would check is fuses,  then for relays,  if those are all good a look at the fan itself.   i am unsure if that car has a temp switch,  id immagine that a car that new may be controlled (on and off) by the car computer,  but if there is a  fan switch/ temp switch that may be an issue also.   what i would do after checking fuses and relays is disconnect the fan and test it with a direct wire to battery and see if it goes.    hope that helps.   :icon_thumright:</p>
]]></description><link>https://fargostreet.com/post/167937</link><guid isPermaLink="true">https://fargostreet.com/post/167937</guid><dc:creator><![CDATA[Goodnbuzzd]]></dc:creator><pubDate>Wed, 25 Jul 2007 17:27:58 GMT</pubDate></item><item><title><![CDATA[Reply to CL overheating issue on Wed, 25 Jul 2007 04:47:23 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">ruthless351;178402 wrote:<br />
Sounds like the cooling fan isnt turning on. Check some fuses.</p>
<p dir="auto">I had that problem too in one of my old cars. I was sitting in the drive thru at McDonald's one hot afternoon and ended up overheating and having white smoke everywhere.</p>
]]></description><link>https://fargostreet.com/post/167899</link><guid isPermaLink="true">https://fargostreet.com/post/167899</guid><dc:creator><![CDATA[amicheze]]></dc:creator><pubDate>Wed, 25 Jul 2007 04:47:23 GMT</pubDate></item><item><title><![CDATA[Reply to CL overheating issue on Wed, 25 Jul 2007 01:09:54 GMT]]></title><description><![CDATA[<p dir="auto">Sounds like the cooling fan isnt turning on. Check some fuses.</p>
]]></description><link>https://fargostreet.com/post/167876</link><guid isPermaLink="true">https://fargostreet.com/post/167876</guid><dc:creator><![CDATA[ruthless351]]></dc:creator><pubDate>Wed, 25 Jul 2007 01:09:54 GMT</pubDate></item></channel></rss>
