<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[turbo or na]]></title><description><![CDATA[<p dir="auto">alright so me and my friends were having a discussion on which is better on gas.</p>
<p dir="auto">the discussion consisted of topics such as turbocharged vehicles need bigger fuel injectors which obviously spray more fuel.</p>
<p dir="auto">but also at cruising speeds the turbo is a restriction in the exhaust system, but once you need power like going up hills or in the mountains, it is more easy to get power with the turbo pulling you through.</p>
<p dir="auto">does anyone have any takes on this. i know its hard to prove such a thing like this and the topic can be too sided and bascially it all comes down to your foot.</p>
<p dir="auto">thanks, jon</p>
]]></description><link>https://fargostreet.com/topic/11605/turbo-or-na</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:15:46 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/11605.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Aug 2007 23:52:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to turbo or na on Sun, 26 Aug 2007 18:14:55 GMT]]></title><description><![CDATA[<p dir="auto">For the factory specs on a 92 talon it says the na gets better gas millage.<br />
<a href="http://autos.msn.com/research/vip/Spec_Glance.aspx?year=1992&amp;make=Eagle&amp;model=Talon&amp;trimid=-1" rel="nofollow ugc">http://autos.msn.com/research/vip/Spec_Glance.aspx?year=1992&amp;make=Eagle&amp;model=Talon&amp;trimid=-1</a><br />
I think the exact same engine was used on both na and turboed versions of this car for that year.</p>
<p dir="auto"><a href="http://autos.msn.com/research/vip/Spec_Glance.aspx?year=1995&amp;make=Eagle&amp;model=Talon&amp;trimid=-1" rel="nofollow ugc">http://autos.msn.com/research/vip/Spec_Glance.aspx?year=1995&amp;make=Eagle&amp;model=Talon&amp;trimid=-1</a><br />
the 2g was very close for gas millage but differant engines were used.</p>
<p dir="auto"><a href="http://autos.msn.com/research/vip/Spec_Glance.aspx?year=2007&amp;make=Chevrolet&amp;model=Cobalt&amp;trimid=-1" rel="nofollow ugc">http://autos.msn.com/research/vip/Spec_Glance.aspx?year=2007&amp;make=Chevrolet&amp;model=Cobalt&amp;trimid=-1</a><br />
the supercharged colbalt get worse milage than the na colbalt.</p>
]]></description><link>https://fargostreet.com/post/171125</link><guid isPermaLink="true">https://fargostreet.com/post/171125</guid><dc:creator><![CDATA[black2g]]></dc:creator><pubDate>Sun, 26 Aug 2007 18:14:55 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Sun, 26 Aug 2007 07:38:09 GMT]]></title><description><![CDATA[<p dir="auto">bench racing is an ugly thing.</p>
<p dir="auto">first off, to eliminate the chassis and driveline from the process, you need to look at the fuel consumption for a given engine output level with the engine on a stand.</p>
<p dir="auto">Next, there's no magic involved -- making a certain amount of HP requires a certain amount of air, which also requires a certain amount of fuel.  Of course, any engine makes power that you cannot measure at the crank.. this is power used to turn the alternator, or to warm the engine, or to pump the engines oil, etc.</p>
<p dir="auto">It is my opinion that given two engines making identical peak power at the same RPM, with similar internal losses and accessory loads, the NA engine will use less fuel.</p>
<p dir="auto">Of course, where are you going to find 2 identical engines that make the same amount of HP in both NA and turbo versions?  If one of them is a 3 liter V6 vs a 2 liter I4 turbo, the internal differences will be intrinsically different due to different # of bearings, balance shafts, # of valves, etc.</p>
<p dir="auto">I think as a practical matter, a smaller, lower displacement turbo engine can make similar peak power when its boosting, but be lighter and consume less fuel when its not boosting.  The A4 2.0T gets better milages than the A4 3.2 V6.</p>
<p dir="auto">Under boost i think an NA engine does better.  Turbo combustion is less efficient than NA combustion i think, and most turbos run rich under boost.  running rich == using more fuel than strictly necessary.</p>
<p dir="auto">In around town driving, my A4 2.0T gets better mileage than my 2.8L NA V6 passat, which gets MUCH better mileage than my 3.5L I6 NA M5.  The A4 is 200hp, the VW is 190hp, and the M5 is ~250hp.  The A4 is actually the heaviest of the vehicles and has the most drivetrain losses.  It's also got the most efficient engine design with the most modern technology.</p>
]]></description><link>https://fargostreet.com/post/171093</link><guid isPermaLink="true">https://fargostreet.com/post/171093</guid><dc:creator><![CDATA[thrash]]></dc:creator><pubDate>Sun, 26 Aug 2007 07:38:09 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Sat, 25 Aug 2007 14:41:48 GMT]]></title><description><![CDATA[<p dir="auto">I would say NA or gas mileage... I could never NOT boost...</p>
]]></description><link>https://fargostreet.com/post/171037</link><guid isPermaLink="true">https://fargostreet.com/post/171037</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Sat, 25 Aug 2007 14:41:48 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Sat, 25 Aug 2007 04:52:51 GMT]]></title><description><![CDATA[<p dir="auto">On my del sol, i consistently got about 32 mpg on it NA, when i turbod it, even before tuning i got 33 mpg, and that is usually what i got so i gained about 1 mpg on average.</p>
]]></description><link>https://fargostreet.com/post/171017</link><guid isPermaLink="true">https://fargostreet.com/post/171017</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Sat, 25 Aug 2007 04:52:51 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Sat, 25 Aug 2007 01:50:54 GMT]]></title><description><![CDATA[<p dir="auto">The fact of the matter is both.  There are so many variables that one could argue this for EVER.  Flow of both air and fuel, restrictions wheter it be exhaust or intake.  This is like comparing apples to oranges.</p>
]]></description><link>https://fargostreet.com/post/170999</link><guid isPermaLink="true">https://fargostreet.com/post/170999</guid><dc:creator><![CDATA[bader3245]]></dc:creator><pubDate>Sat, 25 Aug 2007 01:50:54 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Fri, 24 Aug 2007 05:08:04 GMT]]></title><description><![CDATA[<p dir="auto">The most I've ever gotten in my dsm is 26mpg that I know of.  That was cruising to ndsu from mn.  I can get as low as 16-18 mpg though sadly.  2.0L ftw lol!</p>
]]></description><link>https://fargostreet.com/post/170868</link><guid isPermaLink="true">https://fargostreet.com/post/170868</guid><dc:creator><![CDATA[mr.98gsx]]></dc:creator><pubDate>Fri, 24 Aug 2007 05:08:04 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Fri, 24 Aug 2007 02:52:38 GMT]]></title><description><![CDATA[<p dir="auto">i just mean factory tune...same motor same everything..like a na dsm from factory and turbo dsm from factory...everything is BONE STOCK. which will get better gas mileage average?</p>
]]></description><link>https://fargostreet.com/post/170851</link><guid isPermaLink="true">https://fargostreet.com/post/170851</guid><dc:creator><![CDATA[beachbum_jon]]></dc:creator><pubDate>Fri, 24 Aug 2007 02:52:38 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Fri, 24 Aug 2007 01:10:45 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">KA-T_240;181426 wrote:<br />
i actually have no personal expeince. never drove on the highway with my car. I have delivered them but dont fill the tank up. i got just under 27 with a auto, which in 240s when stock gets better gasmileage. but it was -20 so thats a big side affect right there</p>
<p dir="auto">I also think I would have better gas mileage with a bigger turbo, because it would take more rpm to spool. on the highway at 80mph, I am at 3200-3300rpm in 5th gear. which when I am full throttle at the rpm at am in the upper teens in boost. so if it hit a bump oops 10psi, lol</p>
<p dir="auto">Type much?</p>
<p dir="auto">It all depends on your tune. It doesnt matter whether your turbo or N/A when you aren't in boost. most turbo people just have their cars tuned to be lean at low RPMS. Lean obviously means better gas mileage. i guess air swirling thought a turbo/Intercooler/ic piping might make a tiny bit of difference on gas mileage, but I highly doubt it.</p>
]]></description><link>https://fargostreet.com/post/170830</link><guid isPermaLink="true">https://fargostreet.com/post/170830</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Fri, 24 Aug 2007 01:10:45 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Fri, 24 Aug 2007 01:07:53 GMT]]></title><description><![CDATA[<p dir="auto">2 words</p>
<p dir="auto">Volumetric Efficiency</p>
]]></description><link>https://fargostreet.com/post/170828</link><guid isPermaLink="true">https://fargostreet.com/post/170828</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Fri, 24 Aug 2007 01:07:53 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Fri, 24 Aug 2007 00:57:16 GMT]]></title><description><![CDATA[<p dir="auto">i actually have no personal expeince. never drove on the highway with my car. I have delivered them but dont fill the tank up. i got just under 27 with a auto, which in 240s when stock gets better gasmileage. but it was -20 so thats a big side affect right there</p>
]]></description><link>https://fargostreet.com/post/170824</link><guid isPermaLink="true">https://fargostreet.com/post/170824</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Fri, 24 Aug 2007 00:57:16 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Fri, 24 Aug 2007 00:29:22 GMT]]></title><description><![CDATA[<p dir="auto">okay ka-t , i assume you have a ka24 in your 240, what does a na ka24 get for gas mileage on the highway?</p>
]]></description><link>https://fargostreet.com/post/170814</link><guid isPermaLink="true">https://fargostreet.com/post/170814</guid><dc:creator><![CDATA[beachbum_jon]]></dc:creator><pubDate>Fri, 24 Aug 2007 00:29:22 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Fri, 24 Aug 2007 00:23:59 GMT]]></title><description><![CDATA[<p dir="auto">ya, I dont get the best gas mileage in town. but its just soo much fun!</p>
]]></description><link>https://fargostreet.com/post/170813</link><guid isPermaLink="true">https://fargostreet.com/post/170813</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Fri, 24 Aug 2007 00:23:59 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Fri, 24 Aug 2007 00:05:23 GMT]]></title><description><![CDATA[<p dir="auto">i get 28 ish mpg in my probe when i'm not on it in town....</p>
]]></description><link>https://fargostreet.com/post/170811</link><guid isPermaLink="true">https://fargostreet.com/post/170811</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Fri, 24 Aug 2007 00:05:23 GMT</pubDate></item><item><title><![CDATA[Reply to turbo or na on Fri, 24 Aug 2007 00:04:09 GMT]]></title><description><![CDATA[<p dir="auto">you are talking about gas mileage?</p>
<p dir="auto">if so, IIRC, a turbo vehicle should get better gasmileage while cruising on the highway. I am happy, i got 29mpg with the 240 driving 80 on way back from souix falls with no cruise control.</p>
]]></description><link>https://fargostreet.com/post/170810</link><guid isPermaLink="true">https://fargostreet.com/post/170810</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Fri, 24 Aug 2007 00:04:09 GMT</pubDate></item></channel></rss>
