<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Corrado down on power]]></title><description><![CDATA[<p dir="auto">My VR6 has been down on power lately, I gained some power back a month ago by getting a new o2 sensor and my gas mileage improved greatly, now my car has lost the power it had gained back, it "bogs" when I give it gas sometimes. The bogging down seems to only happen when it's hot out, but the loss of power is still present at random times, i.e. I can start my car in the morning and it's real peppy, then later that night it has no balls and the check engine light comes on. I tried to get it looked at in Bemidji but no one can hook it up to their diagnostic scanner(my car is OBD1) :icon_scratch: .I haven't got a chance to take it to Valley Imports because I'm really low on cash and I've been busy moving in. Any ideas what it could be?</p>
]]></description><link>https://fargostreet.com/topic/11614/corrado-down-on-power</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 13:29:01 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/11614.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Aug 2007 18:45:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Corrado down on power on Sat, 25 Aug 2007 08:15:15 GMT]]></title><description><![CDATA[<p dir="auto">maf cleaning is apparently a way of life for some VW owners.  search vwvortex for info.</p>
<p dir="auto">Also, does your car have the 4 pin connector?   I've got a VAG-COM we can hook up if you have the 4pin-&gt;OBD2 adapter plug.</p>
]]></description><link>https://fargostreet.com/post/171024</link><guid isPermaLink="true">https://fargostreet.com/post/171024</guid><dc:creator><![CDATA[thrash]]></dc:creator><pubDate>Sat, 25 Aug 2007 08:15:15 GMT</pubDate></item><item><title><![CDATA[Reply to Corrado down on power on Fri, 24 Aug 2007 20:34:53 GMT]]></title><description><![CDATA[<p dir="auto">I've been thinking that it's the mass air, the o2 sensor was screwed up because the car was running rich for awhile, but that was fixed prior to fixing the o2 sensor.</p>
]]></description><link>https://fargostreet.com/post/170950</link><guid isPermaLink="true">https://fargostreet.com/post/170950</guid><dc:creator><![CDATA[untitledfolder]]></dc:creator><pubDate>Fri, 24 Aug 2007 20:34:53 GMT</pubDate></item><item><title><![CDATA[Reply to Corrado down on power on Fri, 24 Aug 2007 19:57:16 GMT]]></title><description><![CDATA[<p dir="auto">Was your 02 sensor carboned up the first time? It maybe running rich and plugging that up, maybe check that out. There is quite a few quirks on the vr6, as most vw's do. Read over the Vwfixx forums <a href="http://www.vwfixx.com" rel="nofollow ugc">http://www.vwfixx.com</a> or the Vwvortex forums <a href="http://forums.vwvortex.com" rel="nofollow ugc">http://forums.vwvortex.com</a>. I have found that the VWfixx forum is quite a bit more helpful, but not visited as often.</p>
]]></description><link>https://fargostreet.com/post/170941</link><guid isPermaLink="true">https://fargostreet.com/post/170941</guid><dc:creator><![CDATA[Bookem]]></dc:creator><pubDate>Fri, 24 Aug 2007 19:57:16 GMT</pubDate></item><item><title><![CDATA[Reply to Corrado down on power on Fri, 24 Aug 2007 18:54:06 GMT]]></title><description><![CDATA[<p dir="auto">Mass air sensor?</p>
]]></description><link>https://fargostreet.com/post/170931</link><guid isPermaLink="true">https://fargostreet.com/post/170931</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Fri, 24 Aug 2007 18:54:06 GMT</pubDate></item></channel></rss>
