<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[civic clutch issue]]></title><description><![CDATA[<p dir="auto">i recently bought my 99 honda civic hatback with a b16 swap and it also has an exedy stage 2 clutch in it... but today i noticed that if crusin at 35mph in 4th gear and i give it like half or a little more gas, it just revs up from that speed but it catches fine when i shift and it only slips when its already in gear (from what i know) . The guy i bought it from said it should be fine but sumtin needs to be tuned or tightened or sumtin, So is it going out or do i need to bring it some where to get fixed?</p>
]]></description><link>https://fargostreet.com/topic/11664/civic-clutch-issue</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 13:29:26 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/11664.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Aug 2007 06:53:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to civic clutch issue on Fri, 07 Sep 2007 05:44:08 GMT]]></title><description><![CDATA[<p dir="auto">it's not hard i just hate doing it.... i suppose i contradicted myself a little bit when i said clutches are never really that hard but trannys are always a bitch.... so i can see why you'd be a little confused.... but usually when i think tranny im thinking automatic...and well i've never liked dealing with those much at all, manuals are lighter, smaller much easier to work with....it still only took me about 3 hours to replace the tranny in my civic and it wasn't hard at all.....so a manual being smaller and lighter once you resurface the flywheel put the clutch on the flywheel and put the tranny in....shouldn't really take that long, it's not hard at all.....but i still hate doing it with all that asbestos crap and the fact my old tranny had a huge hole in it so i was covered in atf all while putting the new used one in</p>
]]></description><link>https://fargostreet.com/post/173063</link><guid isPermaLink="true">https://fargostreet.com/post/173063</guid><dc:creator><![CDATA[luvmy92gmc]]></dc:creator><pubDate>Fri, 07 Sep 2007 05:44:08 GMT</pubDate></item><item><title><![CDATA[Reply to civic clutch issue on Fri, 07 Sep 2007 05:05:35 GMT]]></title><description><![CDATA[<p dir="auto">So you said that changing a clutch has never really hard, but pulling the tranny sucks, how do you change the clutch without pulling the tranny?? And yes, honda autos are very heavy, but not really any worse to swap then manuals.</p>
]]></description><link>https://fargostreet.com/post/173061</link><guid isPermaLink="true">https://fargostreet.com/post/173061</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Fri, 07 Sep 2007 05:05:35 GMT</pubDate></item><item><title><![CDATA[Reply to civic clutch issue on Fri, 07 Sep 2007 04:01:52 GMT]]></title><description><![CDATA[<p dir="auto">pulling the tranny sucks period....especially when it's an auto like the one i put in my honda hatch a few weeks ago, thing weighs about as much as a 350 turbo i'd say</p>
]]></description><link>https://fargostreet.com/post/173046</link><guid isPermaLink="true">https://fargostreet.com/post/173046</guid><dc:creator><![CDATA[luvmy92gmc]]></dc:creator><pubDate>Fri, 07 Sep 2007 04:01:52 GMT</pubDate></item><item><title><![CDATA[Reply to civic clutch issue on Fri, 07 Sep 2007 02:09:29 GMT]]></title><description><![CDATA[<p dir="auto">It was a 5 speed from the factory, and clutches do suck when the motor is in the vehicle.</p>
]]></description><link>https://fargostreet.com/post/173025</link><guid isPermaLink="true">https://fargostreet.com/post/173025</guid><dc:creator><![CDATA[D S ohM]]></dc:creator><pubDate>Fri, 07 Sep 2007 02:09:29 GMT</pubDate></item><item><title><![CDATA[Reply to civic clutch issue on Fri, 07 Sep 2007 01:34:01 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">inspector01;183652 wrote:<br />
Why would it being converted to manual cause the clutch to slip?? And clutches really aren't that cheap, and they are kind of a pain in the ass to install with the motor in the car.</p>
<p dir="auto">converting a car would have nothing to do with the clutch slippage but you obviously need a clutch pedal for a manual vehicle....and I was replying to the guy that said the pedal might need adjusting because whoever put in the pedal assembly might not have adjusted it.....and i also have a 2 post lift in my garage so it's never really been that hard to do clutches in anything</p>
]]></description><link>https://fargostreet.com/post/173018</link><guid isPermaLink="true">https://fargostreet.com/post/173018</guid><dc:creator><![CDATA[luvmy92gmc]]></dc:creator><pubDate>Fri, 07 Sep 2007 01:34:01 GMT</pubDate></item><item><title><![CDATA[Reply to civic clutch issue on Thu, 06 Sep 2007 22:36:32 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">luvmy92gmc;183594 wrote:<br />
it's probably clutch slippage unless the car was an automatic to start with... usually the pedal play doesn't get tampered with much, clutches are cheap anyways</p>
<p dir="auto">Why would it being converted to manual cause the clutch to slip?? And clutches really aren't that cheap, and they are kind of a pain in the ass to install with the motor in the car.</p>
]]></description><link>https://fargostreet.com/post/172989</link><guid isPermaLink="true">https://fargostreet.com/post/172989</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Thu, 06 Sep 2007 22:36:32 GMT</pubDate></item><item><title><![CDATA[Reply to civic clutch issue on Thu, 06 Sep 2007 21:35:22 GMT]]></title><description><![CDATA[<p dir="auto">Brandon it's one of two things.  Either the clutch is shot or the clutch is shot.  Theres also the possible the previous owner put it on the wrong way...</p>
]]></description><link>https://fargostreet.com/post/172975</link><guid isPermaLink="true">https://fargostreet.com/post/172975</guid><dc:creator><![CDATA[Bassplayer]]></dc:creator><pubDate>Thu, 06 Sep 2007 21:35:22 GMT</pubDate></item><item><title><![CDATA[Reply to civic clutch issue on Thu, 06 Sep 2007 18:33:22 GMT]]></title><description><![CDATA[<p dir="auto">it's probably clutch slippage unless the car was an automatic to start with... usually the pedal play doesn't get tampered with much, clutches are cheap anyways</p>
]]></description><link>https://fargostreet.com/post/172931</link><guid isPermaLink="true">https://fargostreet.com/post/172931</guid><dc:creator><![CDATA[luvmy92gmc]]></dc:creator><pubDate>Thu, 06 Sep 2007 18:33:22 GMT</pubDate></item><item><title><![CDATA[Reply to civic clutch issue on Thu, 30 Aug 2007 12:46:44 GMT]]></title><description><![CDATA[<p dir="auto">the only thing you can adjust on a hyrdraulic clutch is pedal play. this might help him too tho.</p>
]]></description><link>https://fargostreet.com/post/171807</link><guid isPermaLink="true">https://fargostreet.com/post/171807</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Thu, 30 Aug 2007 12:46:44 GMT</pubDate></item><item><title><![CDATA[Reply to civic clutch issue on Thu, 30 Aug 2007 03:28:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">BuiltorDie;182392 wrote:<br />
It's a hydro clutch so you can't really adjust it try bleeding it for sure.</p>
<p dir="auto">If you need a new one installed shoot me a PM, I will do it pretty cheap.</p>
<p dir="auto">uh...yes you can..</p>
]]></description><link>https://fargostreet.com/post/171754</link><guid isPermaLink="true">https://fargostreet.com/post/171754</guid><dc:creator><![CDATA[DelSlow]]></dc:creator><pubDate>Thu, 30 Aug 2007 03:28:12 GMT</pubDate></item><item><title><![CDATA[Reply to civic clutch issue on Thu, 30 Aug 2007 03:21:16 GMT]]></title><description><![CDATA[<p dir="auto">It's a hydro clutch so you can't really adjust it try bleeding it for sure.</p>
]]></description><link>https://fargostreet.com/post/171753</link><guid isPermaLink="true">https://fargostreet.com/post/171753</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Thu, 30 Aug 2007 03:21:16 GMT</pubDate></item><item><title><![CDATA[Reply to civic clutch issue on Thu, 30 Aug 2007 03:07:30 GMT]]></title><description><![CDATA[<p dir="auto">bleed the clutch/slave...if that doesn't work then you prolly need a new clutch...if you dont know how to do it you can go ahead and pm your number and we can get together and bleed it...it takes like 5 min...lmk</p>
]]></description><link>https://fargostreet.com/post/171751</link><guid isPermaLink="true">https://fargostreet.com/post/171751</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Thu, 30 Aug 2007 03:07:30 GMT</pubDate></item><item><title><![CDATA[Reply to civic clutch issue on Thu, 30 Aug 2007 01:30:47 GMT]]></title><description><![CDATA[<p dir="auto">tintmaster's will help ya</p>
]]></description><link>https://fargostreet.com/post/171739</link><guid isPermaLink="true">https://fargostreet.com/post/171739</guid><dc:creator><![CDATA[blindsp1]]></dc:creator><pubDate>Thu, 30 Aug 2007 01:30:47 GMT</pubDate></item></channel></rss>
