<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rim repair?]]></title><description><![CDATA[<p dir="auto">Were in fargo(or close) can i get a wheel repaired, or buy a single racing hart c4, single peice, 17x7????</p>
]]></description><link>https://fargostreet.com/topic/11682/rim-repair</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 17:50:05 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/11682.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Aug 2007 15:38:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rim repair? on Tue, 11 Sep 2007 21:18:21 GMT]]></title><description><![CDATA[<p dir="auto">NIce man...im like 99% sure i bought those wheels from you with that POS Saturn...am i right. well anyway. thnx. does ur brother still have that 240???</p>
]]></description><link>https://fargostreet.com/post/173932</link><guid isPermaLink="true">https://fargostreet.com/post/173932</guid><dc:creator><![CDATA[CRX_Civic]]></dc:creator><pubDate>Tue, 11 Sep 2007 21:18:21 GMT</pubDate></item><item><title><![CDATA[Reply to Rim repair? on Sat, 01 Sep 2007 02:35:37 GMT]]></title><description><![CDATA[<p dir="auto">I didn't see any noticeable excess of wear on that tire and if there was any vibration I didn't feel any of it while driving. I took the car up 90+ mph and it ran good. I actually sold the rims to guy in fargo, he had a newer prelude at the time, never heard anything back from him so I'm guessing they where good to go on his car as well. Plus, the racing harts I have now have been repaired, DAMN RAILROAD SPIKES!, it went in the tire and punched whole in my rim. I made a patch out of heavier gauge aluminum and had it welded over the hole, it had pin hole leaks though so I sealed the outside with a layer of epoxy and it did the trick.<br />
Although, if I wouldn't have been in such a damn hurry to get it back on my car I would've taken the tire off and sealed it from the inside instead, the air pressure from the inside eventually made the expoxy on the ouside come loose and leak but it took a long time for that to happen, well over a year.</p>
]]></description><link>https://fargostreet.com/post/172008</link><guid isPermaLink="true">https://fargostreet.com/post/172008</guid><dc:creator><![CDATA[ichibankilla]]></dc:creator><pubDate>Sat, 01 Sep 2007 02:35:37 GMT</pubDate></item><item><title><![CDATA[Reply to Rim repair? on Sat, 01 Sep 2007 01:57:07 GMT]]></title><description><![CDATA[<p dir="auto">^ How was the tire wear on it, do u know if there was a high road force?</p>
]]></description><link>https://fargostreet.com/post/172004</link><guid isPermaLink="true">https://fargostreet.com/post/172004</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Sat, 01 Sep 2007 01:57:07 GMT</pubDate></item><item><title><![CDATA[Reply to Rim repair? on Fri, 31 Aug 2007 21:53:08 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">CRX_Civic;182459 wrote:<br />
<p dir="auto">I believe all racing hart rims are forged. Anyways, I used to have a set of one piece C4s and I hit a rather large "unmarked" bump on the highway and it bent the inside lip, outside lip(not bad enough to notice) and cracked the middle section about 8 inches. A friend of mine a sledgehammer and good solid 2x4(for a striking surface) pretty much fixed the inside bend and I had the crack welded with an aluminum welder. After it was fixed I took it to a tire shop to have a new tire put on and explained to them the situation and told them to just get it at close to balanced as they could. After it was back on the car I couldn't feel any noticeable imbalance while driving even at highway speed and beyond, I put the rim on the back instead of the front in case a problem should arise but it never did. Also, as far as getting a new rims, I searched around google a bit and it seems as though the C4 is discontinued with only a few sets of multi-piece C4s still floating around.</p>
]]></description><link>https://fargostreet.com/post/171980</link><guid isPermaLink="true">https://fargostreet.com/post/171980</guid><dc:creator><![CDATA[ichibankilla]]></dc:creator><pubDate>Fri, 31 Aug 2007 21:53:08 GMT</pubDate></item><item><title><![CDATA[Reply to Rim repair? on Fri, 31 Aug 2007 17:45:01 GMT]]></title><description><![CDATA[<p dir="auto">Ebay...</p>
]]></description><link>https://fargostreet.com/post/171953</link><guid isPermaLink="true">https://fargostreet.com/post/171953</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Fri, 31 Aug 2007 17:45:01 GMT</pubDate></item><item><title><![CDATA[Reply to Rim repair? on Fri, 31 Aug 2007 16:12:55 GMT]]></title><description><![CDATA[<p dir="auto">Yea, i dont think im gonna get it repaired...anyone have a clue were i could buy a single wheel....? is that even possible???</p>
]]></description><link>https://fargostreet.com/post/171941</link><guid isPermaLink="true">https://fargostreet.com/post/171941</guid><dc:creator><![CDATA[CRX_Civic]]></dc:creator><pubDate>Fri, 31 Aug 2007 16:12:55 GMT</pubDate></item><item><title><![CDATA[Reply to Rim repair? on Thu, 30 Aug 2007 23:03:55 GMT]]></title><description><![CDATA[<p dir="auto">Thing is if u repair it (if it's cracked or something) u'd think it'd be a bitch to balance and get it with little road force on the tires, beings there would be a heavy spot in the wheel.</p>
]]></description><link>https://fargostreet.com/post/171865</link><guid isPermaLink="true">https://fargostreet.com/post/171865</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Thu, 30 Aug 2007 23:03:55 GMT</pubDate></item><item><title><![CDATA[Reply to Rim repair? on Thu, 30 Aug 2007 20:58:27 GMT]]></title><description><![CDATA[<p dir="auto">C.A.R.S. repairs rims intown</p>
<p dir="auto">tell him Kelly from Lunde's sent ya</p>
<p dir="auto">Jason 729-1291</p>
]]></description><link>https://fargostreet.com/post/171852</link><guid isPermaLink="true">https://fargostreet.com/post/171852</guid><dc:creator><![CDATA[Raider]]></dc:creator><pubDate>Thu, 30 Aug 2007 20:58:27 GMT</pubDate></item><item><title><![CDATA[Reply to Rim repair? on Thu, 30 Aug 2007 19:24:11 GMT]]></title><description><![CDATA[<p dir="auto">racinghart is probably a forged wheel</p>
]]></description><link>https://fargostreet.com/post/171843</link><guid isPermaLink="true">https://fargostreet.com/post/171843</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Thu, 30 Aug 2007 19:24:11 GMT</pubDate></item><item><title><![CDATA[Reply to Rim repair? on Thu, 30 Aug 2007 17:36:13 GMT]]></title><description><![CDATA[<p dir="auto">If it's forged I'm not sure if they can do much with. But I could be wrong</p>
]]></description><link>https://fargostreet.com/post/171830</link><guid isPermaLink="true">https://fargostreet.com/post/171830</guid><dc:creator><![CDATA[GhettoFabulousCRX]]></dc:creator><pubDate>Thu, 30 Aug 2007 17:36:13 GMT</pubDate></item><item><title><![CDATA[Reply to Rim repair? on Thu, 30 Aug 2007 16:53:36 GMT]]></title><description><![CDATA[<p dir="auto">there is a place in the cities that repairs wheels. i cant remember the name of the place at the moment though.</p>
]]></description><link>https://fargostreet.com/post/171827</link><guid isPermaLink="true">https://fargostreet.com/post/171827</guid><dc:creator><![CDATA[D S ohM]]></dc:creator><pubDate>Thu, 30 Aug 2007 16:53:36 GMT</pubDate></item><item><title><![CDATA[Reply to Rim repair? on Thu, 30 Aug 2007 16:17:53 GMT]]></title><description><![CDATA[<p dir="auto">What is wrong with it? Most of the time i'd say you'd be best off getting a new one.</p>
]]></description><link>https://fargostreet.com/post/171821</link><guid isPermaLink="true">https://fargostreet.com/post/171821</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Thu, 30 Aug 2007 16:17:53 GMT</pubDate></item></channel></rss>
