<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[clutch damper???????]]></title><description><![CDATA[<p dir="auto">on my dsm there is a clutch damper in line between my master and my slave. I could be wrong but just from general knowledge i would want to believe it reduces jerkyness and dampens the clutch engagement. i don't know though. but what i want to know is does it have to be there???? will it send to much pressure to the slave without it there and blow seals? I would like to run a straight hose from master-slave to eliminate some variables but i don't like taking parts off when they are suppose to be there. has anyone ever took theirs off?? I couldn't find any info on a google search but i didn't spent to much time on it. please give me your input.<br />
thanks</p>
]]></description><link>https://fargostreet.com/topic/11794/clutch-damper</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 10:08:05 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/11794.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Sep 2007 02:09:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to clutch damper??????? on Mon, 10 Sep 2007 01:41:52 GMT]]></title><description><![CDATA[<p dir="auto">thanks</p>
]]></description><link>https://fargostreet.com/post/173447</link><guid isPermaLink="true">https://fargostreet.com/post/173447</guid><dc:creator><![CDATA[black2g]]></dc:creator><pubDate>Mon, 10 Sep 2007 01:41:52 GMT</pubDate></item><item><title><![CDATA[Reply to clutch damper??????? on Sun, 09 Sep 2007 23:11:07 GMT]]></title><description><![CDATA[<p dir="auto">Just take that whole thing out, its unnecessary.  There's also a clutch fluid restricter in the slave cylinder that you can take out, doing those will make the clutch pedal feel better and also engage/disengage faster.  <a href="http://www.vfaq.com/index-main.html" rel="nofollow ugc">http://www.vfaq.com/index-main.html</a> is your friend, click on drivetrain and you'll find it there.</p>
]]></description><link>https://fargostreet.com/post/173432</link><guid isPermaLink="true">https://fargostreet.com/post/173432</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Sun, 09 Sep 2007 23:11:07 GMT</pubDate></item><item><title><![CDATA[Reply to clutch damper??????? on Sun, 09 Sep 2007 15:22:26 GMT]]></title><description><![CDATA[<p dir="auto">Check <a href="www.dsmtalk.com">www.dsmtalk.com</a> or <a href="www.dsmtuners.com">www.dsmtuners.com</a> and go under the help! tech sections</p>
]]></description><link>https://fargostreet.com/post/173363</link><guid isPermaLink="true">https://fargostreet.com/post/173363</guid><dc:creator><![CDATA[D S ohM]]></dc:creator><pubDate>Sun, 09 Sep 2007 15:22:26 GMT</pubDate></item></channel></rss>
