<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[cavi electrical demon]]></title><description><![CDATA[<p dir="auto">looking for anythoughts on this or if anyone has delt with it.</p>
<p dir="auto">My friend has like a 99 cavi 4 banger, he is having electrical issues that make it seem like the alternator is going out, but he had that tested and it was good.   he did cross the points on the alternator with a wrench or something and made it spark.</p>
<p dir="auto">symptoms- dimm dashlights, dim head lights, low power for everything, dies, I think he said it will run if he jumps it,  and all the dash lights freak out when it's running.</p>
<p dir="auto">I havn't had a chance to look at it and he's not a big car guy, but I wanted to see what you guys thought.   he's wondering if it will be worth fixing.</p>
]]></description><link>https://fargostreet.com/topic/11825/cavi-electrical-demon</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:59:37 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/11825.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Sep 2007 04:21:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to cavi electrical demon on Tue, 18 Sep 2007 02:01:51 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">lord_deastofact;184931 wrote:<br />
turned out to just be a bad wire.  he took it to a shop before I could look at it.   thanks guys!</p>
<p dir="auto">just guessing the fusible link on the power wire to the starter from the altenator? thats where I would have started.</p>
]]></description><link>https://fargostreet.com/post/175238</link><guid isPermaLink="true">https://fargostreet.com/post/175238</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Tue, 18 Sep 2007 02:01:51 GMT</pubDate></item><item><title><![CDATA[Reply to cavi electrical demon on Thu, 13 Sep 2007 02:08:16 GMT]]></title><description><![CDATA[<p dir="auto">turned out to just be a bad wire.  he took it to a shop before I could look at it.   thanks guys!</p>
]]></description><link>https://fargostreet.com/post/174252</link><guid isPermaLink="true">https://fargostreet.com/post/174252</guid><dc:creator><![CDATA[lord_deastofact]]></dc:creator><pubDate>Thu, 13 Sep 2007 02:08:16 GMT</pubDate></item><item><title><![CDATA[Reply to cavi electrical demon on Wed, 12 Sep 2007 05:14:36 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Cura86;184741 wrote:<br />
Maybe the Voltage Reg????</p>
<p dir="auto">Which is <strong>IN</strong> the alternator.</p>
]]></description><link>https://fargostreet.com/post/174063</link><guid isPermaLink="true">https://fargostreet.com/post/174063</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Wed, 12 Sep 2007 05:14:36 GMT</pubDate></item><item><title><![CDATA[Reply to cavi electrical demon on Wed, 12 Sep 2007 05:04:12 GMT]]></title><description><![CDATA[<p dir="auto">Maybe the Voltage Reg????</p>
]]></description><link>https://fargostreet.com/post/174062</link><guid isPermaLink="true">https://fargostreet.com/post/174062</guid><dc:creator><![CDATA[Cura86]]></dc:creator><pubDate>Wed, 12 Sep 2007 05:04:12 GMT</pubDate></item><item><title><![CDATA[Reply to cavi electrical demon on Wed, 12 Sep 2007 04:34:51 GMT]]></title><description><![CDATA[<p dir="auto">k, good to hear your thoughts on it, most of you are thinking about the same as me, I wanted to get some opinions before I really looked at it, to see if I can save him some money.</p>
]]></description><link>https://fargostreet.com/post/174061</link><guid isPermaLink="true">https://fargostreet.com/post/174061</guid><dc:creator><![CDATA[lord_deastofact]]></dc:creator><pubDate>Wed, 12 Sep 2007 04:34:51 GMT</pubDate></item><item><title><![CDATA[Reply to cavi electrical demon on Tue, 11 Sep 2007 05:31:31 GMT]]></title><description><![CDATA[<p dir="auto">If the alternator tests good check your ground cable conections and clean them up and make sure all your battery cables are in good shape an there's no corrosion everywhere...I had a prelude one time that had a new alternator in it, turns out it was just the ground cable was corroded where it connects to the frame...</p>
]]></description><link>https://fargostreet.com/post/173824</link><guid isPermaLink="true">https://fargostreet.com/post/173824</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Tue, 11 Sep 2007 05:31:31 GMT</pubDate></item><item><title><![CDATA[Reply to cavi electrical demon on Tue, 11 Sep 2007 05:31:13 GMT]]></title><description><![CDATA[<p dir="auto">Bah! Diggin too far into it. I'll lay $ on the alternator.</p>
]]></description><link>https://fargostreet.com/post/173823</link><guid isPermaLink="true">https://fargostreet.com/post/173823</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Tue, 11 Sep 2007 05:31:13 GMT</pubDate></item><item><title><![CDATA[Reply to cavi electrical demon on Tue, 11 Sep 2007 05:29:47 GMT]]></title><description><![CDATA[<p dir="auto">I'd check your main grounding points to see if any are loose/corroded</p>
]]></description><link>https://fargostreet.com/post/173822</link><guid isPermaLink="true">https://fargostreet.com/post/173822</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 11 Sep 2007 05:29:47 GMT</pubDate></item><item><title><![CDATA[Reply to cavi electrical demon on Tue, 11 Sep 2007 05:23:42 GMT]]></title><description><![CDATA[<p dir="auto">Unlike most import vehicles, Gm doesn't have a "main" fuse per say. Nor does it have an alternator fuse. It may be the battery. Do this, jump start it and disconnect the negative terminal. If it dies, replace your alternator. If not, replace the battery.</p>
]]></description><link>https://fargostreet.com/post/173820</link><guid isPermaLink="true">https://fargostreet.com/post/173820</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Tue, 11 Sep 2007 05:23:42 GMT</pubDate></item><item><title><![CDATA[Reply to cavi electrical demon on Tue, 11 Sep 2007 05:10:52 GMT]]></title><description><![CDATA[<p dir="auto">I did that once and it blew the main fuse under the hood(on mine at least), it may have done the same but not burned quite all the way through, fuses can do that from time to time. When in doubt, check the fuses first.</p>
]]></description><link>https://fargostreet.com/post/173812</link><guid isPermaLink="true">https://fargostreet.com/post/173812</guid><dc:creator><![CDATA[ichibankilla]]></dc:creator><pubDate>Tue, 11 Sep 2007 05:10:52 GMT</pubDate></item><item><title><![CDATA[Reply to cavi electrical demon on Tue, 11 Sep 2007 04:30:05 GMT]]></title><description><![CDATA[<p dir="auto">It sounds like alternator to me. It will run when jumpstarted but will die shortly after because the alternator is not charging to recharge the battery hence the car runs off of the battery and if the battery isnt fully charged, it wont last long. And thats why all of the stuff on the instrument cluster is wacky.</p>
]]></description><link>https://fargostreet.com/post/173795</link><guid isPermaLink="true">https://fargostreet.com/post/173795</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Tue, 11 Sep 2007 04:30:05 GMT</pubDate></item></channel></rss>
