<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Disconnecting the &amp;quot;rev limiter&amp;quot;]]></title><description><![CDATA[<p dir="auto">Would it be a good idea for an automatic? If i did disconnect the governor would it still shift or would the RPM's keep getting higher? I want to disconnect my governor but I'm afraid my car wouldn't shift "seeing as how it's the "rev limiter" " so i guess my main question is "Would my car still shift after disconnecting the rev limiter"?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://fargostreet.com/topic/11909/disconnecting-the-quot-rev-limiter-quot</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 10:34:31 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/11909.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 Sep 2007 20:25:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Thu, 20 Sep 2007 03:06:24 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">wannabe;186189 wrote:<br />
if you want a real z car, just buy a 350, done...</p>
<p dir="auto">I think you meant 300zx not 350z</p>
]]></description><link>https://fargostreet.com/post/175581</link><guid isPermaLink="true">https://fargostreet.com/post/175581</guid><dc:creator><![CDATA[z31]]></dc:creator><pubDate>Thu, 20 Sep 2007 03:06:24 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 22:03:19 GMT]]></title><description><![CDATA[<p dir="auto">send him a pm, should have his at sabin soon, youll have to check it out.<br />
Gary</p>
]]></description><link>https://fargostreet.com/post/175538</link><guid isPermaLink="true">https://fargostreet.com/post/175538</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Wed, 19 Sep 2007 22:03:19 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 19:47:24 GMT]]></title><description><![CDATA[<p dir="auto">So i should let Jason build my Z engine?....and how much would he want to do that for me?</p>
]]></description><link>https://fargostreet.com/post/175516</link><guid isPermaLink="true">https://fargostreet.com/post/175516</guid><dc:creator><![CDATA[JN210]]></dc:creator><pubDate>Wed, 19 Sep 2007 19:47:24 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 18:53:19 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Overrated waste of $$$</p>
<p dir="auto">Oh and before you even say it, Stock GT vs Stock 350 is a drivers race, and there is a nice price difference between the two.</p>
]]></description><link>https://fargostreet.com/post/175510</link><guid isPermaLink="true">https://fargostreet.com/post/175510</guid><dc:creator><![CDATA[StangerBanger96]]></dc:creator><pubDate>Wed, 19 Sep 2007 18:53:19 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 18:51:14 GMT]]></title><description><![CDATA[<p dir="auto">if you want a real z car, just buy a 350, done...</p>
]]></description><link>https://fargostreet.com/post/175509</link><guid isPermaLink="true">https://fargostreet.com/post/175509</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 19 Sep 2007 18:51:14 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 18:43:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Zero;186172 wrote:<br />
when they say "brake" they mean break, and what they are talking about is probably the torque converter.  they can explode at high rpms, at least from what i've heard.</p>
<p dir="auto">You should do other mods first, like different intake manifold, full exhaust, make the stock setup breath better, you'd notice more gains anyway.</p>
<p dir="auto">Umm, the torque converter would be the least of his worries if he removed the limiter and felt he could safely hit higher than stock RPM.  Valves could start floating, Piston to Valve contact could occur, anything in the heads could start breaking due to subjection to stresses it wasn't intended to see.  Anything involving rotating masses would be subject to failure if he wasn't running an engine built to handle the higher RPMs.</p>
]]></description><link>https://fargostreet.com/post/175508</link><guid isPermaLink="true">https://fargostreet.com/post/175508</guid><dc:creator><![CDATA[StangerBanger96]]></dc:creator><pubDate>Wed, 19 Sep 2007 18:43:11 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 18:33:52 GMT]]></title><description><![CDATA[<p dir="auto">my suggestion: Take out the engine/trans, and give it to jason with a pile of cash, we'll get it in line<br />
Gary</p>
]]></description><link>https://fargostreet.com/post/175507</link><guid isPermaLink="true">https://fargostreet.com/post/175507</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Wed, 19 Sep 2007 18:33:52 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 17:13:01 GMT]]></title><description><![CDATA[<p dir="auto">Well my main reasoning for doing it before was to see if i were to get a "power gain" well now i see that the idiot who disconnected his was wrong, i think i will leave it alone. I am however going to build up my VG and turn it into a HP beast, im going to turbo it and while the engine is out of the car im getting a 5-speed trans. (if i can find one cheap) and I'm also going to build up my engine while i have it sitting on the engine rack.</p>
]]></description><link>https://fargostreet.com/post/175501</link><guid isPermaLink="true">https://fargostreet.com/post/175501</guid><dc:creator><![CDATA[JN210]]></dc:creator><pubDate>Wed, 19 Sep 2007 17:13:01 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 15:45:49 GMT]]></title><description><![CDATA[<p dir="auto">when they say "brake" they mean break, and what they are talking about is probably the torque converter.  they can explode at high rpms, at least from what i've heard.</p>
]]></description><link>https://fargostreet.com/post/175492</link><guid isPermaLink="true">https://fargostreet.com/post/175492</guid><dc:creator><![CDATA[Zero]]></dc:creator><pubDate>Wed, 19 Sep 2007 15:45:49 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 14:39:22 GMT]]></title><description><![CDATA[<p dir="auto">You can do it; but, you won't make power up there, and things are probably going to brake.</p>
]]></description><link>https://fargostreet.com/post/175484</link><guid isPermaLink="true">https://fargostreet.com/post/175484</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Wed, 19 Sep 2007 14:39:22 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 14:38:25 GMT]]></title><description><![CDATA[<p dir="auto">why would you WANT to do it though, what was your main reasoning for doing it?</p>
]]></description><link>https://fargostreet.com/post/175483</link><guid isPermaLink="true">https://fargostreet.com/post/175483</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 19 Sep 2007 14:38:25 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 13:28:35 GMT]]></title><description><![CDATA[<p dir="auto">Well, I just wanted to see if it was a good idea or not, guess it's not so great. I read off this one forum where this guy took his out, And he showed how, I wasn't really to keen on the idea so i wanted to know what you guys thought.</p>
]]></description><link>https://fargostreet.com/post/175476</link><guid isPermaLink="true">https://fargostreet.com/post/175476</guid><dc:creator><![CDATA[JN210]]></dc:creator><pubDate>Wed, 19 Sep 2007 13:28:35 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 02:44:16 GMT]]></title><description><![CDATA[<p dir="auto">Here is the stock dyno<br />
<a href="http://z31.com/faqu/k&amp;n.cone.filter.dyno.stock.na.jpg" rel="nofollow ugc">http://z31.com/faqu/k&amp;n.cone.filter.dyno.stock.na.jpg</a><br />
Disabling the fuel cut (rev limiter) is going to what?</p>
]]></description><link>https://fargostreet.com/post/175427</link><guid isPermaLink="true">https://fargostreet.com/post/175427</guid><dc:creator><![CDATA[z31]]></dc:creator><pubDate>Wed, 19 Sep 2007 02:44:16 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 02:31:38 GMT]]></title><description><![CDATA[<p dir="auto">yeah, not a cool thing to do.  with your stock cams, your car stops making ANY power above 5600.  Jason had big ass cams in his with the N/A auto, and it still started falling off over 6500.  Waste of time, and i wont tell you how to do it either.<br />
Gary</p>
]]></description><link>https://fargostreet.com/post/175426</link><guid isPermaLink="true">https://fargostreet.com/post/175426</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Wed, 19 Sep 2007 02:31:38 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Wed, 19 Sep 2007 02:25:54 GMT]]></title><description><![CDATA[<p dir="auto">In many cars that I've come across have rev limiter set to maximize factory settings.</p>
<p dir="auto">Using my swap as an example:</p>
<p dir="auto">makes 240 hp and trq on an N/A 6.  redlines @ 6200.  Only available in an automatic, and uses 2 indiviual intake manifolds connected by an Iris valve that can open for "power" mode.  Has serious breathing and exhaust issues.</p>
<p dir="auto">If i freeze the iris valve open, remove the 6 miles of intake and put on a high flow filter, then run good exhaust, the engine can make power up to 7500 RPM.  The reason they limited the reving was because of a shitty exhaust/clearing stroke on the cams plus the poorly flowing exhaust found on all subarus.</p>
<p dir="auto">I'm sure other cars have similar setups...</p>
<p dir="auto">do the research, what are the limitations and why? check, check, data log, then do...</p>
]]></description><link>https://fargostreet.com/post/175423</link><guid isPermaLink="true">https://fargostreet.com/post/175423</guid><dc:creator><![CDATA[Colin]]></dc:creator><pubDate>Wed, 19 Sep 2007 02:25:54 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Tue, 18 Sep 2007 23:31:05 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">JN210;186036 wrote:<br />
<p dir="auto">Thanks The answer to your question is yes,  the transmission will work the same, and No I wont tell you how to do it.<br />
Like every one else said, why would you want to raise the red line?  :icon_scratch:</p>
]]></description><link>https://fargostreet.com/post/175400</link><guid isPermaLink="true">https://fargostreet.com/post/175400</guid><dc:creator><![CDATA[z31]]></dc:creator><pubDate>Tue, 18 Sep 2007 23:31:05 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Tue, 18 Sep 2007 23:06:32 GMT]]></title><description><![CDATA[<p dir="auto">why the hell would you want to do this anyways?</p>
]]></description><link>https://fargostreet.com/post/175395</link><guid isPermaLink="true">https://fargostreet.com/post/175395</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Tue, 18 Sep 2007 23:06:32 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Tue, 18 Sep 2007 22:54:07 GMT]]></title><description><![CDATA[<p dir="auto">No, spray nitrous into the exhaust. and then shoot the bottle from a rocket riding away.</p>
]]></description><link>https://fargostreet.com/post/175392</link><guid isPermaLink="true">https://fargostreet.com/post/175392</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Tue, 18 Sep 2007 22:54:07 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Tue, 18 Sep 2007 22:44:29 GMT]]></title><description><![CDATA[<p dir="auto">n00b</p>
]]></description><link>https://fargostreet.com/post/175386</link><guid isPermaLink="true">https://fargostreet.com/post/175386</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Tue, 18 Sep 2007 22:44:29 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Tue, 18 Sep 2007 22:19:35 GMT]]></title><description><![CDATA[<p dir="auto">^^^ yeah! and spray ether in the intake at the same time! ooo the horsepowa!</p>
]]></description><link>https://fargostreet.com/post/175381</link><guid isPermaLink="true">https://fargostreet.com/post/175381</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Tue, 18 Sep 2007 22:19:35 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Tue, 18 Sep 2007 22:12:36 GMT]]></title><description><![CDATA[<p dir="auto">^^ They don't know what they're talking about. Get rid of it. You don't need it.</p>
<p dir="auto">Once you get it taken care of, set up a video camera and stomp it down in neutral.</p>
]]></description><link>https://fargostreet.com/post/175377</link><guid isPermaLink="true">https://fargostreet.com/post/175377</guid><dc:creator><![CDATA[amicheze]]></dc:creator><pubDate>Tue, 18 Sep 2007 22:12:36 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Tue, 18 Sep 2007 22:12:08 GMT]]></title><description><![CDATA[<p dir="auto">ya rev limiters are there for a reason. thats how  parts get broken.  and more then likely you will just loose power up top, unless you have alot of mods.</p>
<p dir="auto">if you are talking about your speed limiter.... why would you want to?</p>
]]></description><link>https://fargostreet.com/post/175376</link><guid isPermaLink="true">https://fargostreet.com/post/175376</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Tue, 18 Sep 2007 22:12:08 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Tue, 18 Sep 2007 22:01:22 GMT]]></title><description><![CDATA[<p dir="auto">are you doing this to "top out" higher or rev higher? either way bad idea. you wont make any power reving higher</p>
]]></description><link>https://fargostreet.com/post/175373</link><guid isPermaLink="true">https://fargostreet.com/post/175373</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Tue, 18 Sep 2007 22:01:22 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnecting the &amp;quot;rev limiter&amp;quot; on Tue, 18 Sep 2007 21:07:06 GMT]]></title><description><![CDATA[<p dir="auto">Unless you have a built engine and/or standalone, I don't see why you would want to.</p>
]]></description><link>https://fargostreet.com/post/175368</link><guid isPermaLink="true">https://fargostreet.com/post/175368</guid><dc:creator><![CDATA[3_Series]]></dc:creator><pubDate>Tue, 18 Sep 2007 21:07:06 GMT</pubDate></item></channel></rss>
