<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[cutting]]></title><description><![CDATA[<p dir="auto">is there an easy way to cut a car out of a picture, or cut the wheels out?  Or is the only way the lasso tool?</p>
]]></description><link>https://fargostreet.com/topic/1210/cutting</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 01:11:43 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/1210.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 07 Jan 2005 15:14:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to cutting on Fri, 07 Jan 2005 22:51:17 GMT]]></title><description><![CDATA[<p dir="auto">easiest way to do is to put them into different layers, using the polygonimal(sp?) lasso. copy or cut it, then screw around with it</p>
]]></description><link>https://fargostreet.com/post/22277</link><guid isPermaLink="true">https://fargostreet.com/post/22277</guid><dc:creator><![CDATA[STiSchucky]]></dc:creator><pubDate>Fri, 07 Jan 2005 22:51:17 GMT</pubDate></item><item><title><![CDATA[Reply to cutting on Fri, 07 Jan 2005 22:26:27 GMT]]></title><description><![CDATA[<p dir="auto">SOmething with color gradients. YOu can set it so it only takes a color from a range you set. Hard to explain...</p>
]]></description><link>https://fargostreet.com/post/22273</link><guid isPermaLink="true">https://fargostreet.com/post/22273</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Fri, 07 Jan 2005 22:26:27 GMT</pubDate></item><item><title><![CDATA[Reply to cutting on Fri, 07 Jan 2005 21:55:07 GMT]]></title><description><![CDATA[<p dir="auto">i thought you were cutting yourself or something lol....i'm sure there are other ways but i just use the lasso tool.</p>
]]></description><link>https://fargostreet.com/post/22262</link><guid isPermaLink="true">https://fargostreet.com/post/22262</guid><dc:creator><![CDATA[Pony_Racer]]></dc:creator><pubDate>Fri, 07 Jan 2005 21:55:07 GMT</pubDate></item><item><title><![CDATA[Reply to cutting on Fri, 07 Jan 2005 21:53:35 GMT]]></title><description><![CDATA[<p dir="auto">I will chime in on this later.</p>
]]></description><link>https://fargostreet.com/post/22261</link><guid isPermaLink="true">https://fargostreet.com/post/22261</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Fri, 07 Jan 2005 21:53:35 GMT</pubDate></item></channel></rss>
