<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wheels, tires, W&#x2F;B 02, honda, snowmobile parts]]></title><description><![CDATA[<p dir="auto">Im open to offers on most stuff, but some stuff im pretty firm on.</p>
<p dir="auto">PLX R-500 Wideband 02 sensor w/ brand new EGT sensor(used about 3-4k miles)- $425<br />
16” rage rims, painted black with shiny red lip w/ yokohoma parada spec 2s- $400<br />
17” Rays Gramlight 57c’s gold with almost new tires- $1200<br />
17” Ventus tires-(like new)  2-235 and 2-215 series (I can find out sidewall size, these run about $175 a piece new)- $200 per pair<br />
Ebay universal fuel pressure regulator</p>
<p dir="auto">Y8 head parts<br />
Z6 head- dissassembled<br />
D16Y8 bottom end - Dissassembled, no rods, pistons, or oil pan.<br />
Civic EX/SI trannys-<br />
Integra Front and Rear stock Sway bars- work on civics- $50 pr.<br />
Y8 Dizzy-complete (I have a conversion harness so this will work on obd-1 also)- $80<br />
Obd-2 D-series alternator-1000 miles- $40 (can easily be made to work on obd-1)<br />
EG tailgate- good shape- $50<br />
Del Sol windows and window motors<br />
Del Sol door panels- good shape- $30 Pair<br />
14” Del Sol Si wheels- fat 5 style- (2 with good tires- 2 completely shot)- $120<br />
EG p/s mirror block off plate- $10<br />
Misc mounts, p/s pumps, mirrors, interior pieces (quite a bit of EK stuff), IM's, Injectors, fuel pumps, wiring plugs, most anything you could want.<br />
OEM DC teg wing- $10<br />
EK hatch oem wing- $15<br />
EG hatch oem wing- $15<br />
EG hatch rear window- $30<br />
60 mm B-series TB- $50 (upgrade d-series)</p>
<p dir="auto">Snowmobile parts- probably long shot but maybe-<br />
2004-newer arctic cat sno pro side panels-( probably 5 sets, price depends on condition but cheap)<br />
2004- new arctic cat sno pro hoods- one green one painted white-<br />
Firecat headlights<br />
SLP powder pro skis (arctic cat mounts)- $275<br />
Arctic Cat sno pro skis(fit others)- $125<br />
1998-2001 Arctic cat sway bars<br />
MISC risers and garbage</p>
]]></description><link>https://fargostreet.com/topic/12118/wheels-tires-w-b-02-honda-snowmobile-parts</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:33:08 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/12118.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Oct 2007 23:14:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Sat, 01 Dec 2007 06:24:52 GMT]]></title><description><![CDATA[<p dir="auto">How much for the firecat headlights?  Are they in good shape?</p>
]]></description><link>https://fargostreet.com/post/186007</link><guid isPermaLink="true">https://fargostreet.com/post/186007</guid><dc:creator><![CDATA[awd95mn]]></dc:creator><pubDate>Sat, 01 Dec 2007 06:24:52 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Sat, 01 Dec 2007 01:10:59 GMT]]></title><description><![CDATA[<p dir="auto">so you need the distributor plugs on the engine harness side??</p>
]]></description><link>https://fargostreet.com/post/185956</link><guid isPermaLink="true">https://fargostreet.com/post/185956</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Sat, 01 Dec 2007 01:10:59 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Sat, 01 Dec 2007 00:06:07 GMT]]></title><description><![CDATA[<p dir="auto">I guess ill need the clips that the distributor plugs into, on the harness.</p>
]]></description><link>https://fargostreet.com/post/185953</link><guid isPermaLink="true">https://fargostreet.com/post/185953</guid><dc:creator><![CDATA[BlackEJ8]]></dc:creator><pubDate>Sat, 01 Dec 2007 00:06:07 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Fri, 30 Nov 2007 16:01:12 GMT]]></title><description><![CDATA[<p dir="auto">As in the plugs off of an OBD-1 dizzy?? Probably, i can check but it won't be until monday probably.</p>
]]></description><link>https://fargostreet.com/post/185913</link><guid isPermaLink="true">https://fargostreet.com/post/185913</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Fri, 30 Nov 2007 16:01:12 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Fri, 30 Nov 2007 15:17:48 GMT]]></title><description><![CDATA[<p dir="auto">Would you happen to have an obd-1 distributor clip?</p>
]]></description><link>https://fargostreet.com/post/185908</link><guid isPermaLink="true">https://fargostreet.com/post/185908</guid><dc:creator><![CDATA[BlackEJ8]]></dc:creator><pubDate>Fri, 30 Nov 2007 15:17:48 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Thu, 29 Nov 2007 16:01:45 GMT]]></title><description><![CDATA[<p dir="auto">Bump, make offers.</p>
]]></description><link>https://fargostreet.com/post/185763</link><guid isPermaLink="true">https://fargostreet.com/post/185763</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Thu, 29 Nov 2007 16:01:45 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Fri, 23 Nov 2007 19:47:20 GMT]]></title><description><![CDATA[<p dir="auto">I believe you need an adaptor to go to the new style risers and bars to work on older sleds.....</p>
<p dir="auto">Bump, i removed some sold parts and added some more.</p>
]]></description><link>https://fargostreet.com/post/184681</link><guid isPermaLink="true">https://fargostreet.com/post/184681</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Fri, 23 Nov 2007 19:47:20 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Fri, 16 Nov 2007 19:27:56 GMT]]></title><description><![CDATA[<p dir="auto">what do you want for the ac bar risers? will they fit on a 94 zr700?</p>
]]></description><link>https://fargostreet.com/post/183851</link><guid isPermaLink="true">https://fargostreet.com/post/183851</guid><dc:creator><![CDATA[LivinLow]]></dc:creator><pubDate>Fri, 16 Nov 2007 19:27:56 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Fri, 09 Nov 2007 05:05:47 GMT]]></title><description><![CDATA[<p dir="auto">It is a god damn stock EG wing, it looks like every single other one you have ever seen.</p>
]]></description><link>https://fargostreet.com/post/182592</link><guid isPermaLink="true">https://fargostreet.com/post/182592</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Fri, 09 Nov 2007 05:05:47 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Thu, 08 Nov 2007 18:12:23 GMT]]></title><description><![CDATA[<p dir="auto">pic of eg wing??</p>
]]></description><link>https://fargostreet.com/post/182544</link><guid isPermaLink="true">https://fargostreet.com/post/182544</guid><dc:creator><![CDATA[blindsp1]]></dc:creator><pubDate>Thu, 08 Nov 2007 18:12:23 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Thu, 08 Nov 2007 16:04:37 GMT]]></title><description><![CDATA[<p dir="auto">Bump again......make me offers.</p>
]]></description><link>https://fargostreet.com/post/182528</link><guid isPermaLink="true">https://fargostreet.com/post/182528</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Thu, 08 Nov 2007 16:04:37 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Sat, 27 Oct 2007 18:38:07 GMT]]></title><description><![CDATA[<p dir="auto">Im pretty sure they are, call me and i will tell you the history behind both of them, call me sometime and ill explain it.</p>
]]></description><link>https://fargostreet.com/post/181192</link><guid isPermaLink="true">https://fargostreet.com/post/181192</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Sat, 27 Oct 2007 18:38:07 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Sat, 27 Oct 2007 16:03:19 GMT]]></title><description><![CDATA[<p dir="auto">those ex trannys in pretty good shape?</p>
]]></description><link>https://fargostreet.com/post/181178</link><guid isPermaLink="true">https://fargostreet.com/post/181178</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Sat, 27 Oct 2007 16:03:19 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Sat, 27 Oct 2007 14:19:38 GMT]]></title><description><![CDATA[<p dir="auto">TTT........</p>
]]></description><link>https://fargostreet.com/post/181176</link><guid isPermaLink="true">https://fargostreet.com/post/181176</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Sat, 27 Oct 2007 14:19:38 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Sun, 21 Oct 2007 18:57:15 GMT]]></title><description><![CDATA[<p dir="auto">Bump again......</p>
]]></description><link>https://fargostreet.com/post/180321</link><guid isPermaLink="true">https://fargostreet.com/post/180321</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Sun, 21 Oct 2007 18:57:15 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Sat, 13 Oct 2007 18:38:19 GMT]]></title><description><![CDATA[<p dir="auto">pics of fat fives and tire tread?</p>
]]></description><link>https://fargostreet.com/post/179136</link><guid isPermaLink="true">https://fargostreet.com/post/179136</guid><dc:creator><![CDATA[blindsp1]]></dc:creator><pubDate>Sat, 13 Oct 2007 18:38:19 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Fri, 12 Oct 2007 21:24:20 GMT]]></title><description><![CDATA[<p dir="auto">Call me at (218)255-1205 if you want anything delivered cuz im coming down to fargo on sunday. Free delivery.</p>
]]></description><link>https://fargostreet.com/post/179070</link><guid isPermaLink="true">https://fargostreet.com/post/179070</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Fri, 12 Oct 2007 21:24:20 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Thu, 11 Oct 2007 15:08:08 GMT]]></title><description><![CDATA[<p dir="auto">Updated the list.......</p>
]]></description><link>https://fargostreet.com/post/178825</link><guid isPermaLink="true">https://fargostreet.com/post/178825</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Thu, 11 Oct 2007 15:08:08 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Tue, 09 Oct 2007 17:23:01 GMT]]></title><description><![CDATA[<p dir="auto">Pm me. Im very interested in the 16's</p>
]]></description><link>https://fargostreet.com/post/178566</link><guid isPermaLink="true">https://fargostreet.com/post/178566</guid><dc:creator><![CDATA[youngin2nr]]></dc:creator><pubDate>Tue, 09 Oct 2007 17:23:01 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Tue, 09 Oct 2007 14:39:26 GMT]]></title><description><![CDATA[<p dir="auto">spose the rage's your pretty firm on.</p>
]]></description><link>https://fargostreet.com/post/178552</link><guid isPermaLink="true">https://fargostreet.com/post/178552</guid><dc:creator><![CDATA[blindsp1]]></dc:creator><pubDate>Tue, 09 Oct 2007 14:39:26 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Tue, 09 Oct 2007 04:39:26 GMT]]></title><description><![CDATA[<p dir="auto">I love this seller, would buy again ++!</p>
]]></description><link>https://fargostreet.com/post/178490</link><guid isPermaLink="true">https://fargostreet.com/post/178490</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Tue, 09 Oct 2007 04:39:26 GMT</pubDate></item><item><title><![CDATA[Reply to Wheels, tires, W&#x2F;B 02, honda, snowmobile parts on Tue, 09 Oct 2007 04:37:51 GMT]]></title><description><![CDATA[<p dir="auto">its a shame i loved the way that thing sat but im sure it will look good with some changes also, good luck on the sales. <strong>vouch for and great guy</strong></p>
]]></description><link>https://fargostreet.com/post/178488</link><guid isPermaLink="true">https://fargostreet.com/post/178488</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Tue, 09 Oct 2007 04:37:51 GMT</pubDate></item></channel></rss>
