<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[WTF?]]></title><description><![CDATA[<p dir="auto">So, I have an xbox 360 and it's ruined two discs. I have it stood upright on a cooler thing, and it's giving me some grief. Not only are the discs ruined, but the controllers flash thier ring as though they are trying to connect. They even do it when the thing is off...What's the deal?</p>
]]></description><link>https://fargostreet.com/topic/12247/wtf</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:10:48 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/12247.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 23 Oct 2007 18:41:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to WTF? on Sat, 03 Nov 2007 17:46:55 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Jim;191850 wrote:<br />
Warranty it. Microsoft extended the warranty 3 years....</p>
<p dir="auto">I believe the 3 year warranty only applies to the 3 Red Lights error, everything else is 1 year.</p>
<p dir="auto">There is a well known issue where some of the drives in the 360's have been destroying disks though. I'd be willing to bet if you called Customer Support @ Microsoft they might say "no" at first but you could push enough and get them to say "ok send it in we'll fix it".</p>
]]></description><link>https://fargostreet.com/post/181791</link><guid isPermaLink="true">https://fargostreet.com/post/181791</guid><dc:creator><![CDATA[StangerBanger96]]></dc:creator><pubDate>Sat, 03 Nov 2007 17:46:55 GMT</pubDate></item><item><title><![CDATA[Reply to WTF? on Sat, 03 Nov 2007 15:35:28 GMT]]></title><description><![CDATA[<p dir="auto">also just fyi -- never change the orientation of the box (flat or upright) while there's a disc in it.</p>
<p dir="auto">the controllers will do the circle-of-green thing when they have a low battery, although having them do that while the box is off is surprising.  note that the box also supports "low power mode" now where it will continue downloading and stuff even though its most of the way off..</p>
]]></description><link>https://fargostreet.com/post/181782</link><guid isPermaLink="true">https://fargostreet.com/post/181782</guid><dc:creator><![CDATA[thrash]]></dc:creator><pubDate>Sat, 03 Nov 2007 15:35:28 GMT</pubDate></item><item><title><![CDATA[Reply to WTF? on Fri, 02 Nov 2007 09:10:27 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">bluejays;191845 wrote:<br />
thats weird the guys at software etc said the one that plugs into the power cord is the better cooling setup</p>
<p dir="auto">The best cooling set up is one that does not draw power from the xbox 360 at all.  i've seen ppl use four 120mm fans powered by an adapter and that drops temps dramatically.</p>
<p dir="auto">The best consumer product right now is the pelican air flo (?) product which runs off the USB ports and also functions as a breakout box giving all kinds of ports.  The nyko one will fuck up your shit.  Stay away.</p>
<p dir="auto">I say if your 360 needs cooling, you need a new xbox.  If it's eating disks, try putting it horizontally, if it still does it, you need a new xbox.  call up MS, they are replacing these things left and right, you don't necessarily even need a ring of death to get a replacement.</p>
]]></description><link>https://fargostreet.com/post/181736</link><guid isPermaLink="true">https://fargostreet.com/post/181736</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Fri, 02 Nov 2007 09:10:27 GMT</pubDate></item><item><title><![CDATA[Reply to WTF? on Wed, 31 Oct 2007 02:25:24 GMT]]></title><description><![CDATA[<p dir="auto">I stand mine up and have had 0 problems.</p>
]]></description><link>https://fargostreet.com/post/181592</link><guid isPermaLink="true">https://fargostreet.com/post/181592</guid><dc:creator><![CDATA[capitlj]]></dc:creator><pubDate>Wed, 31 Oct 2007 02:25:24 GMT</pubDate></item><item><title><![CDATA[Reply to WTF? on Fri, 26 Oct 2007 01:47:26 GMT]]></title><description><![CDATA[<p dir="auto">Warranty it. Microsoft extended the warranty 3 years....</p>
]]></description><link>https://fargostreet.com/post/181035</link><guid isPermaLink="true">https://fargostreet.com/post/181035</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Fri, 26 Oct 2007 01:47:26 GMT</pubDate></item><item><title><![CDATA[Reply to WTF? on Fri, 26 Oct 2007 00:35:41 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">jester;191504 wrote:<br />
you really shouldnt use the 360 upright,  they are notorious for chewing up discs.  also if you need a cooling setup get the one that plugs into the usb port in the back otherwise you face a greater risk for the ring of death.</p>
<p dir="auto">thats weird the guys at software etc said the one that plugs into the power cord is the better cooling setup</p>
]]></description><link>https://fargostreet.com/post/181030</link><guid isPermaLink="true">https://fargostreet.com/post/181030</guid><dc:creator><![CDATA[bluejays]]></dc:creator><pubDate>Fri, 26 Oct 2007 00:35:41 GMT</pubDate></item><item><title><![CDATA[Reply to WTF? on Tue, 23 Oct 2007 22:12:38 GMT]]></title><description><![CDATA[<p dir="auto">you really shouldnt use the 360 upright,  they are notorious for chewing up discs.  also if you need a cooling setup get the one that plugs into the usb port in the back otherwise you face a greater risk for the ring of death.</p>
]]></description><link>https://fargostreet.com/post/180701</link><guid isPermaLink="true">https://fargostreet.com/post/180701</guid><dc:creator><![CDATA[jester]]></dc:creator><pubDate>Tue, 23 Oct 2007 22:12:38 GMT</pubDate></item><item><title><![CDATA[Reply to WTF? on Tue, 23 Oct 2007 19:03:35 GMT]]></title><description><![CDATA[<p dir="auto">Yep, and it's getting pretty old...Halo 3 has been replaced once, and now Forza needs to be replaced. It was working just fine last night before I left.</p>
]]></description><link>https://fargostreet.com/post/180657</link><guid isPermaLink="true">https://fargostreet.com/post/180657</guid><dc:creator><![CDATA[JN607]]></dc:creator><pubDate>Tue, 23 Oct 2007 19:03:35 GMT</pubDate></item><item><title><![CDATA[Reply to WTF? on Tue, 23 Oct 2007 18:57:50 GMT]]></title><description><![CDATA[<p dir="auto">Luke's brother eats disks too, on the outside edge?</p>
]]></description><link>https://fargostreet.com/post/180655</link><guid isPermaLink="true">https://fargostreet.com/post/180655</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Tue, 23 Oct 2007 18:57:50 GMT</pubDate></item><item><title><![CDATA[Reply to WTF? on Tue, 23 Oct 2007 18:50:21 GMT]]></title><description><![CDATA[<p dir="auto">It's not the cooling I'm worried about, why are the controllers flashing right now when the thing is turned off?</p>
]]></description><link>https://fargostreet.com/post/180650</link><guid isPermaLink="true">https://fargostreet.com/post/180650</guid><dc:creator><![CDATA[JN607]]></dc:creator><pubDate>Tue, 23 Oct 2007 18:50:21 GMT</pubDate></item><item><title><![CDATA[Reply to WTF? on Tue, 23 Oct 2007 18:48:06 GMT]]></title><description><![CDATA[<p dir="auto">The cooling fans for the xbox are on the side that faces down when you stand it up. Lay it down and put it on something like a piece of cardboard if you have it laying on the carpet it should run better that way.</p>
]]></description><link>https://fargostreet.com/post/180648</link><guid isPermaLink="true">https://fargostreet.com/post/180648</guid><dc:creator><![CDATA[thurmanmerman]]></dc:creator><pubDate>Tue, 23 Oct 2007 18:48:06 GMT</pubDate></item></channel></rss>
