<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Removing Radio from tempo]]></title><description><![CDATA[<p dir="auto">I can't figure out how to get this damned thing out. I bought the 2 U shaped hook things and when I shove them in there, the cd player loosens up, but I cant pull it out, anyone got tips, I tried prying it but all I did was crack the dash.</p>
]]></description><link>https://fargostreet.com/topic/12338/removing-radio-from-tempo</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 18:20:12 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/12338.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Nov 2007 16:07:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Removing Radio from tempo on Sun, 04 Nov 2007 17:13:04 GMT]]></title><description><![CDATA[<p dir="auto">There's also a plastic/nylon guide on the top of the radio that runs along a flaty piece of steel. If that's in yours, it's gonna be a fucker to get out as they are pretty snug fitting. Try pulling harder as Jon said. But pull evenly or it wont budge. Also make sure that you are actually collapsing the side catches rather than spreading them further apart. I've seen alot of N00bs do this and end up destrying the radio taking it out. Hope this helps.</p>
]]></description><link>https://fargostreet.com/post/181852</link><guid isPermaLink="true">https://fargostreet.com/post/181852</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sun, 04 Nov 2007 17:13:04 GMT</pubDate></item><item><title><![CDATA[Reply to Removing Radio from tempo on Sun, 04 Nov 2007 17:03:28 GMT]]></title><description><![CDATA[<p dir="auto">pull harder....or use a small flathead screwdriver and pry on each side so it pulls out a little</p>
]]></description><link>https://fargostreet.com/post/181850</link><guid isPermaLink="true">https://fargostreet.com/post/181850</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Sun, 04 Nov 2007 17:03:28 GMT</pubDate></item></channel></rss>
