<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Interior light wont shut off.]]></title><description><![CDATA[<p dir="auto">As you may know I have a 91 Talon.  Before my light would never come on when I opened the door but now it wont shut off.  It is the lights that are at your feet inside the car.</p>
<p dir="auto">Also the light that indicates that a door is open stays on all the time.  It started blinking on the way up here from Wis. and has since stayed on.</p>
<p dir="auto">Suggestions?</p>
]]></description><link>https://fargostreet.com/topic/1246/interior-light-wont-shut-off.</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:05:38 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/1246.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Jan 2005 17:03:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Interior light wont shut off. on Tue, 11 Jan 2005 23:11:42 GMT]]></title><description><![CDATA[<p dir="auto">I was thinking that but you never know.</p>
]]></description><link>https://fargostreet.com/post/23142</link><guid isPermaLink="true">https://fargostreet.com/post/23142</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 11 Jan 2005 23:11:42 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Tue, 11 Jan 2005 22:40:29 GMT]]></title><description><![CDATA[<p dir="auto">it didnt cause"Yeah but just now when I was driving it around at just about every stop the car would shut off and taking out that fuse disabled the radio."<br />
hadhappend</p>
]]></description><link>https://fargostreet.com/post/23141</link><guid isPermaLink="true">https://fargostreet.com/post/23141</guid><dc:creator><![CDATA[My NOva]]></dc:creator><pubDate>Tue, 11 Jan 2005 22:40:29 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Tue, 11 Jan 2005 20:11:28 GMT]]></title><description><![CDATA[<blockquote>
Pull the fuse... Mid West Customs is the best shop ever!<br />
lol  just messin with ya.</p>
<p dir="auto">i never even knew it was a shop haha...but pulling the fuse would solve the problem</p>
]]></description><link>https://fargostreet.com/post/23102</link><guid isPermaLink="true">https://fargostreet.com/post/23102</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 11 Jan 2005 20:11:28 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Tue, 11 Jan 2005 19:13:48 GMT]]></title><description><![CDATA[<p dir="auto">Yeah after taking out that door switch I took it out on the freeway and played a little bit but once I stopped the idle just went back to normal.  Sweet!!!</p>
<p dir="auto">I think I owe you a six pack or something.</p>
]]></description><link>https://fargostreet.com/post/23077</link><guid isPermaLink="true">https://fargostreet.com/post/23077</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 11 Jan 2005 19:13:48 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Tue, 11 Jan 2005 03:04:59 GMT]]></title><description><![CDATA[<p dir="auto">Pull the fuse... Mid West Customs is the best shop ever!<br />
]]></description><link>https://fargostreet.com/post/22918</link><guid isPermaLink="true">https://fargostreet.com/post/22918</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Tue, 11 Jan 2005 03:04:59 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Tue, 11 Jan 2005 02:31:17 GMT]]></title><description><![CDATA[<p dir="auto">I had the same problem with both of my DSM's. If I can see it, I'll probably be able to figure it out.</p>
]]></description><link>https://fargostreet.com/post/22909</link><guid isPermaLink="true">https://fargostreet.com/post/22909</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Tue, 11 Jan 2005 02:31:17 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 23:41:48 GMT]]></title><description><![CDATA[<p dir="auto">if you didnt fix it try putting a small tack weld where the light switch connects in the door jam. i did that on my girlfriends car because the door jam was dented in.<br />
just my two cents.</p>
]]></description><link>https://fargostreet.com/post/22895</link><guid isPermaLink="true">https://fargostreet.com/post/22895</guid><dc:creator><![CDATA[92TSIpos]]></dc:creator><pubDate>Mon, 10 Jan 2005 23:41:48 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 22:21:38 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">dynotune wrote:<br />
Door ajar switch open circuit.  Remove switch on drivers side, ground wire and if light goes off, that switch is bad.  If not check other doors including hatch.</p>
<p dir="auto">what was wrong with this help?  this is the correct way to fix it!</p>
]]></description><link>https://fargostreet.com/post/22878</link><guid isPermaLink="true">https://fargostreet.com/post/22878</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Mon, 10 Jan 2005 22:21:38 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 21:21:47 GMT]]></title><description><![CDATA[<p dir="auto">OK will do.</p>
]]></description><link>https://fargostreet.com/post/22845</link><guid isPermaLink="true">https://fargostreet.com/post/22845</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 10 Jan 2005 21:21:47 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 21:08:53 GMT]]></title><description><![CDATA[<p dir="auto">Chris get ahold of me tomorrow at work and I'll see if I can help you out.</p>
]]></description><link>https://fargostreet.com/post/22839</link><guid isPermaLink="true">https://fargostreet.com/post/22839</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Mon, 10 Jan 2005 21:08:53 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 20:18:35 GMT]]></title><description><![CDATA[<blockquote>
thanks mwc1! haha<br />
Yeah but just now when I was driving it around at just about every stop the car would shut off and taking out that fuse disabled the radio.</p>
]]></description><link>https://fargostreet.com/post/22833</link><guid isPermaLink="true">https://fargostreet.com/post/22833</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 10 Jan 2005 20:18:35 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 19:55:05 GMT]]></title><description><![CDATA[<p dir="auto">thanks mwc1! haha</p>
]]></description><link>https://fargostreet.com/post/22823</link><guid isPermaLink="true">https://fargostreet.com/post/22823</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 10 Jan 2005 19:55:05 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 18:56:04 GMT]]></title><description><![CDATA[<p dir="auto">I pulled out the fuse and the light went out mission accomplished.</p>
]]></description><link>https://fargostreet.com/post/22818</link><guid isPermaLink="true">https://fargostreet.com/post/22818</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 10 Jan 2005 18:56:04 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 18:51:17 GMT]]></title><description><![CDATA[<p dir="auto">try just bending the metal part around the white plastice piece up so the door actually pushes the plastic piece in when its closed.</p>
]]></description><link>https://fargostreet.com/post/22817</link><guid isPermaLink="true">https://fargostreet.com/post/22817</guid><dc:creator><![CDATA[amicheze]]></dc:creator><pubDate>Mon, 10 Jan 2005 18:51:17 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 18:48:42 GMT]]></title><description><![CDATA[<p dir="auto">im sure you could find someone else with ur car with a manual or search long enough online and find one.  Maybe the dealership would have access to one??</p>
]]></description><link>https://fargostreet.com/post/22816</link><guid isPermaLink="true">https://fargostreet.com/post/22816</guid><dc:creator><![CDATA[jct_4628]]></dc:creator><pubDate>Mon, 10 Jan 2005 18:48:42 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 18:24:29 GMT]]></title><description><![CDATA[<p dir="auto">No manual.</p>
<p dir="auto">It is mighty cold outside but I will try it.</p>
]]></description><link>https://fargostreet.com/post/22815</link><guid isPermaLink="true">https://fargostreet.com/post/22815</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 10 Jan 2005 18:24:29 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 17:59:43 GMT]]></title><description><![CDATA[<p dir="auto">just look at the switch box cover...or in your manual...it will say which one is the interior lights.</p>
]]></description><link>https://fargostreet.com/post/22813</link><guid isPermaLink="true">https://fargostreet.com/post/22813</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 10 Jan 2005 17:59:43 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 17:57:20 GMT]]></title><description><![CDATA[<p dir="auto">Anyone know what fuse it could be?</p>
]]></description><link>https://fargostreet.com/post/22812</link><guid isPermaLink="true">https://fargostreet.com/post/22812</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 10 Jan 2005 17:57:20 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 17:53:42 GMT]]></title><description><![CDATA[<p dir="auto">or i tihnk there is just a fuse you can take out.</p>
]]></description><link>https://fargostreet.com/post/22811</link><guid isPermaLink="true">https://fargostreet.com/post/22811</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 10 Jan 2005 17:53:42 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 17:49:36 GMT]]></title><description><![CDATA[<p dir="auto">Door ajar switch open circuit.  Remove switch on drivers side, ground wire and if light goes off, that switch is bad.  If not check other doors including hatch.</p>
]]></description><link>https://fargostreet.com/post/22810</link><guid isPermaLink="true">https://fargostreet.com/post/22810</guid><dc:creator><![CDATA[dynotune]]></dc:creator><pubDate>Mon, 10 Jan 2005 17:49:36 GMT</pubDate></item><item><title><![CDATA[Reply to Interior light wont shut off. on Mon, 10 Jan 2005 17:32:39 GMT]]></title><description><![CDATA[<p dir="auto">sounds like your wirings messed up somewhere...</p>
]]></description><link>https://fargostreet.com/post/22808</link><guid isPermaLink="true">https://fargostreet.com/post/22808</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 10 Jan 2005 17:32:39 GMT</pubDate></item></channel></rss>
