<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Snowmobile actin up]]></title><description><![CDATA[<p dir="auto">I figured i'd post it up in here, mods if you have a better place to put it thats fine with me. So I just recentally bought a 95 ski-doo formula z (583 motor) this year and i have been havin a lil bit of trouble with it. I can go out and it starts right up but after i take it out for a little spin it likes to start boggin out on me, it's like the gas just cuts in and out, i usaully give it a lil more gas or feather it and it will stay runnin for a while but then it justs dies. Also if you just let it sit for a lil bit you can go out and it will start rite up. So i was just wonderin if any of you guys had any suggestions on why it wont run rite. I'm thinkin something to do with the fuel system, but i mite be wrong. Also i have checked the carbs over numerous times and they are just fine. I thinking bout maybe just sellin it off so if anyone is interested give me a holla. It would be nice to get one good ride in b4 the end of winter lol. lmk what u guys think, thanks</p>
]]></description><link>https://fargostreet.com/topic/12761/snowmobile-actin-up</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 20:13:28 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/12761.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 16 Dec 2007 01:28:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Snowmobile actin up on Tue, 18 Dec 2007 07:05:26 GMT]]></title><description><![CDATA[<p dir="auto">well, i got gary takin a look at it now, hopefully everthing comes out ok. lol</p>
]]></description><link>https://fargostreet.com/post/188239</link><guid isPermaLink="true">https://fargostreet.com/post/188239</guid><dc:creator><![CDATA[speed_ricer69]]></dc:creator><pubDate>Tue, 18 Dec 2007 07:05:26 GMT</pubDate></item><item><title><![CDATA[Reply to Snowmobile actin up on Mon, 17 Dec 2007 19:51:18 GMT]]></title><description><![CDATA[<p dir="auto">replace spark plug wires and the inline fuel filter, or add one if you dont have one. i had the same problem on my ac and there was water in the tank and the wires were shot</p>
]]></description><link>https://fargostreet.com/post/188192</link><guid isPermaLink="true">https://fargostreet.com/post/188192</guid><dc:creator><![CDATA[LivinLow]]></dc:creator><pubDate>Mon, 17 Dec 2007 19:51:18 GMT</pubDate></item><item><title><![CDATA[Reply to Snowmobile actin up on Mon, 17 Dec 2007 18:18:02 GMT]]></title><description><![CDATA[<p dir="auto">PM a price that your looking at getting for it....</p>
]]></description><link>https://fargostreet.com/post/188184</link><guid isPermaLink="true">https://fargostreet.com/post/188184</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Mon, 17 Dec 2007 18:18:02 GMT</pubDate></item><item><title><![CDATA[Reply to Snowmobile actin up on Mon, 17 Dec 2007 18:07:06 GMT]]></title><description><![CDATA[<p dir="auto">sounds like a jetting iisue to me.  id say it has a lean bog,  the way hes describing it.  running lean will make it overheat and quit,  after a while ittl start again,  but,  if it is run thatway too much youll melt down a piston,  if it hasnt already started to.</p>
]]></description><link>https://fargostreet.com/post/188182</link><guid isPermaLink="true">https://fargostreet.com/post/188182</guid><dc:creator><![CDATA[Goodnbuzzd]]></dc:creator><pubDate>Mon, 17 Dec 2007 18:07:06 GMT</pubDate></item><item><title><![CDATA[Reply to Snowmobile actin up on Sun, 16 Dec 2007 05:02:23 GMT]]></title><description><![CDATA[<p dir="auto">I'd say take off the carbs, soak them overnight in cleaner...change the plugs out and check the wires...</p>
<p dir="auto">So Gary...can u do anything to a 78 El Tigre 440 liquid to get a little more power out of it?</p>
]]></description><link>https://fargostreet.com/post/188043</link><guid isPermaLink="true">https://fargostreet.com/post/188043</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Sun, 16 Dec 2007 05:02:23 GMT</pubDate></item><item><title><![CDATA[Reply to Snowmobile actin up on Sun, 16 Dec 2007 03:32:16 GMT]]></title><description><![CDATA[<p dir="auto">did you sync the carbs?  set the base height?  everything is clean i hope.  Its definately in the carbs.  If you want you can bring it over to breck and we'll set it up for ya cheap.  Also when is the last time the clutches have been through.  If you want some speed we can do a few little tricks and it will be a whole different sled.  That is if it isnt one of our old ones to begin with, think we had about 20 of those 95 z's in the area we set up.  LMK.<br />
Gary</p>
]]></description><link>https://fargostreet.com/post/188038</link><guid isPermaLink="true">https://fargostreet.com/post/188038</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Sun, 16 Dec 2007 03:32:16 GMT</pubDate></item><item><title><![CDATA[Reply to Snowmobile actin up on Sun, 16 Dec 2007 03:31:25 GMT]]></title><description><![CDATA[<p dir="auto">Could be ignition (resistance increases with temp.).  I would start by checking your plug wire ends for corrosion.  They can get corroded where they go on the plug and the other end where they connect to the plug wire.  Just something to check, it causes the same symptoms.</p>
]]></description><link>https://fargostreet.com/post/188036</link><guid isPermaLink="true">https://fargostreet.com/post/188036</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Sun, 16 Dec 2007 03:31:25 GMT</pubDate></item><item><title><![CDATA[Reply to Snowmobile actin up on Sun, 16 Dec 2007 02:54:08 GMT]]></title><description><![CDATA[<p dir="auto">naw im good but thanks for the offer</p>
]]></description><link>https://fargostreet.com/post/188032</link><guid isPermaLink="true">https://fargostreet.com/post/188032</guid><dc:creator><![CDATA[speed_ricer69]]></dc:creator><pubDate>Sun, 16 Dec 2007 02:54:08 GMT</pubDate></item><item><title><![CDATA[Reply to Snowmobile actin up on Sun, 16 Dec 2007 01:40:38 GMT]]></title><description><![CDATA[<p dir="auto">I'll give you $300 for it.</p>
]]></description><link>https://fargostreet.com/post/188025</link><guid isPermaLink="true">https://fargostreet.com/post/188025</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Sun, 16 Dec 2007 01:40:38 GMT</pubDate></item></channel></rss>
