<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Leaving a car on stands]]></title><description><![CDATA[<p dir="auto">I was just wondering if there's anything bad about leaving a car on jack stands for a long period of time...like a few months at a time...</p>
]]></description><link>https://fargostreet.com/topic/12827/leaving-a-car-on-stands</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 13:20:42 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/12827.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Dec 2007 05:43:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Leaving a car on stands on Tue, 25 Dec 2007 07:55:48 GMT]]></title><description><![CDATA[<p dir="auto">You should already know what to do with the whole mouse thing, i already told you before but if you forget just call me and ill let you know again. Also faber has some good points....</p>
]]></description><link>https://fargostreet.com/post/188999</link><guid isPermaLink="true">https://fargostreet.com/post/188999</guid><dc:creator><![CDATA[itRfan]]></dc:creator><pubDate>Tue, 25 Dec 2007 07:55:48 GMT</pubDate></item><item><title><![CDATA[Reply to Leaving a car on stands on Tue, 25 Dec 2007 06:47:50 GMT]]></title><description><![CDATA[<p dir="auto">ok...i'll have to do that...it has been setting on stands already for quite a while...but I plan on moving it to a heated shop this week, instead of out in a snowbank, lol</p>
]]></description><link>https://fargostreet.com/post/188995</link><guid isPermaLink="true">https://fargostreet.com/post/188995</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Tue, 25 Dec 2007 06:47:50 GMT</pubDate></item><item><title><![CDATA[Reply to Leaving a car on stands on Tue, 25 Dec 2007 06:36:52 GMT]]></title><description><![CDATA[<p dir="auto">get a piece of plywood or something and set it between the rims and the car. Thats my opinion</p>
]]></description><link>https://fargostreet.com/post/188994</link><guid isPermaLink="true">https://fargostreet.com/post/188994</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Tue, 25 Dec 2007 06:36:52 GMT</pubDate></item><item><title><![CDATA[Reply to Leaving a car on stands on Tue, 25 Dec 2007 06:06:16 GMT]]></title><description><![CDATA[<p dir="auto">Ok...The only reason why I ask is cause pretty much the whole suspension and everything will be off of the car so I cant really have it on the ground, and I barely ever get down to work on it so it usually sits for long periods of time....what about doing it the ghetto way and using some shitty wheels and tires as stands, beings it would be a larger surface area for it to rest on?</p>
]]></description><link>https://fargostreet.com/post/188989</link><guid isPermaLink="true">https://fargostreet.com/post/188989</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Tue, 25 Dec 2007 06:06:16 GMT</pubDate></item><item><title><![CDATA[Reply to Leaving a car on stands on Tue, 25 Dec 2007 05:57:02 GMT]]></title><description><![CDATA[<p dir="auto">If you really care about it, I would put something else between stands and body/frame. Then put would up under the tires or susp. to take strain of the susp. Other then that if its properly stored no. Make sure to do anti Mice stuff.</p>
]]></description><link>https://fargostreet.com/post/188985</link><guid isPermaLink="true">https://fargostreet.com/post/188985</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Tue, 25 Dec 2007 05:57:02 GMT</pubDate></item></channel></rss>
