<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is this another common problem with DSMs?]]></title><description><![CDATA[<p dir="auto">I got up this morning and checked out <a href="http://weather.com" rel="nofollow ugc">weather.com</a> to find out it is -25 outside.  My roomies car wouldn't start so it made me worry about mine. I had a class at 9:00 so I decided to start it at 8:30 so it could warm up for a while.</p>
<p dir="auto">Althhough it didn't want to start, it did reluctantly.  So I let it idle for about 15 minutes while I went back inside to see if they called off school (No such luck.)  I come back outside at about 8:50 which should give me reasonable time to get to school.</p>
<p dir="auto">I try getting my car into reverse but it just won't go.  I sat tried to do it for about 15 minutes with no luck.  I ended up hitching a ride with a girl to school but never went to class because I hate interupting a professor.</p>
<p dir="auto">Is this a problem with DSM's hating to go into reverse like this or is this just a cold weather problem?</p>
]]></description><link>https://fargostreet.com/topic/1299/is-this-another-common-problem-with-dsms</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 18:58:41 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/1299.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Jan 2005 15:27:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Fri, 28 Jan 2005 21:44:38 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">JamesonTSI-AWD wrote:<br />
yeah the cold is tuff for reverse sometimes but i have had the problem without the extreme cold, just put it in fourth and let off the clutch just a very little bit, and then put it in reverse quick, works everytime man</p>
<p dir="auto">as far as the syncromesh, i wouldnt go with penzoil, i dont know if the put perafin in there like they do with there oil, but if they do it is no good, it is like a wax that will coat the gears, and builds up.  i have seen some bad stuff happen to motors with penzoil!</p>
<p dir="auto">NO PENZOIL! haha</p>
<p dir="auto">Gm and Pennzoil  Syncromesh are the same!!! Pennziol makes it for GM and has the same part number.. But i wouldnt use it.... lol</p>
<p dir="auto">Kevin<br />
sls</p>
]]></description><link>https://fargostreet.com/post/27022</link><guid isPermaLink="true">https://fargostreet.com/post/27022</guid><dc:creator><![CDATA[blackcougar]]></dc:creator><pubDate>Fri, 28 Jan 2005 21:44:38 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Fri, 28 Jan 2005 21:42:18 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">92TSIpos wrote:<br />
i feel your pain man, I went to put my car in reverse and it wouldnt go in at all. Then it overheated because all my "coolant" froze inside the radiator and now its sitting at stop n go :mad:</p>
<p dir="auto">POS</p>
<p dir="auto">You mean all your water froze in your radiator...</p>
sls</p>
]]></description><link>https://fargostreet.com/post/27020</link><guid isPermaLink="true">https://fargostreet.com/post/27020</guid><dc:creator><![CDATA[blackcougar]]></dc:creator><pubDate>Fri, 28 Jan 2005 21:42:18 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Wed, 26 Jan 2005 13:57:43 GMT]]></title><description><![CDATA[<p dir="auto">or it doesnt say GM on it and its not sold be a dealer?</p>
]]></description><link>https://fargostreet.com/post/26478</link><guid isPermaLink="true">https://fargostreet.com/post/26478</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Wed, 26 Jan 2005 13:57:43 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Wed, 26 Jan 2005 13:49:52 GMT]]></title><description><![CDATA[<p dir="auto">cheaper is generally not better, there is probably just more shitty addatives to make it cheaper!</p>
]]></description><link>https://fargostreet.com/post/26475</link><guid isPermaLink="true">https://fargostreet.com/post/26475</guid><dc:creator><![CDATA[JamesonTSI-AWD]]></dc:creator><pubDate>Wed, 26 Jan 2005 13:49:52 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Wed, 26 Jan 2005 01:23:05 GMT]]></title><description><![CDATA[<p dir="auto">I agree...penzoil does not make very good oil.  It just makes a mess.  I have heard the same thing(no proof though) of havoline their products.</p>
]]></description><link>https://fargostreet.com/post/26385</link><guid isPermaLink="true">https://fargostreet.com/post/26385</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Wed, 26 Jan 2005 01:23:05 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Tue, 25 Jan 2005 23:31:40 GMT]]></title><description><![CDATA[<p dir="auto">sorry bout that... didn't read that post!</p>
]]></description><link>https://fargostreet.com/post/26354</link><guid isPermaLink="true">https://fargostreet.com/post/26354</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Tue, 25 Jan 2005 23:31:40 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Tue, 25 Jan 2005 22:39:08 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Bad93ex wrote:<br />
I think I am going to try some Pennzoil Syncromesh.  I have read on dsmtuners that it works well and is about $5 cheaper per bottle than the GM stuff even though it is the same stuff.</p>
<p dir="auto">i have no idea..... i was just thinkin they probably would put parafin in there</p>
]]></description><link>https://fargostreet.com/post/26337</link><guid isPermaLink="true">https://fargostreet.com/post/26337</guid><dc:creator><![CDATA[JamesonTSI-AWD]]></dc:creator><pubDate>Tue, 25 Jan 2005 22:39:08 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Tue, 25 Jan 2005 22:22:38 GMT]]></title><description><![CDATA[<p dir="auto">penzoil makes their own synchromesh</p>
]]></description><link>https://fargostreet.com/post/26329</link><guid isPermaLink="true">https://fargostreet.com/post/26329</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Tue, 25 Jan 2005 22:22:38 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Tue, 25 Jan 2005 22:17:55 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">maybe i'm just confused... but synchromesh isn't made by penzoil.......... ?</p>
]]></description><link>https://fargostreet.com/post/26326</link><guid isPermaLink="true">https://fargostreet.com/post/26326</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Tue, 25 Jan 2005 22:17:55 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Tue, 25 Jan 2005 21:22:02 GMT]]></title><description><![CDATA[<p dir="auto">yeah the cold is tuff for reverse sometimes but i have had the problem without the extreme cold, just put it in fourth and let off the clutch just a very little bit, and then put it in reverse quick, works everytime man</p>
]]></description><link>https://fargostreet.com/post/26309</link><guid isPermaLink="true">https://fargostreet.com/post/26309</guid><dc:creator><![CDATA[JamesonTSI-AWD]]></dc:creator><pubDate>Tue, 25 Jan 2005 21:22:02 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Sun, 16 Jan 2005 01:43:15 GMT]]></title><description><![CDATA[<p dir="auto">gvr4 as in tranny....doh!</p>
]]></description><link>https://fargostreet.com/post/24379</link><guid isPermaLink="true">https://fargostreet.com/post/24379</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Sun, 16 Jan 2005 01:43:15 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Sun, 16 Jan 2005 01:42:29 GMT]]></title><description><![CDATA[<p dir="auto">my dsm has kinda been having the same going into (R) problem every now and then...and when it is a problem just keep on semi-forcing it in (dont grind it) and slightly let off the clutch a little bit until it pops into gear...thats what i do anyway and it works for me...then again, i got a new gvr4 <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /> .....but its worth a shot</p>
]]></description><link>https://fargostreet.com/post/24378</link><guid isPermaLink="true">https://fargostreet.com/post/24378</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Sun, 16 Jan 2005 01:42:29 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Sat, 15 Jan 2005 19:26:08 GMT]]></title><description><![CDATA[<p dir="auto">I Know how that is , R is hard to get in to when its cold out. You have a Jdm Tranny so you may want to look at your linkages and adjust them properly.. Also a good Idea to switch over to some othr fluids..</p>
sls</p>
]]></description><link>https://fargostreet.com/post/24309</link><guid isPermaLink="true">https://fargostreet.com/post/24309</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Sat, 15 Jan 2005 19:26:08 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Sat, 15 Jan 2005 16:23:20 GMT]]></title><description><![CDATA[<p dir="auto">that would suck if it was. i told him the other day to put some coolant in it</p>
]]></description><link>https://fargostreet.com/post/24270</link><guid isPermaLink="true">https://fargostreet.com/post/24270</guid><dc:creator><![CDATA[King Ricer]]></dc:creator><pubDate>Sat, 15 Jan 2005 16:23:20 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Sat, 15 Jan 2005 16:09:43 GMT]]></title><description><![CDATA[<p dir="auto">Fucking cheap ass, putting near straight water in @ below zero temps...LMFAO. BTW that isnt your fluidyne is it?</p>
]]></description><link>https://fargostreet.com/post/24267</link><guid isPermaLink="true">https://fargostreet.com/post/24267</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Sat, 15 Jan 2005 16:09:43 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Sat, 15 Jan 2005 15:46:15 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">maybe you should have put some "coolant" in it</p>
]]></description><link>https://fargostreet.com/post/24254</link><guid isPermaLink="true">https://fargostreet.com/post/24254</guid><dc:creator><![CDATA[King Ricer]]></dc:creator><pubDate>Sat, 15 Jan 2005 15:46:15 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Fri, 14 Jan 2005 21:15:20 GMT]]></title><description><![CDATA[<p dir="auto">Ouch that sucks to hear man.  Just hope for an early spring.</p>
]]></description><link>https://fargostreet.com/post/24105</link><guid isPermaLink="true">https://fargostreet.com/post/24105</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 14 Jan 2005 21:15:20 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Fri, 14 Jan 2005 21:13:09 GMT]]></title><description><![CDATA[<p dir="auto">i feel your pain man, I went to put my car in reverse and it wouldnt go in at all. Then it overheated because all my "coolant" froze inside the radiator and now its sitting at stop n go :mad:</p>
]]></description><link>https://fargostreet.com/post/24101</link><guid isPermaLink="true">https://fargostreet.com/post/24101</guid><dc:creator><![CDATA[92TSIpos]]></dc:creator><pubDate>Fri, 14 Jan 2005 21:13:09 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Fri, 14 Jan 2005 21:05:39 GMT]]></title><description><![CDATA[<blockquote>
when its running or when its not?</p>
<p dir="auto">When it was off.  So what does it mean then?</p>
]]></description><link>https://fargostreet.com/post/24094</link><guid isPermaLink="true">https://fargostreet.com/post/24094</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 14 Jan 2005 21:05:39 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Fri, 14 Jan 2005 21:03:51 GMT]]></title><description><![CDATA[<p dir="auto">when its running or when its not?</p>
]]></description><link>https://fargostreet.com/post/24092</link><guid isPermaLink="true">https://fargostreet.com/post/24092</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Fri, 14 Jan 2005 21:03:51 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Fri, 14 Jan 2005 21:03:04 GMT]]></title><description><![CDATA[<p dir="auto">I just tried and reverse is a little reluctant to go in but it does when it is off.</p>
<p dir="auto">I guess it has the same part # as the GM stuff but is under a different name.  I did look into on Dsmtuners.</p>
]]></description><link>https://fargostreet.com/post/24091</link><guid isPermaLink="true">https://fargostreet.com/post/24091</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 14 Jan 2005 21:03:04 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Fri, 14 Jan 2005 21:02:44 GMT]]></title><description><![CDATA[<p dir="auto">johnson bought it for his car too</p>
]]></description><link>https://fargostreet.com/post/24090</link><guid isPermaLink="true">https://fargostreet.com/post/24090</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Fri, 14 Jan 2005 21:02:44 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Fri, 14 Jan 2005 21:00:44 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">You sure its the same stuff?  Your tranny is worth a good deal more then $15, I dunno...</p>
]]></description><link>https://fargostreet.com/post/24089</link><guid isPermaLink="true">https://fargostreet.com/post/24089</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Fri, 14 Jan 2005 21:00:44 GMT</pubDate></item><item><title><![CDATA[Reply to Is this another common problem with DSMs? on Fri, 14 Jan 2005 20:53:34 GMT]]></title><description><![CDATA[<p dir="auto">its worth a shot isnt it? usually that only is for when like synchros are bad but hey ya never know</p>
]]></description><link>https://fargostreet.com/post/24085</link><guid isPermaLink="true">https://fargostreet.com/post/24085</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Fri, 14 Jan 2005 20:53:34 GMT</pubDate></item></channel></rss>
