<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tach wire on an EF civic]]></title><description><![CDATA[<p dir="auto">Where can I connect the green signal wire on a tachometer to my EF civic?  I know you can connect it to the dizzy but theres got to be a diagnostic port or something closer to connect it to.</p>
]]></description><link>https://fargostreet.com/topic/13011/tach-wire-on-an-ef-civic</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 05:45:55 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/13011.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 Jan 2008 18:08:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tach wire on an EF civic on Wed, 23 Jan 2008 06:22:34 GMT]]></title><description><![CDATA[<p dir="auto">yeah, I guess they are going at somewhat of a premium then, like 50-100 (no kidding 100) plus shipping.  does anyone know if a 91 civic lx cluster will work plug and play?  im sick of wiring for a week or two.</p>
]]></description><link>https://fargostreet.com/post/191286</link><guid isPermaLink="true">https://fargostreet.com/post/191286</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Wed, 23 Jan 2008 06:22:34 GMT</pubDate></item><item><title><![CDATA[Reply to Tach wire on an EF civic on Wed, 23 Jan 2008 03:20:19 GMT]]></title><description><![CDATA[<p dir="auto">I bought an si Cluster of bubba for 25 bucks last year... they are even cheaper on ebay. HF ones go for 10 bucks sometimes.</p>
]]></description><link>https://fargostreet.com/post/191272</link><guid isPermaLink="true">https://fargostreet.com/post/191272</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 23 Jan 2008 03:20:19 GMT</pubDate></item><item><title><![CDATA[Reply to Tach wire on an EF civic on Mon, 21 Jan 2008 07:11:02 GMT]]></title><description><![CDATA[<p dir="auto">im watching a few on ebay now, hopefully something comes of it.  i plan on being able to start the car tomorrow if my parts get here.  i'll need to adjust the idle rpm and set the timing ( I fuckin forgot to mark the dizzy position when I took it off) so I'll need to have a tach connected.</p>
]]></description><link>https://fargostreet.com/post/191182</link><guid isPermaLink="true">https://fargostreet.com/post/191182</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Mon, 21 Jan 2008 07:11:02 GMT</pubDate></item><item><title><![CDATA[Reply to Tach wire on an EF civic on Mon, 21 Jan 2008 06:29:30 GMT]]></title><description><![CDATA[<p dir="auto">just wait till you get a cluster with a tach, they cost like $25-50 tops</p>
]]></description><link>https://fargostreet.com/post/191176</link><guid isPermaLink="true">https://fargostreet.com/post/191176</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Mon, 21 Jan 2008 06:29:30 GMT</pubDate></item><item><title><![CDATA[Reply to Tach wire on an EF civic on Mon, 21 Jan 2008 06:12:26 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">matt j;202369 wrote:<br />
have you tried looking at the pin outputs from the links that i gave you on your other post about the mpfi? That may help you also. I know when i did mine in a ef i hooked it up to the tach signal wire on ecu, but that was like 5 years ago now and cant remember which one it was.</p>
<p dir="auto">Yep, that was very helpfull.  I think I am just going to use the tach signal wire on the cluster harness.  Getting the cluster out isn't as much of a pain in the ass as I thought.  Hopefully I will be getting a cluster with a tach soon but in the meantime it's an external tach for me (not the huge kind with the obnoxious shift light tho)</p>
]]></description><link>https://fargostreet.com/post/191173</link><guid isPermaLink="true">https://fargostreet.com/post/191173</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Mon, 21 Jan 2008 06:12:26 GMT</pubDate></item><item><title><![CDATA[Reply to Tach wire on an EF civic on Mon, 21 Jan 2008 05:57:42 GMT]]></title><description><![CDATA[<p dir="auto">look for a blue wire coming from the dizzy thats what i have always used.</p>
]]></description><link>https://fargostreet.com/post/191168</link><guid isPermaLink="true">https://fargostreet.com/post/191168</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Mon, 21 Jan 2008 05:57:42 GMT</pubDate></item><item><title><![CDATA[Reply to Tach wire on an EF civic on Mon, 21 Jan 2008 04:43:02 GMT]]></title><description><![CDATA[<p dir="auto">have you tried looking at the pin outputs from the links that i gave you on your other post about the mpfi? That may help you also. I know when i did mine in a ef i hooked it up to the tach signal wire on ecu, but that was like 5 years ago now and cant remember which one it was.</p>
]]></description><link>https://fargostreet.com/post/191164</link><guid isPermaLink="true">https://fargostreet.com/post/191164</guid><dc:creator><![CDATA[matt j]]></dc:creator><pubDate>Mon, 21 Jan 2008 04:43:02 GMT</pubDate></item><item><title><![CDATA[Reply to Tach wire on an EF civic on Mon, 21 Jan 2008 00:04:03 GMT]]></title><description><![CDATA[<p dir="auto">That wire (B20) is listed as the Ignition Timing Adjusting Connector, is that the right one?</p>
]]></description><link>https://fargostreet.com/post/191138</link><guid isPermaLink="true">https://fargostreet.com/post/191138</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Mon, 21 Jan 2008 00:04:03 GMT</pubDate></item><item><title><![CDATA[Reply to Tach wire on an EF civic on Sun, 20 Jan 2008 19:38:25 GMT]]></title><description><![CDATA[<p dir="auto">looking at the ECU, it is the bottom left brown wire on the left black plug.</p>
]]></description><link>https://fargostreet.com/post/191123</link><guid isPermaLink="true">https://fargostreet.com/post/191123</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Sun, 20 Jan 2008 19:38:25 GMT</pubDate></item><item><title><![CDATA[Reply to Tach wire on an EF civic on Sun, 20 Jan 2008 19:10:20 GMT]]></title><description><![CDATA[<p dir="auto">ECU plugs.</p>
]]></description><link>https://fargostreet.com/post/191121</link><guid isPermaLink="true">https://fargostreet.com/post/191121</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Sun, 20 Jan 2008 19:10:20 GMT</pubDate></item></channel></rss>
