<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Knock problems]]></title><description><![CDATA[<p dir="auto">when i drive down the highway in 5th gear at about 3500 rpms my afc says im knocking really bad. I tried adjusting the afc a little richer and that did nothing, so i tried leaning it out and that did nothing. Ive heard that it could be a lot of different things causing it, like timing, too rich or too lean, spark plug gap, bad plug wires, etc. etc.  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f615.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--confused" style="height:23px;width:auto;vertical-align:middle" title=":confused:" alt="😕" />  :mad:</p>
]]></description><link>https://fargostreet.com/topic/1330/knock-problems</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 01:18:57 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/1330.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Jan 2005 11:19:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Knock problems on Wed, 19 Jan 2005 04:17:52 GMT]]></title><description><![CDATA[<p dir="auto">I had the afc monitering the knock and had it paused so it will read the most knock and hold it on the screen. I have 550cc injectors, ten pounds of boost, I didnt time it troy did, and im not sure what plugs i have.</p>
<p dir="auto">P.S. Im trying not to blow it up thats why im asking this.<br />
p.s.s. Kevin let me know when you have time and ill bring it over so you can fuck with it.</p>
]]></description><link>https://fargostreet.com/post/25006</link><guid isPermaLink="true">https://fargostreet.com/post/25006</guid><dc:creator><![CDATA[92TSIpos]]></dc:creator><pubDate>Wed, 19 Jan 2005 04:17:52 GMT</pubDate></item><item><title><![CDATA[Reply to Knock problems on Wed, 19 Jan 2005 04:06:07 GMT]]></title><description><![CDATA[<p dir="auto">i don't know nick... i'm pretty sure i remember seeing triple digits on my afc <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://fargostreet.com/post/25004</link><guid isPermaLink="true">https://fargostreet.com/post/25004</guid><dc:creator><![CDATA[out there]]></dc:creator><pubDate>Wed, 19 Jan 2005 04:06:07 GMT</pubDate></item><item><title><![CDATA[Reply to Knock problems on Wed, 19 Jan 2005 00:54:00 GMT]]></title><description><![CDATA[<p dir="auto">Get a datalogger to find out , I can let you use mine for a hour or so... Did you get a new knock sensor? if not check if its good I wouldnt bother with the s-afc just use the data logger.. what injectors are you using? How much boost, whats your timing set at?  which plugs? Tuning a dsm isnt for everyone. If you want us to tune it on the wideband for the street give me a call (701)282-2902</p>
<p dir="auto">PS. Please done Reck that Nice Spendy Engine!!! Good Luck!<br />
Kevin<br />
sls</p>
]]></description><link>https://fargostreet.com/post/24971</link><guid isPermaLink="true">https://fargostreet.com/post/24971</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Wed, 19 Jan 2005 00:54:00 GMT</pubDate></item><item><title><![CDATA[Reply to Knock problems on Tue, 18 Jan 2005 23:53:14 GMT]]></title><description><![CDATA[<p dir="auto">Yeah, i wouldn't be paying any attention to that because whoever hooked it up obviously didn't do it right.  The most possible know that can be record is 43.</p>
]]></description><link>https://fargostreet.com/post/24961</link><guid isPermaLink="true">https://fargostreet.com/post/24961</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Tue, 18 Jan 2005 23:53:14 GMT</pubDate></item><item><title><![CDATA[Reply to Knock problems on Tue, 18 Jan 2005 22:34:41 GMT]]></title><description><![CDATA[<p dir="auto">the most knock ive seen is 207 in 3rd gear at 5500 rpm. I was going to do a knock sensor led or something, but ive heard theres no point.</p>
]]></description><link>https://fargostreet.com/post/24945</link><guid isPermaLink="true">https://fargostreet.com/post/24945</guid><dc:creator><![CDATA[92TSIpos]]></dc:creator><pubDate>Tue, 18 Jan 2005 22:34:41 GMT</pubDate></item><item><title><![CDATA[Reply to Knock problems on Mon, 17 Jan 2005 18:06:59 GMT]]></title><description><![CDATA[<p dir="auto">your afc says you're knocking? is that your only means of checking this out?  because i've read that the afc is not a good source of knock info.  in fact, in my car, it is WAY off, so i ignore it</p>
]]></description><link>https://fargostreet.com/post/24673</link><guid isPermaLink="true">https://fargostreet.com/post/24673</guid><dc:creator><![CDATA[out there]]></dc:creator><pubDate>Mon, 17 Jan 2005 18:06:59 GMT</pubDate></item><item><title><![CDATA[Reply to Knock problems on Mon, 17 Jan 2005 16:45:29 GMT]]></title><description><![CDATA[<p dir="auto">What wire did you tap into @ the ECU?  How much knock are you seeing?</p>
]]></description><link>https://fargostreet.com/post/24651</link><guid isPermaLink="true">https://fargostreet.com/post/24651</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Mon, 17 Jan 2005 16:45:29 GMT</pubDate></item></channel></rss>
