<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Joels properly set welder VS Mine........]]></title><description><![CDATA[<p dir="auto">Start my own little thread so i don't piss parker off by putting it in his thread.</p>
<p dir="auto">Just wanted to point out that Spatter is not present when a GMAW machine is set correctly, and in different techniques.</p>
<p dir="auto">I used mild 1/4" mild steel and 2.5" exhaust pipe scrap, very similar to the materials joel used........... Also .030 wire well below 100 amps, so well within the range of the welder joel used............</p>
<p dir="auto">I have another welder setup with .020 wire at the other farm, and it would of done a better job than this even, but i was welding on a tender truck and just did this after i was done</p>
<p dir="auto">K so pics to prove material used</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/welding003.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/welding005.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">So this is what we are comparing it to.......Joel's</p>
<p dir="auto"><img src="http://img.photobucket.com/albums/v294/atmospere_adikt/DSC00163.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v294/atmospere_adikt/DSC00162-1.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
notice on joel's  that there is not nearly enough manipulation of the electrode and obviously the machine is not set correctly. Also look at the bead, the manipulation (movement back/forth) is very inconsistent and varying. Contrasting look at mine, very tight  movments that are very uniform and consistent<br />
.<br />
.<br />
.<br />
.<br />
.<br />
And mine,<br />
First bead is just your regular horizontal steady burn with manipulation...</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/welding007.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Next bead is a triggered method, on-off-on-off...... with manipulation</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/welding010.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Last is what should be the nicest bead, Vertical Down, but the wire speed should of been down a little</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/welding012.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Oh, yeah i just used a hand wire brush to remove the smoke/stain to show the weld, and note that there is no undercut on either member even with a large difference in thickness. Look at how the edges tie in showing good penetration and enough amperage. And put my initials on it to prove</p>
<p dir="auto">And if any of those welds broke because of "lack of penetration" i would blow any chosen guy</p>
<p dir="auto">Yep i like being an asshole <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/topic/13556/joels-properly-set-welder-vs-mine........</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 20:33:45 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/13556.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Mar 2008 01:56:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 15:35:37 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Afsil80;211591 wrote:<br />
Faber, you're the LAST person that should be correcting people when it comes to grammar and spelling.</p>
<p dir="auto">Beat me to it!</p>
]]></description><link>https://fargostreet.com/post/200318</link><guid isPermaLink="true">https://fargostreet.com/post/200318</guid><dc:creator><![CDATA[StangerBanger96]]></dc:creator><pubDate>Thu, 27 Mar 2008 15:35:37 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 13:51:04 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Parker;211615 wrote:<br />
piss off</p>
<p dir="auto">:pickle:</p>
]]></description><link>https://fargostreet.com/post/200307</link><guid isPermaLink="true">https://fargostreet.com/post/200307</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Thu, 27 Mar 2008 13:51:04 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 07:06:59 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">MisterCMK;211556 wrote:</p>
<ul>
<li>they're</li>
<li>long<br />
piss off</li>
</ul>
]]></description><link>https://fargostreet.com/post/200298</link><guid isPermaLink="true">https://fargostreet.com/post/200298</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Thu, 27 Mar 2008 07:06:59 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 06:27:46 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">+1...I think he missed a few classes in high school...how he made it to college I have no clue...lol</p>
]]></description><link>https://fargostreet.com/post/200290</link><guid isPermaLink="true">https://fargostreet.com/post/200290</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Thu, 27 Mar 2008 06:27:46 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 04:49:58 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">LOL!</p>
]]></description><link>https://fargostreet.com/post/200278</link><guid isPermaLink="true">https://fargostreet.com/post/200278</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Thu, 27 Mar 2008 04:49:58 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 04:42:21 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">weshole;211568 wrote:<br />
You all can thank me later.</p>
<p dir="auto">hey its later...thanks wes! lol</p>
]]></description><link>https://fargostreet.com/post/200276</link><guid isPermaLink="true">https://fargostreet.com/post/200276</guid><dc:creator><![CDATA[King Ricer]]></dc:creator><pubDate>Thu, 27 Mar 2008 04:42:21 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 04:39:41 GMT]]></title><description><![CDATA[<p dir="auto">Faber, you're the LAST person that should be correcting people when it comes to grammar and spelling.</p>
]]></description><link>https://fargostreet.com/post/200274</link><guid isPermaLink="true">https://fargostreet.com/post/200274</guid><dc:creator><![CDATA[Afsil80]]></dc:creator><pubDate>Thu, 27 Mar 2008 04:39:41 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 03:07:56 GMT]]></title><description><![CDATA[<p dir="auto">um....thanx?</p>
]]></description><link>https://fargostreet.com/post/200252</link><guid isPermaLink="true">https://fargostreet.com/post/200252</guid><dc:creator><![CDATA[itRfan]]></dc:creator><pubDate>Thu, 27 Mar 2008 03:07:56 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 03:06:17 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">KA-T_240;211566 wrote:<br />
O snap!</p>
<p dir="auto">It is in RYM now. Let the fight begin!</p>
<p dir="auto">You all can thank me later.</p>
]]></description><link>https://fargostreet.com/post/200251</link><guid isPermaLink="true">https://fargostreet.com/post/200251</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Thu, 27 Mar 2008 03:06:17 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 03:00:52 GMT]]></title><description><![CDATA[<p dir="auto">O snap!</p>
]]></description><link>https://fargostreet.com/post/200249</link><guid isPermaLink="true">https://fargostreet.com/post/200249</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Thu, 27 Mar 2008 03:00:52 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 02:48:51 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">MisterCMK;211564 wrote:<br />
Get back in your hole</p>
<p dir="auto">:icon_salut:</p>
]]></description><link>https://fargostreet.com/post/200248</link><guid isPermaLink="true">https://fargostreet.com/post/200248</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Thu, 27 Mar 2008 02:48:51 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 02:32:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">DrifterExtreme;211562 wrote:<br />
^^^ umm no one cares</p>
<p dir="auto">Get back in your hole</p>
]]></description><link>https://fargostreet.com/post/200247</link><guid isPermaLink="true">https://fargostreet.com/post/200247</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Thu, 27 Mar 2008 02:32:20 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 02:28:19 GMT]]></title><description><![CDATA[<p dir="auto">^^^ umm no one cares</p>
]]></description><link>https://fargostreet.com/post/200245</link><guid isPermaLink="true">https://fargostreet.com/post/200245</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Thu, 27 Mar 2008 02:28:19 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 02:26:52 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">KA-T_240;211559 wrote:<br />
^You missed don't(also more professional as do not)</p>
<p dir="auto">No, I did not miss it.  I was simply correcting his pathetic spelling and word choice.</p>
]]></description><link>https://fargostreet.com/post/200244</link><guid isPermaLink="true">https://fargostreet.com/post/200244</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Thu, 27 Mar 2008 02:26:52 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 02:10:29 GMT]]></title><description><![CDATA[<p dir="auto">^You missed don't(also more professional as do not)</p>
]]></description><link>https://fargostreet.com/post/200242</link><guid isPermaLink="true">https://fargostreet.com/post/200242</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Thu, 27 Mar 2008 02:10:29 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 01:56:38 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Parker;211415 wrote:<br />
man you guys are brutal... i could care less what exhaust welds looks like, there under a car... and as loing as they dont crack, i dont give a shit.....</p>
<ul>
<li>they're</li>
<li>long</li>
</ul>
]]></description><link>https://fargostreet.com/post/200239</link><guid isPermaLink="true">https://fargostreet.com/post/200239</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Thu, 27 Mar 2008 01:56:38 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Thu, 27 Mar 2008 01:40:36 GMT]]></title><description><![CDATA[<p dir="auto">its an old school ESAB</p>
<p dir="auto">id take the one you were using any day over this</p>
]]></description><link>https://fargostreet.com/post/200237</link><guid isPermaLink="true">https://fargostreet.com/post/200237</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Thu, 27 Mar 2008 01:40:36 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Wed, 26 Mar 2008 23:28:47 GMT]]></title><description><![CDATA[<p dir="auto">to play devils advicate... i want pictures of you welder zac :rolleyes:</p>
]]></description><link>https://fargostreet.com/post/200223</link><guid isPermaLink="true">https://fargostreet.com/post/200223</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Wed, 26 Mar 2008 23:28:47 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Wed, 26 Mar 2008 23:25:54 GMT]]></title><description><![CDATA[<p dir="auto">i was waiting for someone to say that....</p>
]]></description><link>https://fargostreet.com/post/200222</link><guid isPermaLink="true">https://fargostreet.com/post/200222</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Wed, 26 Mar 2008 23:25:54 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Wed, 26 Mar 2008 20:35:12 GMT]]></title><description><![CDATA[<p dir="auto">My welds can beat up your welds.</p>
]]></description><link>https://fargostreet.com/post/200201</link><guid isPermaLink="true">https://fargostreet.com/post/200201</guid><dc:creator><![CDATA[Sweet-WRX-Lovin]]></dc:creator><pubDate>Wed, 26 Mar 2008 20:35:12 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Tue, 25 Mar 2008 23:04:35 GMT]]></title><description><![CDATA[<p dir="auto">it wasnt a shitty weld though, The penetration was good, I am happy with the weld given the equiptmentused. I posted to as a picture of parkers exhaust in his exhast thread.</p>
]]></description><link>https://fargostreet.com/post/200104</link><guid isPermaLink="true">https://fargostreet.com/post/200104</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Tue, 25 Mar 2008 23:04:35 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Tue, 25 Mar 2008 22:19:48 GMT]]></title><description><![CDATA[<p dir="auto">triple posting FTL...oh and the welds are...alright...lol</p>
]]></description><link>https://fargostreet.com/post/200099</link><guid isPermaLink="true">https://fargostreet.com/post/200099</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Tue, 25 Mar 2008 22:19:48 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Tue, 25 Mar 2008 22:11:17 GMT]]></title><description><![CDATA[<p dir="auto">man you guys are brutal... i could care less what exhaust welds looks like, there under a car... and as loing as they dont crack, i dont give a shit.....</p>
]]></description><link>https://fargostreet.com/post/200098</link><guid isPermaLink="true">https://fargostreet.com/post/200098</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Tue, 25 Mar 2008 22:11:17 GMT</pubDate></item><item><title><![CDATA[Reply to Joels properly set welder VS Mine........ on Tue, 25 Mar 2008 15:06:23 GMT]]></title><description><![CDATA[<p dir="auto">You can both weld better than I can.  Damn.</p>
]]></description><link>https://fargostreet.com/post/200051</link><guid isPermaLink="true">https://fargostreet.com/post/200051</guid><dc:creator><![CDATA[Colin]]></dc:creator><pubDate>Tue, 25 Mar 2008 15:06:23 GMT</pubDate></item></channel></rss>
