<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Torque wrench info]]></title><description><![CDATA[<p dir="auto">I found this today and thought it was kind of interesting.</p>
<p dir="auto">The Proper use of a Torque Wrench</p>
<p dir="auto">Many times I have heard people complain that these come loose (Control arms are an example). I ask if they torqued to factory specs and I always get the "Yes I did..", then I ask if they adjusted for the preload (frictional drag torque) on the nut. "Huh???" There torque is inevitably lower than factory because they forgot this point.</p>
<p dir="auto">Stated torque measurements factor in the frictional force of clean parts, so make certain that everything is clean, and has no burrs. Measuring for Pre-load (frictional drag torque) is fairly easy in theory. The textbook way assumes that you are screwing the nut onto a stationary bolt or thread; we all know this doesn't work, since our stuff is not stationary. Here is the easiest way to do it. Jam the bolt head with a wrench against something so that it won't move. Don't hold it in your hand, since you will have some give there, and may get an inaccurate measurement. Take the nut and screw it on until it stops (hand tight), then take the torque wrench and turn the nut. Start with the lowest setting and work your way up if you are using a micrometer torque, if you are using a beam style, just watch the pointer, the point at which the nut turns is the pre-load (frictional drag torque). You then just add this to the torque you want to go to. i.e. 10ft/lb pre-load (frictional drag torque) + 100ft/lb torque setting = 110ft/lb setting on the torque wrench. There is another pre-load computation for bolts based upon tension/torsion/bolt stretch/ friction/ etc... I really don't want to get into that side, since it really doesn't have a purpose in our application. For those of us with torque wrenches, here is something that I forget to do also. Something to keep in mind when we use them.</p>
<p dir="auto">Preloading a torque wrench is an important to the overall accuracy. It must be performed each time the torque wrench is used after periods of non-use or whenever torque direction is changed. There are several reasons for preloading your torque wrench. First, it will set internal components so that when force is applied, torque begins immediately with no internal settling. Second, it distributes lubrication to moving internal parts.</p>
<p dir="auto">How to do it:</p>
<ol>
<li>Set torque wrench between 50 percent and 100 percent of full scale.</li>
<li>Mount torque drive in a stationary fixture (i.e. socket welded to bench, vise).</li>
<li>Exercise the torque wrench three to five times in the direction you will be verifying.</li>
<li>Perform torque measurement.</li>
</ol>
<p dir="auto">Remember to store torque wrenches (click-type) in the low setting. Otherwise calibration will be needed at shorter intervals. You should have your torque wrenches calibrated yearly for accuracy, but it can be costly, so most of us don't do it. I admit that mine are not any longer.</p>
]]></description><link>https://fargostreet.com/topic/13729/torque-wrench-info</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 17:12:39 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/13729.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Apr 2008 03:01:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Torque wrench info on Sun, 13 Apr 2008 22:06:56 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">KA-T_240;214346 wrote:<br />
^Pretty sure they do down here also. There is probably a reason why every torque wrench at our shop and in our person tools is snap on.</p>
<p dir="auto">Nevermind the fact that you guys probably have a snap on truck and lines of credit.</p>
]]></description><link>https://fargostreet.com/post/203079</link><guid isPermaLink="true">https://fargostreet.com/post/203079</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sun, 13 Apr 2008 22:06:56 GMT</pubDate></item><item><title><![CDATA[Reply to Torque wrench info on Sun, 13 Apr 2008 22:06:29 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">z31;214332 wrote:<br />
:deal:  Buy a SnapOn and dissregaurd all that bullshit.  :icon_bigsmurf:</p>
<p dir="auto">Wrong.</p>
]]></description><link>https://fargostreet.com/post/203077</link><guid isPermaLink="true">https://fargostreet.com/post/203077</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sun, 13 Apr 2008 22:06:29 GMT</pubDate></item><item><title><![CDATA[Reply to Torque wrench info on Sun, 13 Apr 2008 17:10:49 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f4a3.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--bomb" style="height:23px;width:auto;vertical-align:middle" title=":bomb:" alt="💣" /></p>
]]></description><link>https://fargostreet.com/post/203047</link><guid isPermaLink="true">https://fargostreet.com/post/203047</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Sun, 13 Apr 2008 17:10:49 GMT</pubDate></item><item><title><![CDATA[Reply to Torque wrench info on Sun, 13 Apr 2008 13:32:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Parker;214359 wrote:<br />
in order for a torque wrench to be accurate, it needs to be clicked 3-4 times.... i know at catapiler they have a bench with a bunch of welded down nuts, so people can go over there and click their torque wrench a couple times before they use it...</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/bsflag.gif" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">pics or BS............</p>
<p dir="auto"><img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://fargostreet.com/post/203030</link><guid isPermaLink="true">https://fargostreet.com/post/203030</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sun, 13 Apr 2008 13:32:11 GMT</pubDate></item><item><title><![CDATA[Reply to Torque wrench info on Sun, 13 Apr 2008 10:38:32 GMT]]></title><description><![CDATA[<p dir="auto">Perhaps I shall click my torque wrench 6 times tomorrow afternoon.</p>
<p dir="auto">Perhaps.</p>
]]></description><link>https://fargostreet.com/post/203027</link><guid isPermaLink="true">https://fargostreet.com/post/203027</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Sun, 13 Apr 2008 10:38:32 GMT</pubDate></item><item><title><![CDATA[Reply to Torque wrench info on Sun, 13 Apr 2008 08:34:21 GMT]]></title><description><![CDATA[<p dir="auto">in order for a torque wrench to be accurate, it needs to be clicked 3-4 times.... i know at catapiler they have a bench with a bunch of welded down nuts, so people can go over there and click their torque wrench a couple times before they use it...</p>
]]></description><link>https://fargostreet.com/post/203022</link><guid isPermaLink="true">https://fargostreet.com/post/203022</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Sun, 13 Apr 2008 08:34:21 GMT</pubDate></item><item><title><![CDATA[Reply to Torque wrench info on Sun, 13 Apr 2008 06:36:09 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">revolutionz_s13;214345 wrote:<br />
snap on will recalibrate their torque wrenchs for free...at least up here they do</p>
<p dir="auto">^Pretty sure they do down here also. There is probably a reason why every torque wrench at our shop and in our person tools is snap on.</p>
]]></description><link>https://fargostreet.com/post/203009</link><guid isPermaLink="true">https://fargostreet.com/post/203009</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Sun, 13 Apr 2008 06:36:09 GMT</pubDate></item><item><title><![CDATA[Reply to Torque wrench info on Sun, 13 Apr 2008 06:11:33 GMT]]></title><description><![CDATA[<p dir="auto">snap on will recalibrate their torque wrenchs for free...at least up here they do</p>
]]></description><link>https://fargostreet.com/post/203008</link><guid isPermaLink="true">https://fargostreet.com/post/203008</guid><dc:creator><![CDATA[revolutionz_s13]]></dc:creator><pubDate>Sun, 13 Apr 2008 06:11:33 GMT</pubDate></item><item><title><![CDATA[Reply to Torque wrench info on Sun, 13 Apr 2008 05:50:08 GMT]]></title><description><![CDATA[<blockquote>
:deal:  Buy a SnapOn and dissregaurd all that bullshit.  :icon_bigsmurf:<br />
ummmm... wrong....</p>
]]></description><link>https://fargostreet.com/post/203002</link><guid isPermaLink="true">https://fargostreet.com/post/203002</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Sun, 13 Apr 2008 05:50:08 GMT</pubDate></item><item><title><![CDATA[Reply to Torque wrench info on Sun, 13 Apr 2008 03:47:58 GMT]]></title><description><![CDATA[<p dir="auto">:deal:  Buy a SnapOn and dissregaurd all that bullshit.  :icon_bigsmurf:</p>
]]></description><link>https://fargostreet.com/post/202995</link><guid isPermaLink="true">https://fargostreet.com/post/202995</guid><dc:creator><![CDATA[z31]]></dc:creator><pubDate>Sun, 13 Apr 2008 03:47:58 GMT</pubDate></item></channel></rss>
