<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Civic Problem]]></title><description><![CDATA[<p dir="auto">Ok my check engine light came on recently on my 97 civic and the codes were p301-misfire1,p302-misfire 2, p1300 and, p1399. i put new plugs and wires and the cap and rotor looked fine.  so after that it still was running rough. i pulled the wires out one at a time and the cylinder2 wire made no change while it ran. so i thought it could be a bad injector but that wasnt it. so now im lost. I get spark, there is no sign of anti-freeze in the oil. Do anyone of you guys have any ideas on what it could be?  thanks</p>
]]></description><link>https://fargostreet.com/topic/13825/civic-problem</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 09:02:54 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/13825.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Apr 2008 20:36:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Civic Problem on Tue, 22 Apr 2008 21:50:37 GMT]]></title><description><![CDATA[<p dir="auto">Sounds like u got a dead cylinder on your hands.</p>
]]></description><link>https://fargostreet.com/post/204503</link><guid isPermaLink="true">https://fargostreet.com/post/204503</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Tue, 22 Apr 2008 21:50:37 GMT</pubDate></item><item><title><![CDATA[Reply to Civic Problem on Tue, 22 Apr 2008 21:29:35 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Rexwagon;215834 wrote:<br />
you can bring it over later and I will help you work on it.</p>
<p dir="auto">thats if it makes it. lol that thing has been running like ass. i have just been driving the 99 around. i dont want to wreck it any more then i have to.... or i can blow up the motor and do another swap!!</p>
]]></description><link>https://fargostreet.com/post/204498</link><guid isPermaLink="true">https://fargostreet.com/post/204498</guid><dc:creator><![CDATA[99civic]]></dc:creator><pubDate>Tue, 22 Apr 2008 21:29:35 GMT</pubDate></item><item><title><![CDATA[Reply to Civic Problem on Tue, 22 Apr 2008 21:22:26 GMT]]></title><description><![CDATA[<p dir="auto">you can bring it over later and I will help you work on it.</p>
]]></description><link>https://fargostreet.com/post/204497</link><guid isPermaLink="true">https://fargostreet.com/post/204497</guid><dc:creator><![CDATA[Rexwagon]]></dc:creator><pubDate>Tue, 22 Apr 2008 21:22:26 GMT</pubDate></item><item><title><![CDATA[Reply to Civic Problem on Tue, 22 Apr 2008 21:16:13 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">KA-T_240;215829 wrote:<br />
Injector o-rings, stuck open injector.....</p>
<p dir="auto">Its either missing cause its not getting spark(at all or not at right time), No compression, To much or no fuel.</p>
<p dir="auto">put in new o-rings, all the injectors looked fine other then just a little build up on the ends. i guess ill have to try a compression test.</p>
]]></description><link>https://fargostreet.com/post/204495</link><guid isPermaLink="true">https://fargostreet.com/post/204495</guid><dc:creator><![CDATA[99civic]]></dc:creator><pubDate>Tue, 22 Apr 2008 21:16:13 GMT</pubDate></item><item><title><![CDATA[Reply to Civic Problem on Tue, 22 Apr 2008 21:13:59 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Bookem;215828 wrote:<br />
If it started misfiring after the plug change. Double check the gap, if it's right on just try switching plugs from a different cylinder and see if the miss carries with the plug.</p>
<p dir="auto">no at misfired b4 the new plugs and i made sure they were gapped right.</p>
]]></description><link>https://fargostreet.com/post/204493</link><guid isPermaLink="true">https://fargostreet.com/post/204493</guid><dc:creator><![CDATA[99civic]]></dc:creator><pubDate>Tue, 22 Apr 2008 21:13:59 GMT</pubDate></item><item><title><![CDATA[Reply to Civic Problem on Tue, 22 Apr 2008 21:01:15 GMT]]></title><description><![CDATA[<p dir="auto">Injector o-rings, stuck open injector.....</p>
]]></description><link>https://fargostreet.com/post/204492</link><guid isPermaLink="true">https://fargostreet.com/post/204492</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Tue, 22 Apr 2008 21:01:15 GMT</pubDate></item><item><title><![CDATA[Reply to Civic Problem on Tue, 22 Apr 2008 20:59:58 GMT]]></title><description><![CDATA[<p dir="auto">If it started misfiring after the plug change. Double check the gap, if it's right on just try switching plugs from a different cylinder and see if the miss carries with the plug.</p>
]]></description><link>https://fargostreet.com/post/204491</link><guid isPermaLink="true">https://fargostreet.com/post/204491</guid><dc:creator><![CDATA[Bookem]]></dc:creator><pubDate>Tue, 22 Apr 2008 20:59:58 GMT</pubDate></item></channel></rss>
