<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[OBD1 honda parts]]></title><description><![CDATA[<p dir="auto">I need the following still for my mini me swap:</p>
<p dir="auto">OBD1 d16y8 distributor (rotor, cap, etc)<br />
OBD1 distributor harness<br />
vtec solenoid harness<br />
OBD0 to OBD1 jumper harness<br />
wideband o2 setup</p>
<p dir="auto">if you have anything you want to sell let me know a price, thanks!</p>
]]></description><link>https://fargostreet.com/topic/13829/obd1-honda-parts</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 09:24:31 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/13829.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Apr 2008 05:19:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to OBD1 honda parts on Mon, 12 May 2008 05:20:19 GMT]]></title><description><![CDATA[<p dir="auto">I have an OBD1 Z6 dizzy...if you need it, PM me an offer</p>
]]></description><link>https://fargostreet.com/post/207233</link><guid isPermaLink="true">https://fargostreet.com/post/207233</guid><dc:creator><![CDATA[GreenLantern]]></dc:creator><pubDate>Mon, 12 May 2008 05:20:19 GMT</pubDate></item><item><title><![CDATA[Reply to OBD1 honda parts on Thu, 24 Apr 2008 23:44:38 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">SPANISH-RICE;216219 wrote:<br />
which aslo brings up a question from me. im running a y7 block with a z6 head and as far as i know i use the timing belt that corresponds with the head correct? it just seems like my z6 belt has alot of slack in it</p>
<p dir="auto">yup, belt goes with the cam gear (I had a Z6 cam on a Y8 head with a Y8 cam gear and used a Y8 belt)...your belt OEM brandon? I'm guessing so but idk.</p>
]]></description><link>https://fargostreet.com/post/204922</link><guid isPermaLink="true">https://fargostreet.com/post/204922</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Thu, 24 Apr 2008 23:44:38 GMT</pubDate></item><item><title><![CDATA[Reply to OBD1 honda parts on Thu, 24 Apr 2008 20:59:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">torbs;216214 wrote:<br />
Don't forget John, you need OBD1 injectors as well (i believe?)<br />
Also, you'll want a Y8 timing belt.</p>
<p dir="auto">which aslo brings up a question from me. im running a y7 block with a z6 head and as far as i know i use the timing belt that corresponds with the head correct? it just seems like my z6 belt has alot of slack in it</p>
]]></description><link>https://fargostreet.com/post/204878</link><guid isPermaLink="true">https://fargostreet.com/post/204878</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Thu, 24 Apr 2008 20:59:12 GMT</pubDate></item><item><title><![CDATA[Reply to OBD1 honda parts on Thu, 24 Apr 2008 20:56:48 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">JohnW;215986 wrote:<br />
no, i mean a wideband.  im going to be running a p28 w/ ostrich, and chrome pro.  to start, im just going to use a p30 rom with the p28 basemap (p30 has datalogging enabled), but with the little bit higher compression, and the fact that I don't know how much this a6/y8 combo is going to mess with ignition timing, i'd rather know whats up with my a/f ratio.  i can tune using knock counts like on the dsm however i have no knock sensor and im not sure if the p28 can be made to read a knock sensor or not.</p>
<p dir="auto">As for the dizzy, I guess any sohc dizzy will work except the z6 (different bolt pattern), it's just a matter of the wiring.  wiring I can do <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">o damn someone doing something the right way with a honda around here for a change... +1 for you man. i cant wait to see this car</p>
]]></description><link>https://fargostreet.com/post/204877</link><guid isPermaLink="true">https://fargostreet.com/post/204877</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Thu, 24 Apr 2008 20:56:48 GMT</pubDate></item><item><title><![CDATA[Reply to OBD1 honda parts on Thu, 24 Apr 2008 20:54:34 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">I have both.</p>
]]></description><link>https://fargostreet.com/post/204876</link><guid isPermaLink="true">https://fargostreet.com/post/204876</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Thu, 24 Apr 2008 20:54:34 GMT</pubDate></item><item><title><![CDATA[Reply to OBD1 honda parts on Thu, 24 Apr 2008 20:49:21 GMT]]></title><description><![CDATA[<p dir="auto">Don't forget John, you need OBD1 injectors as well (i believe?)<br />
]]></description><link>https://fargostreet.com/post/204873</link><guid isPermaLink="true">https://fargostreet.com/post/204873</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Thu, 24 Apr 2008 20:49:21 GMT</pubDate></item><item><title><![CDATA[Reply to OBD1 honda parts on Wed, 23 Apr 2008 21:01:01 GMT]]></title><description><![CDATA[<p dir="auto">That is why i said, if you get a Z6 dizzy, i could trade you housings cuz i have y8 housing.</p>
]]></description><link>https://fargostreet.com/post/204646</link><guid isPermaLink="true">https://fargostreet.com/post/204646</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Wed, 23 Apr 2008 21:01:01 GMT</pubDate></item><item><title><![CDATA[Reply to OBD1 honda parts on Wed, 23 Apr 2008 20:30:14 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">bubba;215938 wrote:<br />
I ordered my jumper harness through Tintmasters... its obd0-obd1 vtec, has all the extra wires, and ran me $90 or so, which was a pretty good deal.</p>
<p dir="auto">Also by wideband 02, arent u meaning 4 wire o2... dont need a wideband unless ur boosting it or something</p>
<p dir="auto">no, i mean a wideband.  im going to be running a p28 w/ ostrich, and chrome pro.  to start, im just going to use a p30 rom with the p28 basemap (p30 has datalogging enabled), but with the little bit higher compression, and the fact that I don't know how much this a6/y8 combo is going to mess with ignition timing, i'd rather know whats up with my a/f ratio.  i can tune using knock counts like on the dsm however i have no knock sensor and im not sure if the p28 can be made to read a knock sensor or not.</p>
]]></description><link>https://fargostreet.com/post/204645</link><guid isPermaLink="true">https://fargostreet.com/post/204645</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Wed, 23 Apr 2008 20:30:14 GMT</pubDate></item><item><title><![CDATA[Reply to OBD1 honda parts on Wed, 23 Apr 2008 15:02:11 GMT]]></title><description><![CDATA[<p dir="auto">OBD-1 D16Y8s are really rare. You need a Y8 housing with Z6 internals im guessing. If you find a Z6 dizzy, i could probly trade you housings cuz i have a y8 but i need the internals( you would have the internals you need with y8 housing). I also have probably most wiring that you need.</p>
]]></description><link>https://fargostreet.com/post/204599</link><guid isPermaLink="true">https://fargostreet.com/post/204599</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Wed, 23 Apr 2008 15:02:11 GMT</pubDate></item><item><title><![CDATA[Reply to OBD1 honda parts on Wed, 23 Apr 2008 14:57:37 GMT]]></title><description><![CDATA[<p dir="auto">I ordered my jumper harness through Tintmasters... its obd0-obd1 vtec, has all the extra wires, and ran me $90 or so, which was a pretty good deal.</p>
]]></description><link>https://fargostreet.com/post/204597</link><guid isPermaLink="true">https://fargostreet.com/post/204597</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Wed, 23 Apr 2008 14:57:37 GMT</pubDate></item><item><title><![CDATA[Reply to OBD1 honda parts on Wed, 23 Apr 2008 10:02:48 GMT]]></title><description><![CDATA[<p dir="auto">it's already converted to mpfi.  I suppose I could wire it back but rewiring all that stuff doesn't sound like fun <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" />  thanks alot tho!</p>
]]></description><link>https://fargostreet.com/post/204592</link><guid isPermaLink="true">https://fargostreet.com/post/204592</guid><dc:creator><![CDATA[JohnW]]></dc:creator><pubDate>Wed, 23 Apr 2008 10:02:48 GMT</pubDate></item><item><title><![CDATA[Reply to OBD1 honda parts on Wed, 23 Apr 2008 07:44:11 GMT]]></title><description><![CDATA[<p dir="auto">i know my friend has a boomslang obd0 dpfi to mpfi  0bd1 vtec. ita a killer harness. i dont think hes using it. send em a pm his username is gsrEK on here</p>
]]></description><link>https://fargostreet.com/post/204586</link><guid isPermaLink="true">https://fargostreet.com/post/204586</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Wed, 23 Apr 2008 07:44:11 GMT</pubDate></item></channel></rss>
