<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[wiring problem in 89 civic]]></title><description><![CDATA[<p dir="auto">I kind of just bought a 89 civic 4 dr. Everything worked fine until the other day when I turned my lights on. The intrament cluster lights didn't turn on along with my taillights. I checked that fuse and both lights are under the same fuse. The fuse was popped but everytime I put a new one in, it pops it again. Whats the best and easiest way to start looking for a bad wire?  Any help would be great!  Thanks</p>
]]></description><link>https://fargostreet.com/topic/14025/wiring-problem-in-89-civic</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 00:02:17 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/14025.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 May 2008 16:01:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to wiring problem in 89 civic on Mon, 19 May 2008 03:04:38 GMT]]></title><description><![CDATA[<p dir="auto">i've got a chilton's for the civic if you need a wiring diagram.  otherwise i'm sure they're all over online. good luck.  I hate fixing wiring issues almost as much as I hate doing anything at all with plumbing.  =D</p>
]]></description><link>https://fargostreet.com/post/207961</link><guid isPermaLink="true">https://fargostreet.com/post/207961</guid><dc:creator><![CDATA[harm]]></dc:creator><pubDate>Mon, 19 May 2008 03:04:38 GMT</pubDate></item><item><title><![CDATA[Reply to wiring problem in 89 civic on Wed, 14 May 2008 01:04:18 GMT]]></title><description><![CDATA[<p dir="auto">check the stereo wiring, it's common for a shitty stereo wiring job to take out that fuse.</p>
]]></description><link>https://fargostreet.com/post/207452</link><guid isPermaLink="true">https://fargostreet.com/post/207452</guid><dc:creator><![CDATA[darkelvis]]></dc:creator><pubDate>Wed, 14 May 2008 01:04:18 GMT</pubDate></item></channel></rss>
