<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[dsm problem..... big suprise]]></title><description><![CDATA[<p dir="auto">So this ia the situation, after last last sundays incident with ohms dsm his std coolant ran under my car and now it pulls hard to the right hardcore under hard acceleration and jerks back after i let off... I havent hit anything so nothing should be bent... Also the drivers lower ball joint has stripped threads so the lower control arm moves. That a possible culprit? Fyi i am ordering a balljoint 2day anyway... Lmk HELP haha</p>
]]></description><link>https://fargostreet.com/topic/14093/dsm-problem.....-big-suprise</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 13:05:59 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/14093.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 May 2008 23:06:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to dsm problem..... big suprise on Wed, 28 May 2008 07:13:58 GMT]]></title><description><![CDATA[<p dir="auto">Forgot to post earlier... Replaced the balljoint and shes good to go.. Section of the threads was stripped so the control arm had up and down play... 20 dollar ball joint and a hammer got her in and out in about an hour</p>
]]></description><link>https://fargostreet.com/post/209075</link><guid isPermaLink="true">https://fargostreet.com/post/209075</guid><dc:creator><![CDATA[blackcherryTSi]]></dc:creator><pubDate>Wed, 28 May 2008 07:13:58 GMT</pubDate></item><item><title><![CDATA[Reply to dsm problem..... big suprise on Wed, 21 May 2008 11:27:31 GMT]]></title><description><![CDATA[<p dir="auto">On 2g's you cannot replace just the balljoint, however on 1g's you can.  On 2g's you have to buy the whole control arm.  Just need a BFH or a press;)</p>
]]></description><link>https://fargostreet.com/post/208281</link><guid isPermaLink="true">https://fargostreet.com/post/208281</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Wed, 21 May 2008 11:27:31 GMT</pubDate></item><item><title><![CDATA[Reply to dsm problem..... big suprise on Wed, 21 May 2008 02:17:37 GMT]]></title><description><![CDATA[<p dir="auto">ok. i believe it's pressed in. thats why i decided to take the easy way out and replace the whole control arm. maybe 1g are dif. ( i did a 2g) i don't know what you have.</p>
]]></description><link>https://fargostreet.com/post/208235</link><guid isPermaLink="true">https://fargostreet.com/post/208235</guid><dc:creator><![CDATA[black2g]]></dc:creator><pubDate>Wed, 21 May 2008 02:17:37 GMT</pubDate></item><item><title><![CDATA[Reply to dsm problem..... big suprise on Wed, 21 May 2008 01:26:42 GMT]]></title><description><![CDATA[<p dir="auto">I guess u can order just the ball joint so ill c what happens and as for driving it i have my mountain bike but id like to get my car fixed</p>
]]></description><link>https://fargostreet.com/post/208231</link><guid isPermaLink="true">https://fargostreet.com/post/208231</guid><dc:creator><![CDATA[blackcherryTSi]]></dc:creator><pubDate>Wed, 21 May 2008 01:26:42 GMT</pubDate></item><item><title><![CDATA[Reply to dsm problem..... big suprise on Wed, 21 May 2008 01:21:46 GMT]]></title><description><![CDATA[<p dir="auto">So you have a stripped ball joint and you are still driving the car?</p>
]]></description><link>https://fargostreet.com/post/208230</link><guid isPermaLink="true">https://fargostreet.com/post/208230</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Wed, 21 May 2008 01:21:46 GMT</pubDate></item><item><title><![CDATA[Reply to dsm problem..... big suprise on Wed, 21 May 2008 01:05:17 GMT]]></title><description><![CDATA[<p dir="auto">i believe the ball joint is part of the control arm on a dsm. i don't know if the ball joint can be ordered seperately. If that isn't "the" problem it is "one" problem that needs to be fixed. When i did mine i just replaced the whole lower control arm. not to bad of a job. post back after you replace it.</p>
]]></description><link>https://fargostreet.com/post/208227</link><guid isPermaLink="true">https://fargostreet.com/post/208227</guid><dc:creator><![CDATA[black2g]]></dc:creator><pubDate>Wed, 21 May 2008 01:05:17 GMT</pubDate></item><item><title><![CDATA[Reply to dsm problem..... big suprise on Wed, 21 May 2008 01:02:47 GMT]]></title><description><![CDATA[<p dir="auto">HAHAHA! My car gave your car herpes! Shes a dirty little bitch.</p>
]]></description><link>https://fargostreet.com/post/208225</link><guid isPermaLink="true">https://fargostreet.com/post/208225</guid><dc:creator><![CDATA[D S ohM]]></dc:creator><pubDate>Wed, 21 May 2008 01:02:47 GMT</pubDate></item></channel></rss>
