<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My In-Car Entertainment (Work In Progress)]]></title><description><![CDATA[<p dir="auto">So, I finally got all the parts I needed for my In-Car Entertainment! Yay me, so now I'm in the progress of installing everything. Thought I'd let you know what I'm doing!</p>
<p dir="auto"><strong>Headunit:</strong> 7" Lilliput LCD Touch Screen with LED Blacklit</p>
<p dir="auto"><strong>Amplifers:</strong> Kicker 400.1 KX Mono, Alpine MRP-300 4-channel</p>
<p dir="auto"><strong>Speakers:</strong> Sticking with the stock Monsoon System, but upgrading to 5 1/4 Alpine Type-R's, and 6x9 Alpine Type-R's next month(s)</p>
<p dir="auto"><strong>Subs:</strong> 2x Alpine Type-R 2Ohm</p>
<p dir="auto">Now, I am then mounting my laptop in the trunk and plugging that into my screen. So, essentially, I'm running a computer in the car!</p>
<p dir="auto">GPS, XM, and FM Tuner's are plugging into the USB, and I'm also running two USB cables to my rear pillars so you can hook up USB joypads and play games (Mame, N64, Nebula, NES)</p>
<p dir="auto">I'll provide pics next week when my car comes back from the body shop (getting my door repaired as some assholes broke into it and stole my old Type-R's)</p>
]]></description><link>https://fargostreet.com/topic/14141/my-in-car-entertainment-work-in-progress</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:22:24 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/14141.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 May 2008 03:01:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Sun, 10 Aug 2008 06:11:24 GMT]]></title><description><![CDATA[<p dir="auto">Or it is running too small of gauge of wire....what gauge power cable are you using?</p>
]]></description><link>https://fargostreet.com/post/219368</link><guid isPermaLink="true">https://fargostreet.com/post/219368</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sun, 10 Aug 2008 06:11:24 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Sat, 09 Aug 2008 17:03:27 GMT]]></title><description><![CDATA[<p dir="auto">Typically, if the amp shuts down thermally.... It wasn't designed for the loads that its being subjected to. If you are within the spec parameters, the amp itself is probably to blame.</p>
]]></description><link>https://fargostreet.com/post/219303</link><guid isPermaLink="true">https://fargostreet.com/post/219303</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sat, 09 Aug 2008 17:03:27 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Sat, 09 Aug 2008 16:28:51 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">weshole;230734 wrote:<br />
...........WHAT?!?!?! Ok, hold on a sec. What you mount the amp to will have little to no effect on an amps cooling ability. The amp being open to air and having the heat sink able to breathe (for lack of better terms) will help. Running cooloing fans is the MOST efficient way to keep the amp cool. It can be a challenge to keep it looking clean though.</p>
<p dir="auto">This is true. I found the best cooling fans to use are the Targus full size fans for laptops. Mount them about a quarter inch below flush then mount the amp right over it. You dont see the fans. Very clean. Unless you are running tiny amps, in which case...get bigger amps.</p>
]]></description><link>https://fargostreet.com/post/219297</link><guid isPermaLink="true">https://fargostreet.com/post/219297</guid><dc:creator><![CDATA[D S ohM]]></dc:creator><pubDate>Sat, 09 Aug 2008 16:28:51 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Sat, 09 Aug 2008 15:24:41 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Joel;230728 wrote:<br />
are your amps mounted to something solid or a carpeted surface. Mounting to a piece of plywood or sheet metal will help with cooling emmensly.</p>
<p dir="auto">...........WHAT?!?!?! Ok, hold on a sec. What you mount the amp to will have little to no effect on an amps cooling ability. The amp being open to air and having the heat sink able to breathe (for lack of better terms) will help. Running cooloing fans is the MOST efficient way to keep the amp cool. It can be a challenge to keep it looking clean though.</p>
]]></description><link>https://fargostreet.com/post/219287</link><guid isPermaLink="true">https://fargostreet.com/post/219287</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sat, 09 Aug 2008 15:24:41 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Sat, 09 Aug 2008 12:38:07 GMT]]></title><description><![CDATA[<p dir="auto">are your amps mounted to something solid or a carpeted surface. Mounting to a piece of plywood or sheet metal will help with cooling emmensly.</p>
]]></description><link>https://fargostreet.com/post/219281</link><guid isPermaLink="true">https://fargostreet.com/post/219281</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Sat, 09 Aug 2008 12:38:07 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Sat, 09 Aug 2008 04:39:15 GMT]]></title><description><![CDATA[<p dir="auto">I did some more testing on the amp today. It seems that the problem is because it is not being ventilated properly. I picked up some PC Cooling fans and i'm going to try those out and see if that helps, just to move the air around the amplifier.</p>
<p dir="auto">I also got a hold of someone to do some custom fibreglass work! So it will look even better than I thought!</p>
]]></description><link>https://fargostreet.com/post/219264</link><guid isPermaLink="true">https://fargostreet.com/post/219264</guid><dc:creator><![CDATA[Exist2Inspire]]></dc:creator><pubDate>Sat, 09 Aug 2008 04:39:15 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Thu, 07 Aug 2008 14:44:57 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Exist2Inspire;230589 wrote:</p>
<p dir="auto">My Alpine 4-Channel amp is constanly overheating, and I've already gone through 3, so I'm pretty sure they're just a shitty amp.</p>
<p dir="auto">I'll put money on it being a poor ground/too thin of ground/too thin of power cable/poor ventilation around the amp/the amp is not 2 ohm stable (I <em>think</em> monsoon systems use 2 ohm speakers still...could be wrong...and I think that the MRP-F300 is 2 ohm stable as well).  3 amps overheating and failing is not normal from Alpine....did you buy them locally?  If not, they could be knock-offs if bought from some of the more cheap online sites.</p>
<p dir="auto">[QUOTE]<br />
<strong>Still To Accomplish</strong></p>
<p dir="auto">New Mono Amp  LET ME KNOW IF I CAN BE OF ASSISTANCE<br />
New 4-Channel Amp LET ME KNOW IF I CAN BE OF ASSISTANCE<br />
New Speakers (stocker's are starting die out <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":(" alt="😞" /> )  THIS COULD BE CAUSING YOUR AMPS TO OVERHEAT<br />
Single USB plug-in in each A-Pillar<br />
USB Hub under the DVD player<br />
iPod adapter -&gt; planning is all done, just need the USB Hub under the DVD player<br />
XM Radio Adapter and a AM/FM Tuner</p>
<p dir="auto">I won't be at the perfect 10 this year, as I didn't have everything I wanted done in time, but next year I should be there <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">I'll want to add up pictures, but I've still got some work to do around the dash (forgot to put clear-coat on the paint around the screen so its all peeling and fading).</p>
]]></description><link>https://fargostreet.com/post/219158</link><guid isPermaLink="true">https://fargostreet.com/post/219158</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 07 Aug 2008 14:44:57 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Thu, 07 Aug 2008 06:14:52 GMT]]></title><description><![CDATA[<p dir="auto">Wow, it's been a while since I updated haha.</p>
<p dir="auto">Well, the I.C.E. is working great! I've ran into a few problems, but that will be fixed next year when I have more money. My Alpine 4-Channel amp is constanly overheating, and I've already gone through 3, so I'm pretty sure they're just a shitty amp, and my Touch Screen ribbon broke (stupid, stupid me).</p>
<p dir="auto">But here is my system, though nothing is final as it will always change</p>
<p dir="auto">Screen: Lilliput 629GL 7" Touch Screen</p>
<p dir="auto">4-Channel: Alpine MRP-F300<br />
Mono: Kicker 400.1 KX<br />
Subs: 2x Alpine Type-R's<br />
Speakers: Stock Monsoon System</p>
<p dir="auto">750W Black n Decker Power Inverter</p>
<p dir="auto">DVD/CD Drive mounted underneath my HVAC Controls (damn fiberglass broke today, so its kinda just hanging there)</p>
<p dir="auto">GPS (iGuidance 4.0)</p>
<p dir="auto">Running Road-Runner as a front end with LSX Void 3.3 Skin</p>
<p dir="auto"><strong>Still To Accomplish</strong></p>
<p dir="auto">New Mono Amp<br />
New 4-Channel Amp<br />
New Speakers (stocker's are starting die out <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":(" alt="😞" /> )<br />
]]></description><link>https://fargostreet.com/post/219143</link><guid isPermaLink="true">https://fargostreet.com/post/219143</guid><dc:creator><![CDATA[Exist2Inspire]]></dc:creator><pubDate>Thu, 07 Aug 2008 06:14:52 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Mon, 02 Jun 2008 23:03:01 GMT]]></title><description><![CDATA[<p dir="auto">Hey everyone! Just thought I'd give an update on my system. It should be together by wednesday! Everything has been bolted down, and now I just need to wire everything up.</p>
]]></description><link>https://fargostreet.com/post/209424</link><guid isPermaLink="true">https://fargostreet.com/post/209424</guid><dc:creator><![CDATA[Exist2Inspire]]></dc:creator><pubDate>Mon, 02 Jun 2008 23:03:01 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Tue, 27 May 2008 21:53:40 GMT]]></title><description><![CDATA[<p dir="auto">Well, thought I'd supply a little update: I've stopped working on it because my car is in the body shop <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":(" alt="😞" /> Here's hoping I can have it all installed by Sunday for the car show <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
]]></description><link>https://fargostreet.com/post/208963</link><guid isPermaLink="true">https://fargostreet.com/post/208963</guid><dc:creator><![CDATA[Exist2Inspire]]></dc:creator><pubDate>Tue, 27 May 2008 21:53:40 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Tue, 27 May 2008 17:50:19 GMT]]></title><description><![CDATA[<p dir="auto">sounds like a pretty cool setup man, good luck.</p>
]]></description><link>https://fargostreet.com/post/208926</link><guid isPermaLink="true">https://fargostreet.com/post/208926</guid><dc:creator><![CDATA[TurboGTU]]></dc:creator><pubDate>Tue, 27 May 2008 17:50:19 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Tue, 27 May 2008 04:00:22 GMT]]></title><description><![CDATA[<p dir="auto">Ahh...ok, wasn't aware that they had the autopower/hibernate module out.  I may have to incorporate something like that in my setup soon as well.</p>
]]></description><link>https://fargostreet.com/post/208885</link><guid isPermaLink="true">https://fargostreet.com/post/208885</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 27 May 2008 04:00:22 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Tue, 27 May 2008 03:44:40 GMT]]></title><description><![CDATA[<p dir="auto">tjamz: Yeah, I've got my school laptop that I'm going to be using. Advantage is when I go to school I'll hook up my computer and then take it out for classes. I've also ordered an Auto Power/Hibernate module, so as soon as the laptop gets power, it turns on, and shuts off when the power is gone.</p>
]]></description><link>https://fargostreet.com/post/208882</link><guid isPermaLink="true">https://fargostreet.com/post/208882</guid><dc:creator><![CDATA[Exist2Inspire]]></dc:creator><pubDate>Tue, 27 May 2008 03:44:40 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Tue, 27 May 2008 03:15:57 GMT]]></title><description><![CDATA[<p dir="auto">Glad to see some more people are doing some things audio-wise.  If I may ask, why do the car pc setup using a laptop?  Unless of course you already have a laptop ready to go, then that makes perfect sense.  The major advantage of a "true" car pc is having the pc start up when the vehicle starts (just like a "regular" radio) and then go into hibernation when it the ignition is shut off.  Don't take that as criticism please, I was just curious.</p>
]]></description><link>https://fargostreet.com/post/208876</link><guid isPermaLink="true">https://fargostreet.com/post/208876</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 27 May 2008 03:15:57 GMT</pubDate></item><item><title><![CDATA[Reply to My In-Car Entertainment (Work In Progress) on Tue, 27 May 2008 03:03:42 GMT]]></title><description><![CDATA[<p dir="auto">nice, should sound and look great, im an alpine man myself also.</p>
]]></description><link>https://fargostreet.com/post/208873</link><guid isPermaLink="true">https://fargostreet.com/post/208873</guid><dc:creator><![CDATA[95accord]]></dc:creator><pubDate>Tue, 27 May 2008 03:03:42 GMT</pubDate></item></channel></rss>
