<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DSM error codes]]></title><description><![CDATA[<p dir="auto">I bought this car after someone swapped the engine and added some upgrades and couldn't get it to run right.  If I clear the error codes it runs good for a couple of days, then starts to run like crap again.  It drops to lean and acts like it is running on 3 cylinders when cruising at 60.  If I drop it into neutral for a few seconds it returns to stoic and runs fine for a while.</p>
<p dir="auto">Here are the codes.  P0420, Cat Effic Below Threshold (Bank 1).  P0455, EVAP Ctrl System Gross Leak Detected.  P1400, Mfr Controlled Aux Emissions Controls.  P0300B, Random/Multiple Misfires Detected.</p>
<p dir="auto">Any ideas?</p>
]]></description><link>https://fargostreet.com/topic/14261/dsm-error-codes</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 04:35:42 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/14261.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Jun 2008 02:04:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to DSM error codes on Thu, 12 Jun 2008 02:42:30 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">dlEclipse;221909 wrote:<br />
treimche. You mentioned a trick for the 2nd O2 sensor.  If it isn't installed what can I do to stop the P0420 code?  I'm not sure what emissions sensors have been removed and what just wasn't hooked up...  If I purchase DSMLink or the AEM do I still need to worry about the codes?</p>
<p dir="auto">DSMLink or AEM lets you run w/out a rear O2 sensor if you want.  The trick I know is if you have the rear O2 hooked up, but don't have a cat in the car.  If you plan on getting an O2 sensor to put in I can tell you how to do it.</p>
]]></description><link>https://fargostreet.com/post/210631</link><guid isPermaLink="true">https://fargostreet.com/post/210631</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Thu, 12 Jun 2008 02:42:30 GMT</pubDate></item><item><title><![CDATA[Reply to DSM error codes on Wed, 11 Jun 2008 22:21:14 GMT]]></title><description><![CDATA[<p dir="auto">Just get a socketed/chipped ecu and run DSMLink. Its all you really need. Other than that, if anything on here doesn't help, try <a href="www.dsmtalk.com">www.dsmtalk.com</a>  just search and you will find all of your answers.</p>
]]></description><link>https://fargostreet.com/post/210572</link><guid isPermaLink="true">https://fargostreet.com/post/210572</guid><dc:creator><![CDATA[D S ohM]]></dc:creator><pubDate>Wed, 11 Jun 2008 22:21:14 GMT</pubDate></item><item><title><![CDATA[Reply to DSM error codes on Wed, 11 Jun 2008 13:08:32 GMT]]></title><description><![CDATA[<p dir="auto">Ruthless351.  Yes, I've checked the gas cap but I think I'll just replace the stupid thing since it could be a cheap fix for the P1400 code.</p>
<p dir="auto">treimche. You mentioned a trick for the 2nd O2 sensor.  If it isn't installed what can I do to stop the P0420 code?  I'm not sure what emissions sensors have been removed and what just wasn't hooked up...  If I purchase DSMLink or the AEM do I still need to worry about the codes?</p>
<p dir="auto">GnArKiLl.  Unfortunately my home garage is somewhat limited in tools (no compression tester), which is good because I only know enough to be dangerous.</p>
<p dir="auto">Thanks for all the ideas.</p>
]]></description><link>https://fargostreet.com/post/210527</link><guid isPermaLink="true">https://fargostreet.com/post/210527</guid><dc:creator><![CDATA[dlEclipse]]></dc:creator><pubDate>Wed, 11 Jun 2008 13:08:32 GMT</pubDate></item><item><title><![CDATA[Reply to DSM error codes on Wed, 11 Jun 2008 06:15:43 GMT]]></title><description><![CDATA[<p dir="auto">my old 90 fwd turbo did the same thing and it was cuz of low compression.. do i compession test and post  the numbers...</p>
]]></description><link>https://fargostreet.com/post/210518</link><guid isPermaLink="true">https://fargostreet.com/post/210518</guid><dc:creator><![CDATA[GnArKiLl]]></dc:creator><pubDate>Wed, 11 Jun 2008 06:15:43 GMT</pubDate></item><item><title><![CDATA[Reply to DSM error codes on Wed, 11 Jun 2008 04:40:40 GMT]]></title><description><![CDATA[<p dir="auto">Actually don't most cars 95 and newer (OBDII) run 2 O2 sensors?  One before and one after the cat is correct.</p>
<p dir="auto">Also if your emissions stuff is removed, there shouldn't be that many vaccum hoses under the hood.</p>
]]></description><link>https://fargostreet.com/post/210484</link><guid isPermaLink="true">https://fargostreet.com/post/210484</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Wed, 11 Jun 2008 04:40:40 GMT</pubDate></item><item><title><![CDATA[Reply to DSM error codes on Wed, 11 Jun 2008 04:02:26 GMT]]></title><description><![CDATA[<p dir="auto">Well no cat and no O2 sensor downstream  explains the code..P0420, Cat Effic Below Threshold (Bank 1). I dont know much about imports but do they run an O2 sensor before and after the cat?I know some people using an O2 sensor simulator to keep that code from popping up. Go over the vac hoses very carefully make sure they are plugged. Take your time and look over the entire engine bay. As for <em>EVAP Ctrl System Gross Leak Detected. P1400</em> is your gas cap on good and tight? <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /> sorry had to do it.</p>
]]></description><link>https://fargostreet.com/post/210454</link><guid isPermaLink="true">https://fargostreet.com/post/210454</guid><dc:creator><![CDATA[ruthless351]]></dc:creator><pubDate>Wed, 11 Jun 2008 04:02:26 GMT</pubDate></item><item><title><![CDATA[Reply to DSM error codes on Wed, 11 Jun 2008 03:20:48 GMT]]></title><description><![CDATA[<p dir="auto">Yes, it is the 6 bolt motor.  If I'm ready to spend the cash what size injectors should I go for?  I'm not very familiar with the AEM, how does it compare to DSMLink?  Is the AEM really $1900 (ouch)?</p>
]]></description><link>https://fargostreet.com/post/210437</link><guid isPermaLink="true">https://fargostreet.com/post/210437</guid><dc:creator><![CDATA[dlEclipse]]></dc:creator><pubDate>Wed, 11 Jun 2008 03:20:48 GMT</pubDate></item><item><title><![CDATA[Reply to DSM error codes on Wed, 11 Jun 2008 03:11:16 GMT]]></title><description><![CDATA[<p dir="auto">It was pretty much a hack job.  There's no cat installed and I from what I can see the 2nd O2 sensor isn't installed anywhere.  The upgrades include an EVO III 16G Turbo, TurboXS Boost Controller, EVO III O2 Housing, Greddy BOV, Walbro 255 Fuel Pump, Apexi N1 Downpipe and Turboback Exhaust.</p>
<p dir="auto">I can handle the general maintenance stuff, but there's more damn vacuum tubes under that hood than I know what to do with...</p>
]]></description><link>https://fargostreet.com/post/210434</link><guid isPermaLink="true">https://fargostreet.com/post/210434</guid><dc:creator><![CDATA[dlEclipse]]></dc:creator><pubDate>Wed, 11 Jun 2008 03:11:16 GMT</pubDate></item><item><title><![CDATA[Reply to DSM error codes on Wed, 11 Jun 2008 02:59:10 GMT]]></title><description><![CDATA[<p dir="auto">If the emissions stuff is removed, you should still leave the solenoids plugged in, then you won't get those CEL's.  As far as the random/multiple misfire, I think there are some ghetto fixes out there, but the best way is with either DSMLink or a standalone EMS such as AEM.  I'd just spend the money on the AEM and be done w/ it.  I'm going on an assumption that you have the 6 bolt 1G motor in that car.  I wonder if the P0420 could just be a bad O2 sensor.  I know of an awesome trick for the 2nd O2 sensors on a 2G so you won't get codes for that.</p>
]]></description><link>https://fargostreet.com/post/210428</link><guid isPermaLink="true">https://fargostreet.com/post/210428</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Wed, 11 Jun 2008 02:59:10 GMT</pubDate></item><item><title><![CDATA[Reply to DSM error codes on Wed, 11 Jun 2008 02:45:55 GMT]]></title><description><![CDATA[<p dir="auto">Do you still have have the cat(s) installed? What about the emission stuff. Did who ever did the engine swap leave the emission stuff installed or did they hack it? I have a few ideas.....what kind of upgrades his previous owner install?</p>
]]></description><link>https://fargostreet.com/post/210424</link><guid isPermaLink="true">https://fargostreet.com/post/210424</guid><dc:creator><![CDATA[ruthless351]]></dc:creator><pubDate>Wed, 11 Jun 2008 02:45:55 GMT</pubDate></item><item><title><![CDATA[Reply to DSM error codes on Wed, 11 Jun 2008 02:41:47 GMT]]></title><description><![CDATA[<p dir="auto">Eliminate all emissions! Shit, I don't know 2g's worth a damn.</p>
]]></description><link>https://fargostreet.com/post/210423</link><guid isPermaLink="true">https://fargostreet.com/post/210423</guid><dc:creator><![CDATA[D S ohM]]></dc:creator><pubDate>Wed, 11 Jun 2008 02:41:47 GMT</pubDate></item><item><title><![CDATA[Reply to DSM error codes on Wed, 11 Jun 2008 02:29:44 GMT]]></title><description><![CDATA[<p dir="auto">Welcome to the DSM game.</p>
]]></description><link>https://fargostreet.com/post/210417</link><guid isPermaLink="true">https://fargostreet.com/post/210417</guid><dc:creator><![CDATA[D S ohM]]></dc:creator><pubDate>Wed, 11 Jun 2008 02:29:44 GMT</pubDate></item></channel></rss>
