<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[dart blocks]]></title><description><![CDATA[<p dir="auto">i have just recently learned about dart blocks. i was curious what are the advantages of them? what are the disadvantages? and how do you decide what deck size and overbore you want?</p>
]]></description><link>https://fargostreet.com/topic/1465/dart-blocks</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 01:10:27 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/1465.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Jan 2005 21:51:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to dart blocks on Sun, 30 Jan 2005 18:27:27 GMT]]></title><description><![CDATA[<p dir="auto">Wow I didn't know I still had these pictures of my motor.  Good shot of AEBS sleeves and o-rings.</p>
<p dir="auto"><img src="http://www.imperial.org/motor/sleeves1.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://www.imperial.org/motor/sleeves2.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://www.imperial.org/motor/sleeves4.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/27347</link><guid isPermaLink="true">https://fargostreet.com/post/27347</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Sun, 30 Jan 2005 18:27:27 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Sun, 30 Jan 2005 18:05:10 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">how much boost could a well built oem block hold? how much boost could a well built dart hold?</p>
<p dir="auto">not saying that the dart block is a bad thing.  Just that the stock block and AEBS sleeving is just more economical.  And has some pretty high tolerances</p>
<pre><code>   Same material used in top fuel cars
</code></pre>
<p dir="auto">Successfully tested to 55 lbs. of boost<br />
"Best engineered sleeve" ... Sport Compact Car<br />
AEBS Final Bore and Hone  $200<br />
AEBS Stainless O-Ring Work  $200<br />
AEBS T-Sleeve Engine Work $1075<br />
not bad for $1475    and the cost of a stock block  $150-$200</p>
<p dir="auto">if you want to take a look at an AEBS sleeved/ o-ringed block.... drop by the Fargo shop before we put the head on.</p>
]]></description><link>https://fargostreet.com/post/27341</link><guid isPermaLink="true">https://fargostreet.com/post/27341</guid><dc:creator><![CDATA[tntmstr]]></dc:creator><pubDate>Sun, 30 Jan 2005 18:05:10 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Sun, 30 Jan 2005 17:54:32 GMT]]></title><description><![CDATA[<p dir="auto">My AEBS motor has seen in excess of 30 psi with zero problems.  Boost pressure isn't the killer, detonation is the killer.</p>
<p dir="auto">A stock LS block can and has dealt with 25+ psi no problem.  It is all in the tune.  Even a well bult AEBS block can grenade if the tune is that bad.</p>
]]></description><link>https://fargostreet.com/post/27334</link><guid isPermaLink="true">https://fargostreet.com/post/27334</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Sun, 30 Jan 2005 17:54:32 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Sun, 30 Jan 2005 17:44:40 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">bluejays wrote:<br />
how much boost could a well built oem block hold? how much boost could a well built dart hold?<br />
its not how much boost it can hold, its how long that much boost will stay reliable</p>
]]></description><link>https://fargostreet.com/post/27329</link><guid isPermaLink="true">https://fargostreet.com/post/27329</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Sun, 30 Jan 2005 17:44:40 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Sun, 30 Jan 2005 13:34:35 GMT]]></title><description><![CDATA[<p dir="auto">how much boost could a well built oem block hold? how much boost could a well built dart hold?</p>
]]></description><link>https://fargostreet.com/post/27314</link><guid isPermaLink="true">https://fargostreet.com/post/27314</guid><dc:creator><![CDATA[bluejays]]></dc:creator><pubDate>Sun, 30 Jan 2005 13:34:35 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Sun, 30 Jan 2005 07:28:35 GMT]]></title><description><![CDATA[<p dir="auto">Actually, I would have to agree with GSR for once.  We are a dealer of AEBs and Dart.  I would rather sell someone AEBS.  IMHO</p>
]]></description><link>https://fargostreet.com/post/27300</link><guid isPermaLink="true">https://fargostreet.com/post/27300</guid><dc:creator><![CDATA[tntmstr]]></dc:creator><pubDate>Sun, 30 Jan 2005 07:28:35 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Sun, 30 Jan 2005 01:16:50 GMT]]></title><description><![CDATA[<p dir="auto">Any sleeve?  Have you seen the design of the AEBS sleeve?  It's shaped like a T... Sits on top of a ledge.  Hard to sink when it's got a lip butted up against something.</p>
<p dir="auto">I've been "all out" for almost 4 years now.  I have AEBS sleeves in my motor, and have used them in two other motors for others as well.  Also, all pro cars use OEM honda blocks w/ aftermarket sleeves @ HP levels approaching 1200-1300 whp.  Dart block isn't worth it IMHO.</p>
]]></description><link>https://fargostreet.com/post/27241</link><guid isPermaLink="true">https://fargostreet.com/post/27241</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Sun, 30 Jan 2005 01:16:50 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Sat, 29 Jan 2005 23:35:30 GMT]]></title><description><![CDATA[<p dir="auto">Any sleeve....benson darton GE AEBS all have a chance of sinking. If you're gonna go all out, might as well go Dart.</p>
]]></description><link>https://fargostreet.com/post/27230</link><guid isPermaLink="true">https://fargostreet.com/post/27230</guid><dc:creator><![CDATA[seanjohn]]></dc:creator><pubDate>Sat, 29 Jan 2005 23:35:30 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Fri, 28 Jan 2005 06:09:55 GMT]]></title><description><![CDATA[<p dir="auto">Uhm.  You just need the right kind of sleeves to not have to worry about sleeves sinking. <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://fargostreet.com/post/26884</link><guid isPermaLink="true">https://fargostreet.com/post/26884</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Fri, 28 Jan 2005 06:09:55 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Fri, 28 Jan 2005 05:01:21 GMT]]></title><description><![CDATA[<p dir="auto">With a dart block you won't ever have to worry about sinking sleeves. Also, there are just two different size blocks, the short and tall deck. Short is the b16, tall is the rest of the B-series motors.</p>
]]></description><link>https://fargostreet.com/post/26867</link><guid isPermaLink="true">https://fargostreet.com/post/26867</guid><dc:creator><![CDATA[seanjohn]]></dc:creator><pubDate>Fri, 28 Jan 2005 05:01:21 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Fri, 28 Jan 2005 03:47:37 GMT]]></title><description><![CDATA[<p dir="auto">Sleeved stock b series motor is just fine.  Good condition B series cranks can be hard to come by.  If you are looking into having a motor sleeved let me know.</p>
]]></description><link>https://fargostreet.com/post/26857</link><guid isPermaLink="true">https://fargostreet.com/post/26857</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Fri, 28 Jan 2005 03:47:37 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Fri, 28 Jan 2005 02:00:06 GMT]]></title><description><![CDATA[<p dir="auto">talk to Dartcivic if you wanna hear stories about dart blocks......</p>
]]></description><link>https://fargostreet.com/post/26842</link><guid isPermaLink="true">https://fargostreet.com/post/26842</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 28 Jan 2005 02:00:06 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Thu, 27 Jan 2005 23:41:51 GMT]]></title><description><![CDATA[<p dir="auto">ya, is it worth it though nick, especially if you plan on boosting it?</p>
]]></description><link>https://fargostreet.com/post/26817</link><guid isPermaLink="true">https://fargostreet.com/post/26817</guid><dc:creator><![CDATA[bluejays]]></dc:creator><pubDate>Thu, 27 Jan 2005 23:41:51 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Thu, 27 Jan 2005 23:29:41 GMT]]></title><description><![CDATA[<p dir="auto">Dart blocks are pretty cool until you figure out everything you need to make it work. <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">Dart Block, Crank, Bearings, Oil Squirters, Pistons, and Rods makes that bottom end price go up pretty quick. <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/26815</link><guid isPermaLink="true">https://fargostreet.com/post/26815</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Thu, 27 Jan 2005 23:29:41 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Thu, 27 Jan 2005 22:37:46 GMT]]></title><description><![CDATA[<p dir="auto">sweet</p>
]]></description><link>https://fargostreet.com/post/26802</link><guid isPermaLink="true">https://fargostreet.com/post/26802</guid><dc:creator><![CDATA[bluejays]]></dc:creator><pubDate>Thu, 27 Jan 2005 22:37:46 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Thu, 27 Jan 2005 22:34:54 GMT]]></title><description><![CDATA[<p dir="auto">no they can be used in DD cars...from what i have heard and seen they are really good and worth the price.</p>
]]></description><link>https://fargostreet.com/post/26800</link><guid isPermaLink="true">https://fargostreet.com/post/26800</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 27 Jan 2005 22:34:54 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Thu, 27 Jan 2005 22:34:26 GMT]]></title><description><![CDATA[<p dir="auto">lol i wouldnt say any DSM transmission is bulletproof...thats gettin too cocky...trust me i know <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/26799</link><guid isPermaLink="true">https://fargostreet.com/post/26799</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Thu, 27 Jan 2005 22:34:26 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Thu, 27 Jan 2005 22:29:48 GMT]]></title><description><![CDATA[<p dir="auto">so the only downfall is the price? you don't lose drivability or anything?</p>
]]></description><link>https://fargostreet.com/post/26798</link><guid isPermaLink="true">https://fargostreet.com/post/26798</guid><dc:creator><![CDATA[bluejays]]></dc:creator><pubDate>Thu, 27 Jan 2005 22:29:48 GMT</pubDate></item><item><title><![CDATA[Reply to dart blocks on Thu, 27 Jan 2005 22:27:04 GMT]]></title><description><![CDATA[<p dir="auto">bigger the bore...the more power you can make...think of dart blocks like a TRE or Dogbox transmission = Bulletproof</p>
]]></description><link>https://fargostreet.com/post/26795</link><guid isPermaLink="true">https://fargostreet.com/post/26795</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 27 Jan 2005 22:27:04 GMT</pubDate></item></channel></rss>
