<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Call a BS?]]></title><description><![CDATA[<p dir="auto">This is a thread from a car care forum. A guy was giving out his "regimine" as to how he gets cars so clean. Here are his before aGSRstilez 09-12-2004 09:57 AM</p>
<hr />
<p dir="auto">Carpet &amp; Upholstery Cleaning by GSRstilez</p>
<p dir="auto">I have been getting countless questions about my regimen, so I figured I'd just write up an article and post it. I'd like to thank my girlfriend turning my on to the OXY POWER! a little over a year ago. After playing with different dilutions, I've found a great method. Enjoy the read!</p>
<hr />
<p dir="auto">Hey Everyone,</p>
<p dir="auto">As a professional detailer I have tried many different methods to getting a carpet clean. Currently I use a method that lifts deep down stains and odors out quite well.</p>
<p dir="auto">What you will need</p>
<p dir="auto">-Hi-power wet/dry ShopVac<br />
-Oxy Clean (the Granular)<br />
-2 Gallon Bucket<br />
-Medium Hardness Bristled Nylon Brush w/handle<br />
-A good spot remover (I used Meguiar's All Purpose Cleaner diluted 10:1)</p>
<p dir="auto">What to do</p>
<p dir="auto">-Vacuum out the upholstery or carpet<br />
-Mix in the 2 gallon bucket: 2 scoops of Oxy Clean and the rest with warm/hot water<br />
-Stir it up with the brush and let it sit for 5 mins for the product to saturate into the water<br />
-While it is saturating, spray your spot remover onto the surface generously, concentrating the spray on the heavier soil spots<br />
-Proceed to then scrub the solution into the carpet. What I do is hold the handled brush and scoop some water with my hand onto the surface. Work in small squares (1'x1') when agitating and scrub front to back, left and right, repeating over each swipe. You will see the solution saturate into the carpet. Just scrub the solution in and move to your next area.<br />
-When the entire area is saturated, begin where you begun scrubbing the first section. Proceed to extract the water solution out of the carpets/upholstery. I usually take the filter out of the ShopVac (more suction) for this and move slowly over the surface to insure complete extraction of the solution.<br />
-When done, the areas will be damp. Leave the doors open with the dome light switched "OFF" and leave the mats in the sun. It should be dry in an hour or two.<br />
-Let it all dry and Voila!</p>
<p dir="auto">Notes</p>
<p dir="auto">-Get some crevice tools for the Shopvac. It will help with vacuuming and extracting.<br />
-For tight areas, agitate with your hands or a terry towel.<br />
-For a spot remover, you should be just fine with something that is safe for clothing (IE: Shout Spray)<br />
-Repeat if necessary. For deep stains, just apply the solution and let it sit for about 20 mins, then extract out.</p>
<p dir="auto">Here are some pictures of the work I have achieved with the exact steps/products listed above:</p>
<p dir="auto">here are the two pics/</p>
<p dir="auto">You tell me if this is the same car!</p>
<p dir="auto"><img src="/assets/uploads/legacy/attachments/665/fake%201.jpg" alt="fake 1.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/legacy/attachments/666/fake%202.jpg" alt="fake 2.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/topic/1472/call-a-bs</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 08:04:13 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/1472.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 28 Jan 2005 06:51:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Call a BS? on Sat, 29 Jan 2005 03:40:16 GMT]]></title><description><![CDATA[<p dir="auto">For this vehicle the seats either came charcoal or tan and the dash shit brown or black. There were no other colors unless it is leather which it is not so its just the shading.</p>
]]></description><link>https://fargostreet.com/post/27084</link><guid isPermaLink="true">https://fargostreet.com/post/27084</guid><dc:creator><![CDATA[fanaticrockford]]></dc:creator><pubDate>Sat, 29 Jan 2005 03:40:16 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 21:05:55 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">YellowEvo wrote:<br />
your 8 behind kirk, you post 15 posts a day... does that not mean something???????<br />
no and does it matter i like this site so what , im not fighting with kirk anymore, oh yeah and by the way i saw ur evo in moorhead on saturday u didnt see me cause i was moving equipment for the headcharge show after leaving discontent from doing signings <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
]]></description><link>https://fargostreet.com/post/27000</link><guid isPermaLink="true">https://fargostreet.com/post/27000</guid><dc:creator><![CDATA[My NOva]]></dc:creator><pubDate>Fri, 28 Jan 2005 21:05:55 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 21:01:36 GMT]]></title><description><![CDATA[<p dir="auto">your 8 behind kirk, you post 15 posts a day... does that not mean something???????</p>
]]></description><link>https://fargostreet.com/post/26998</link><guid isPermaLink="true">https://fargostreet.com/post/26998</guid><dc:creator><![CDATA[YellowEvo]]></dc:creator><pubDate>Fri, 28 Jan 2005 21:01:36 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 21:00:43 GMT]]></title><description><![CDATA[<blockquote>
QUIT POST WHORING!!!!!!<br />
how am i post whoring i havent really made any posts the past few days plus i was comenting on how clean the car looks so fuck off/////jk <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
]]></description><link>https://fargostreet.com/post/26997</link><guid isPermaLink="true">https://fargostreet.com/post/26997</guid><dc:creator><![CDATA[My NOva]]></dc:creator><pubDate>Fri, 28 Jan 2005 21:00:43 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 20:58:20 GMT]]></title><description><![CDATA[<blockquote>
QUIT POST WHORING!!!!!!</p>
<p dir="auto">exactly!!!!!!!</p>
]]></description><link>https://fargostreet.com/post/26996</link><guid isPermaLink="true">https://fargostreet.com/post/26996</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 28 Jan 2005 20:58:20 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 20:54:05 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">My NOva wrote:<br />
what he said^^^^^^^^^its clean lookin though</p>
<p dir="auto">QUIT POST WHORING!!!!!!</p>
]]></description><link>https://fargostreet.com/post/26995</link><guid isPermaLink="true">https://fargostreet.com/post/26995</guid><dc:creator><![CDATA[YellowEvo]]></dc:creator><pubDate>Fri, 28 Jan 2005 20:54:05 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 20:53:19 GMT]]></title><description><![CDATA[<p dir="auto">what he said^^^^^^^^^its clean lookin though</p>
]]></description><link>https://fargostreet.com/post/26994</link><guid isPermaLink="true">https://fargostreet.com/post/26994</guid><dc:creator><![CDATA[My NOva]]></dc:creator><pubDate>Fri, 28 Jan 2005 20:53:19 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 20:01:02 GMT]]></title><description><![CDATA[<p dir="auto">everything matches perfectly it has to be the same car....theres a envelope in each passenger side pocket of the door.....and the krinkles in the seats are the same...i think they are the same...musta been a cloudy day in the top pic and sunny in the bottom pic.</p>
]]></description><link>https://fargostreet.com/post/26963</link><guid isPermaLink="true">https://fargostreet.com/post/26963</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 28 Jan 2005 20:01:02 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 19:39:31 GMT]]></title><description><![CDATA[<p dir="auto">it's like those things in the newspaper, circle the differences...</p>
]]></description><link>https://fargostreet.com/post/26958</link><guid isPermaLink="true">https://fargostreet.com/post/26958</guid><dc:creator><![CDATA[YellowEvo]]></dc:creator><pubDate>Fri, 28 Jan 2005 19:39:31 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 19:28:44 GMT]]></title><description><![CDATA[<p dir="auto">Where are you seeing that it's a different car?  It's the same.  The only glaring difference is the lack of a floor mat in the first pic vs the second.</p>
]]></description><link>https://fargostreet.com/post/26957</link><guid isPermaLink="true">https://fargostreet.com/post/26957</guid><dc:creator><![CDATA[mym6]]></dc:creator><pubDate>Fri, 28 Jan 2005 19:28:44 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 18:42:57 GMT]]></title><description><![CDATA[<p dir="auto">haha thats such BS, thats a different car. He uses any more "oxy-clean" and he'll have leather seats</p>
]]></description><link>https://fargostreet.com/post/26949</link><guid isPermaLink="true">https://fargostreet.com/post/26949</guid><dc:creator><![CDATA[Tad218]]></dc:creator><pubDate>Fri, 28 Jan 2005 18:42:57 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 18:23:58 GMT]]></title><description><![CDATA[<p dir="auto">thats exactly what i said...it looks way different to me...more than just light</p>
]]></description><link>https://fargostreet.com/post/26947</link><guid isPermaLink="true">https://fargostreet.com/post/26947</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Fri, 28 Jan 2005 18:23:58 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 18:13:06 GMT]]></title><description><![CDATA[<p dir="auto">same model but a different on, look at the shade of the door panels, and dash!</p>
]]></description><link>https://fargostreet.com/post/26945</link><guid isPermaLink="true">https://fargostreet.com/post/26945</guid><dc:creator><![CDATA[GarageAlchemist]]></dc:creator><pubDate>Fri, 28 Jan 2005 18:13:06 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 07:57:19 GMT]]></title><description><![CDATA[<p dir="auto">There the same car. 97-99 nissan maxima GXE. not a bad car if i say so myself.</p>
]]></description><link>https://fargostreet.com/post/26916</link><guid isPermaLink="true">https://fargostreet.com/post/26916</guid><dc:creator><![CDATA[fanaticrockford]]></dc:creator><pubDate>Fri, 28 Jan 2005 07:57:19 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 07:07:18 GMT]]></title><description><![CDATA[<p dir="auto">yeah i dunno whwat to tell ya cause i think it is a diferentcar but that lighting is  ery different cause it looks totally different to me i dunmo tho and like wes said the floormats are ey different err thereare actual floormats in it unlike the first one...but i tihnk its more than liht differential it looks way different</p>
]]></description><link>https://fargostreet.com/post/26900</link><guid isPermaLink="true">https://fargostreet.com/post/26900</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Fri, 28 Jan 2005 07:07:18 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 07:04:42 GMT]]></title><description><![CDATA[<p dir="auto">i think the different lighting makes it look a lot better. less light in the first pic makes things look a lot dirtier than they maybe are. if it is true hes pretty damn good though.</p>
]]></description><link>https://fargostreet.com/post/26898</link><guid isPermaLink="true">https://fargostreet.com/post/26898</guid><dc:creator><![CDATA[amicheze]]></dc:creator><pubDate>Fri, 28 Jan 2005 07:04:42 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 06:59:16 GMT]]></title><description><![CDATA[<p dir="auto">I think they are the same. But definatelly different lightng in each pic and how convenient that there is a floor mat covering the ink stains. But I do believe they are the same car.</p>
]]></description><link>https://fargostreet.com/post/26894</link><guid isPermaLink="true">https://fargostreet.com/post/26894</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Fri, 28 Jan 2005 06:59:16 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 06:56:31 GMT]]></title><description><![CDATA[<p dir="auto">and he's a "professional detailer". he can detail my car if he's gonna put a whole new interior in it! He's getting a ton of praise for his grate work on the carpet and floor mats and interior on that forum.</p>
]]></description><link>https://fargostreet.com/post/26893</link><guid isPermaLink="true">https://fargostreet.com/post/26893</guid><dc:creator><![CDATA[GarageAlchemist]]></dc:creator><pubDate>Fri, 28 Jan 2005 06:56:31 GMT</pubDate></item><item><title><![CDATA[Reply to Call a BS? on Fri, 28 Jan 2005 06:54:20 GMT]]></title><description><![CDATA[<p dir="auto">holy shit the interior looks totally different....very different</p>
]]></description><link>https://fargostreet.com/post/26892</link><guid isPermaLink="true">https://fargostreet.com/post/26892</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Fri, 28 Jan 2005 06:54:20 GMT</pubDate></item></channel></rss>
