<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bad day at the track]]></title><description><![CDATA[<p dir="auto">Sorry if I disappointed anyone today besides myself.  Anyways I guess I need to fire myself from rebuilding trannys. I pushed through the transbrake on every pass except for one and that was on wastegate springs, 10 psi with creep to 17-18.  Anyways the last two passes when I hot lapped (sorry all) I tried adding 6 pounds to it.  I actually ran slower, so wtf.<br />
I took the car to the shop dropped it off and headed home. On the way home I was thinking what the hell is going on.  I then remembered a few weeks ago I had some wire loom touching the cold side of the turbo. At the time it was just melted a little bit, never thought anything of it.  I headed back over there tonight and took a look.  It had actually melted the insulation off the 12 volt feeds to my boost controller solenoids. I have two, one to add pressure and one to dump pressure.  They were both being energized at the same time, so no boost control at all, just a small boost leak. T&amp;T next w/end it should work:icon_rabbit:</p>
]]></description><link>https://fargostreet.com/topic/14853/bad-day-at-the-track</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 22:27:05 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/14853.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Aug 2008 02:31:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bad day at the track on Mon, 18 Aug 2008 03:09:17 GMT]]></title><description><![CDATA[<p dir="auto">I think the best was 10.16 @ 133, I had a 10.71 @ 138, et was screwed as I stopped after I pushed through the brake, I let off a little and it held again.</p>
]]></description><link>https://fargostreet.com/post/220217</link><guid isPermaLink="true">https://fargostreet.com/post/220217</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Mon, 18 Aug 2008 03:09:17 GMT</pubDate></item><item><title><![CDATA[Reply to Bad day at the track on Mon, 18 Aug 2008 03:03:08 GMT]]></title><description><![CDATA[<p dir="auto">What time did you run?</p>
]]></description><link>https://fargostreet.com/post/220209</link><guid isPermaLink="true">https://fargostreet.com/post/220209</guid><dc:creator><![CDATA[z31]]></dc:creator><pubDate>Mon, 18 Aug 2008 03:03:08 GMT</pubDate></item><item><title><![CDATA[Reply to Bad day at the track on Mon, 18 Aug 2008 02:57:10 GMT]]></title><description><![CDATA[<p dir="auto">I had the same issues with the brake before I tore it down.  I must have missed something, at least I have second gear now.  I replaced all clutches and seals among some hard parts.  Boost issues were a completely separate issue.  The boost deal is that the boost controller was not doing anything except leaking. I was running wastegate pressure only and the boost creep, 10 springs creeping to 18 on the shift and drops to 10 again. When Andy (Dynotune) and I were doing all the pulls last year (we guessed over 100 on this motor) we never did a pull under 20 psi so the creep was never an issue.</p>
]]></description><link>https://fargostreet.com/post/220202</link><guid isPermaLink="true">https://fargostreet.com/post/220202</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Mon, 18 Aug 2008 02:57:10 GMT</pubDate></item><item><title><![CDATA[Reply to Bad day at the track on Mon, 18 Aug 2008 02:37:56 GMT]]></title><description><![CDATA[<p dir="auto">So the boost issues at the line are what hurt the tranny or you think something just didn't go together right<br />
??</p>
]]></description><link>https://fargostreet.com/post/220187</link><guid isPermaLink="true">https://fargostreet.com/post/220187</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Mon, 18 Aug 2008 02:37:56 GMT</pubDate></item></channel></rss>
