<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[roll cage]]></title><description><![CDATA[<p dir="auto">who in the FM area can build a roll cage?</p>
]]></description><link>https://fargostreet.com/topic/14900/roll-cage</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 05:55:58 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/14900.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Aug 2008 19:59:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to roll cage on Tue, 26 Aug 2008 04:41:22 GMT]]></title><description><![CDATA[<p dir="auto">Not for the 240...... LOLZ.</p>
<p dir="auto">From what I have heard, do not buy anything more then the 4 point autopower,</p>
]]></description><link>https://fargostreet.com/post/221401</link><guid isPermaLink="true">https://fargostreet.com/post/221401</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Tue, 26 Aug 2008 04:41:22 GMT</pubDate></item><item><title><![CDATA[Reply to roll cage on Tue, 26 Aug 2008 04:34:56 GMT]]></title><description><![CDATA[<p dir="auto">i heard autopower cage are good</p>
<p dir="auto">but dont know if they make it for your car</p>
]]></description><link>https://fargostreet.com/post/221400</link><guid isPermaLink="true">https://fargostreet.com/post/221400</guid><dc:creator><![CDATA[b almer]]></dc:creator><pubDate>Tue, 26 Aug 2008 04:34:56 GMT</pubDate></item><item><title><![CDATA[Reply to roll cage on Tue, 26 Aug 2008 04:18:22 GMT]]></title><description><![CDATA[<p dir="auto">^ I've got a 10 pt S&amp;W cage for my 240 and I can tell just looking at it that it will require some tweaking.</p>
]]></description><link>https://fargostreet.com/post/221397</link><guid isPermaLink="true">https://fargostreet.com/post/221397</guid><dc:creator><![CDATA[Afsil80]]></dc:creator><pubDate>Tue, 26 Aug 2008 04:18:22 GMT</pubDate></item><item><title><![CDATA[Reply to roll cage on Tue, 26 Aug 2008 03:07:24 GMT]]></title><description><![CDATA[<p dir="auto">Ive heard that some pre-fab cages fit well, but the S&amp;W kit I got for my red car needed a lot of fitting to make it work.  Custom is nice, Laske can make it fit nice and tight.</p>
]]></description><link>https://fargostreet.com/post/221392</link><guid isPermaLink="true">https://fargostreet.com/post/221392</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Tue, 26 Aug 2008 03:07:24 GMT</pubDate></item><item><title><![CDATA[Reply to roll cage on Mon, 25 Aug 2008 22:03:19 GMT]]></title><description><![CDATA[<p dir="auto">if you get a prefab cage and need some minor welding done, I got a welder John.</p>
]]></description><link>https://fargostreet.com/post/221337</link><guid isPermaLink="true">https://fargostreet.com/post/221337</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Mon, 25 Aug 2008 22:03:19 GMT</pubDate></item><item><title><![CDATA[Reply to roll cage on Mon, 25 Aug 2008 21:53:19 GMT]]></title><description><![CDATA[<p dir="auto">thanks for the info max.</p>
]]></description><link>https://fargostreet.com/post/221335</link><guid isPermaLink="true">https://fargostreet.com/post/221335</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Mon, 25 Aug 2008 21:53:19 GMT</pubDate></item><item><title><![CDATA[Reply to roll cage on Mon, 25 Aug 2008 17:25:53 GMT]]></title><description><![CDATA[<p dir="auto">Just a heads up on that thrash I was going to have laske do a cage in my 86 corolla and it was going to be around the same price for a scca legal cage with door bars. He designs and builds his own. He does everything from dirt track cars to welding up little holes in ic piping. He will do a great job and for a reasonable price. Definatly worth the money</p>
]]></description><link>https://fargostreet.com/post/221281</link><guid isPermaLink="true">https://fargostreet.com/post/221281</guid><dc:creator><![CDATA[drift86]]></dc:creator><pubDate>Mon, 25 Aug 2008 17:25:53 GMT</pubDate></item><item><title><![CDATA[Reply to roll cage on Mon, 25 Aug 2008 16:39:51 GMT]]></title><description><![CDATA[<p dir="auto">if you have a pretty common car, you should be able to find one pre-made (or 80% pre-made) and have it shipped here.  Should save a lot of money.  The ideal setup would be a weld-in unit where the tubes were cut, bent, and fisheyed for you already, and a competant welder assembles it in-car for you.</p>
<p dir="auto">The reason is that cage design is hard if you want to do it right.  I'm not at all saying that it is beyond anyone here, just that the design and setup is going to be 99% of the time invested.  The welding/install is the easy part.  Someone that designs and sells pre-made cages or cage-kits for your car has amortized that design and tooling time across lots of cages, so it should save you some dough.</p>
<p dir="auto">I had a bolt-in half cage for my E30 BMW shipped to my residential address for around $600, IIRC.</p>
]]></description><link>https://fargostreet.com/post/221265</link><guid isPermaLink="true">https://fargostreet.com/post/221265</guid><dc:creator><![CDATA[thrash]]></dc:creator><pubDate>Mon, 25 Aug 2008 16:39:51 GMT</pubDate></item><item><title><![CDATA[Reply to roll cage on Fri, 22 Aug 2008 20:34:38 GMT]]></title><description><![CDATA[<p dir="auto">Ok I just talked to him and he told me it is ok to post up info.</p>
<p dir="auto">Laske fabrication<br />
7012128812</p>
]]></description><link>https://fargostreet.com/post/221031</link><guid isPermaLink="true">https://fargostreet.com/post/221031</guid><dc:creator><![CDATA[drift86]]></dc:creator><pubDate>Fri, 22 Aug 2008 20:34:38 GMT</pubDate></item><item><title><![CDATA[Reply to roll cage on Fri, 22 Aug 2008 20:30:50 GMT]]></title><description><![CDATA[<p dir="auto">sls will also do it</p>
]]></description><link>https://fargostreet.com/post/221027</link><guid isPermaLink="true">https://fargostreet.com/post/221027</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 22 Aug 2008 20:30:50 GMT</pubDate></item><item><title><![CDATA[Reply to roll cage on Fri, 22 Aug 2008 20:28:44 GMT]]></title><description><![CDATA[<p dir="auto">Shane laske is his name. Some one on here should have a way of getting ahold of him. I got the number but its his cell phone and I need to get an ok to give that out.</p>
]]></description><link>https://fargostreet.com/post/221026</link><guid isPermaLink="true">https://fargostreet.com/post/221026</guid><dc:creator><![CDATA[drift86]]></dc:creator><pubDate>Fri, 22 Aug 2008 20:28:44 GMT</pubDate></item><item><title><![CDATA[Reply to roll cage on Fri, 22 Aug 2008 20:22:21 GMT]]></title><description><![CDATA[<p dir="auto">I think thats obvious....maybe i shouldve posted.. who in the fm area WILL build me a roll cage.</p>
<p dir="auto">And if you know of someone, or a company, i'll need more than a last name <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/221024</link><guid isPermaLink="true">https://fargostreet.com/post/221024</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Fri, 22 Aug 2008 20:22:21 GMT</pubDate></item><item><title><![CDATA[Reply to roll cage on Fri, 22 Aug 2008 20:02:03 GMT]]></title><description><![CDATA[<p dir="auto">Laskie or however you spell it can.</p>
]]></description><link>https://fargostreet.com/post/221020</link><guid isPermaLink="true">https://fargostreet.com/post/221020</guid><dc:creator><![CDATA[Rexwagon]]></dc:creator><pubDate>Fri, 22 Aug 2008 20:02:03 GMT</pubDate></item></channel></rss>
