<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Turbo Rebuild]]></title><description><![CDATA[<p dir="auto">Purchased a turbo that might need to have rebuild done to it.  Anywhere in the Fargo area that does this or am I stuck shipping this off?</p>
]]></description><link>https://fargostreet.com/topic/14961/turbo-rebuild</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 08:24:33 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/14961.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 Aug 2008 00:45:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Turbo Rebuild on Tue, 02 Sep 2008 05:29:29 GMT]]></title><description><![CDATA[<p dir="auto">Why would you waste money on a K03 btw?</p>
]]></description><link>https://fargostreet.com/post/222509</link><guid isPermaLink="true">https://fargostreet.com/post/222509</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Tue, 02 Sep 2008 05:29:29 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Tue, 02 Sep 2008 05:08:44 GMT]]></title><description><![CDATA[<p dir="auto">Sometimes, its cheaper to buy a new one then to rebuild it.</p>
]]></description><link>https://fargostreet.com/post/222505</link><guid isPermaLink="true">https://fargostreet.com/post/222505</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Tue, 02 Sep 2008 05:08:44 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Fri, 29 Aug 2008 23:30:31 GMT]]></title><description><![CDATA[<p dir="auto">That thing looks to be in decent shape.  I'd take it to Dave at Sports car engineering in Moorhead.  He could rebuild an audi turbo in his sleep.</p>
]]></description><link>https://fargostreet.com/post/222143</link><guid isPermaLink="true">https://fargostreet.com/post/222143</guid><dc:creator><![CDATA[Bassplayer]]></dc:creator><pubDate>Fri, 29 Aug 2008 23:30:31 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Fri, 29 Aug 2008 22:30:37 GMT]]></title><description><![CDATA[<p dir="auto">The only way it would have to be sent off is if balancing needs to be done....</p>
<p dir="auto">and that is only would be required if something on the rotating assembly is replaced or you didn't keep track of how the compressor wheel was indexed to the turbine shaft when you took it apart....</p>
<p dir="auto">there is nothing to a journal bearing turbo.....</p>
<p dir="auto">just make sure you keep track of where the compressor wheel was indexed on the turbine shaft when you take it apart...... spec your turbine shaft journals..... install your new bearings, seals, ect.... then put it back together with the compressor wheel in the original position....</p>
<p dir="auto">Majestic Turbo.... is who i would send it off to if i had to... cheap, and a good job....</p>
<p dir="auto">To balance a rotating assembly they only charge something like $60... and i believe it is dynamic</p>
]]></description><link>https://fargostreet.com/post/222139</link><guid isPermaLink="true">https://fargostreet.com/post/222139</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Fri, 29 Aug 2008 22:30:37 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Fri, 29 Aug 2008 17:52:45 GMT]]></title><description><![CDATA[<p dir="auto">midland diesel can do minor rebuilds. talk to ka24blahblahblah about it</p>
]]></description><link>https://fargostreet.com/post/222084</link><guid isPermaLink="true">https://fargostreet.com/post/222084</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 29 Aug 2008 17:52:45 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Fri, 29 Aug 2008 17:15:18 GMT]]></title><description><![CDATA[<p dir="auto">The reason I'm looking around for a place to rebuild is because they sold the turbo as a "rebuildable core"  mostly due to the not knowing the history on the unit.  But for how clean it looks it might not have that many miles on it.  They said it has no shaft play and spins freely, I think they were just covering themselves.  I'm just trying to get info just in case.</p>
]]></description><link>https://fargostreet.com/post/222073</link><guid isPermaLink="true">https://fargostreet.com/post/222073</guid><dc:creator><![CDATA[akielb]]></dc:creator><pubDate>Fri, 29 Aug 2008 17:15:18 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Fri, 29 Aug 2008 15:16:25 GMT]]></title><description><![CDATA[<p dir="auto">and there still might not be anything wrong with it</p>
]]></description><link>https://fargostreet.com/post/221973</link><guid isPermaLink="true">https://fargostreet.com/post/221973</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 29 Aug 2008 15:16:25 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Fri, 29 Aug 2008 15:16:03 GMT]]></title><description><![CDATA[<p dir="auto">some places can do minor rebuilds in town.</p>
]]></description><link>https://fargostreet.com/post/221972</link><guid isPermaLink="true">https://fargostreet.com/post/221972</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 29 Aug 2008 15:16:03 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Fri, 29 Aug 2008 15:03:36 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">SPANISH-RICE;233374 wrote:<br />
why do you say that?</p>
<p dir="auto">cuz no one in town can</p>
]]></description><link>https://fargostreet.com/post/221951</link><guid isPermaLink="true">https://fargostreet.com/post/221951</guid><dc:creator><![CDATA[gsrEK]]></dc:creator><pubDate>Fri, 29 Aug 2008 15:03:36 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Fri, 29 Aug 2008 14:49:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">gsrEK;233366 wrote:<br />
most likely have to send it off</p>
<p dir="auto">why do you say that?</p>
]]></description><link>https://fargostreet.com/post/221916</link><guid isPermaLink="true">https://fargostreet.com/post/221916</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 29 Aug 2008 14:49:11 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Fri, 29 Aug 2008 14:39:57 GMT]]></title><description><![CDATA[<p dir="auto">most likely have to send it off</p>
]]></description><link>https://fargostreet.com/post/221908</link><guid isPermaLink="true">https://fargostreet.com/post/221908</guid><dc:creator><![CDATA[gsrEK]]></dc:creator><pubDate>Fri, 29 Aug 2008 14:39:57 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Fri, 29 Aug 2008 14:34:56 GMT]]></title><description><![CDATA[<p dir="auto">what makes you think it might need a rebuild?</p>
]]></description><link>https://fargostreet.com/post/221904</link><guid isPermaLink="true">https://fargostreet.com/post/221904</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 29 Aug 2008 14:34:56 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Fri, 29 Aug 2008 02:08:27 GMT]]></title><description><![CDATA[<p dir="auto">it is referred to as a K03s from VW/Audi's Part # is 058-145-703-J  It is manufactured my Borg Warner KK3.  It for my Audi A4 1.8T. This is a very small upgrade from my current turbo.  Only adds 20hp but I think mine might be failing so I'm getting ready.</p>
<p dir="auto">Few pics -</p>
<p dir="auto"><img src="http://i142.photobucket.com/albums/r85/akielb/92f6_3.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i142.photobucket.com/albums/r85/akielb/949b_3.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i142.photobucket.com/albums/r85/akielb/95d4_3.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i142.photobucket.com/albums/r85/akielb/9756_3.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i142.photobucket.com/albums/r85/akielb/9909_3.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i142.photobucket.com/albums/r85/akielb/9a3c_3.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i142.photobucket.com/albums/r85/akielb/9b88_3.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i142.photobucket.com/albums/r85/akielb/9ccc_3.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/221837</link><guid isPermaLink="true">https://fargostreet.com/post/221837</guid><dc:creator><![CDATA[akielb]]></dc:creator><pubDate>Fri, 29 Aug 2008 02:08:27 GMT</pubDate></item><item><title><![CDATA[Reply to Turbo Rebuild on Fri, 29 Aug 2008 01:39:48 GMT]]></title><description><![CDATA[<p dir="auto">What kind of turbo is it?</p>
]]></description><link>https://fargostreet.com/post/221831</link><guid isPermaLink="true">https://fargostreet.com/post/221831</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Fri, 29 Aug 2008 01:39:48 GMT</pubDate></item></channel></rss>
