<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Powder coating?]]></title><description><![CDATA[<p dir="auto">Anybody in the Fargo/ Grand Forks area do any powder coating?</p>
]]></description><link>https://fargostreet.com/topic/15210/powder-coating</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 23:45:27 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/15210.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Sep 2008 02:07:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Powder coating? on Sat, 04 Oct 2008 00:08:44 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">iluvracing;239812 wrote:<br />
"in my experience".... when we wipe powder off (before it's cured "obviously") we NEVER use anything wet because then you have the chance of slight water damage which will make to part look like shit. try just using a dry finger or a paper towel. works just fine. or an air hose. which ever would work for what your doing. Ive worked in a powder shop for over 3 years now so ive seen alot of different tricks. not trying to tell you our way is better just throwing ideas out there....</p>
<p dir="auto">Ya i'm new to it and trying new stuff, some things work good some things don't work at all...<br />
When i use the sponge thing its just barely damp, wet was a bad word choice.</p>
<p dir="auto">Do you do wheels?</p>
]]></description><link>https://fargostreet.com/post/228321</link><guid isPermaLink="true">https://fargostreet.com/post/228321</guid><dc:creator><![CDATA[D Caravan]]></dc:creator><pubDate>Sat, 04 Oct 2008 00:08:44 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Fri, 03 Oct 2008 23:36:02 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">D Caravan;239737 wrote:<br />
True, the sponge idea works pretty good.  I'l see if i can get some pics of some parts ive done with two colors</p>
<p dir="auto">"in my experience".... when we wipe powder off (before it's cured "obviously") we NEVER use anything wet because then you have the chance of slight water damage which will make to part look like shit. try just using a dry finger or a paper towel. works just fine. or an air hose. which ever would work for what your doing. Ive worked in a powder shop for over 3 years now so ive seen alot of different tricks. not trying to tell you our way is better just throwing ideas out there....</p>
]]></description><link>https://fargostreet.com/post/228317</link><guid isPermaLink="true">https://fargostreet.com/post/228317</guid><dc:creator><![CDATA[iluvracing]]></dc:creator><pubDate>Fri, 03 Oct 2008 23:36:02 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Fri, 03 Oct 2008 17:17:40 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">iluvracing;239630 wrote:<br />
u can use tape but ur gunna have a lip as the second color will be 2 coats. unless you tape that shit PERFECT before u spray the first coat and tape it PERFECT before u spray your second coat. u also need to make sure that both powders are compatable with each other or it will look like shit. also your first color you spray will most likely get over cured..... you can try it worst comes to worst just strip that shit off and do it again.</p>
<p dir="auto">True, the sponge idea works pretty good.  I'l see if i can get some pics of some parts ive done with two colors</p>
]]></description><link>https://fargostreet.com/post/228242</link><guid isPermaLink="true">https://fargostreet.com/post/228242</guid><dc:creator><![CDATA[D Caravan]]></dc:creator><pubDate>Fri, 03 Oct 2008 17:17:40 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Fri, 03 Oct 2008 04:25:25 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">D Caravan;239497 wrote:<br />
PowderCoating two colors isn't that hard... On like a cylinder head or wheels or whatever... you could use high temp. tape like i have OR you can take a damp sponge and wipe off the powder you don't want to be on there.... like on lettering on a head or something</p>
<p dir="auto">u can use tape but ur gunna have a lip as the second color will be 2 coats. unless you tape that shit PERFECT before u spray the first coat and tape it PERFECT before u spray your second coat. u also need to make sure that both powders are compatable with each other or it will look like shit. also your first color you spray will most likely get over cured..... you can try it worst comes to worst just strip that shit off and do it again.</p>
]]></description><link>https://fargostreet.com/post/228135</link><guid isPermaLink="true">https://fargostreet.com/post/228135</guid><dc:creator><![CDATA[iluvracing]]></dc:creator><pubDate>Fri, 03 Oct 2008 04:25:25 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Fri, 03 Oct 2008 02:43:18 GMT]]></title><description><![CDATA[<p dir="auto">prove it</p>
]]></description><link>https://fargostreet.com/post/228087</link><guid isPermaLink="true">https://fargostreet.com/post/228087</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 03 Oct 2008 02:43:18 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Fri, 03 Oct 2008 02:37:05 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">SPANISH-RICE;239548 wrote:<br />
you dont know that</p>
<p dir="auto">i got proof</p>
]]></description><link>https://fargostreet.com/post/228067</link><guid isPermaLink="true">https://fargostreet.com/post/228067</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Fri, 03 Oct 2008 02:37:05 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Fri, 03 Oct 2008 02:34:10 GMT]]></title><description><![CDATA[<p dir="auto">you dont know that</p>
]]></description><link>https://fargostreet.com/post/228053</link><guid isPermaLink="true">https://fargostreet.com/post/228053</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 03 Oct 2008 02:34:10 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Fri, 03 Oct 2008 02:33:02 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">SPANISH-RICE;239533 wrote:<br />
whos doesnt</p>
<p dir="auto">ur mom</p>
]]></description><link>https://fargostreet.com/post/228049</link><guid isPermaLink="true">https://fargostreet.com/post/228049</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Fri, 03 Oct 2008 02:33:02 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Fri, 03 Oct 2008 02:29:35 GMT]]></title><description><![CDATA[<p dir="auto">whos doesnt</p>
]]></description><link>https://fargostreet.com/post/228038</link><guid isPermaLink="true">https://fargostreet.com/post/228038</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 03 Oct 2008 02:29:35 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Fri, 03 Oct 2008 02:25:35 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">SPANISH-RICE;239522 wrote:<br />
hmm i like powdercoating</p>
<p dir="auto">i do too</p>
]]></description><link>https://fargostreet.com/post/228029</link><guid isPermaLink="true">https://fargostreet.com/post/228029</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Fri, 03 Oct 2008 02:25:35 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Fri, 03 Oct 2008 02:00:38 GMT]]></title><description><![CDATA[<p dir="auto">hmm i like powdercoating</p>
]]></description><link>https://fargostreet.com/post/228027</link><guid isPermaLink="true">https://fargostreet.com/post/228027</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 03 Oct 2008 02:00:38 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Thu, 02 Oct 2008 23:53:57 GMT]]></title><description><![CDATA[<p dir="auto">PowderCoating two colors isn't that hard... On like a cylinder head or wheels or whatever... you could use high temp. tape like i have OR you can take a damp sponge and wipe off the powder you don't want to be on there.... like on lettering on a head or something</p>
]]></description><link>https://fargostreet.com/post/228002</link><guid isPermaLink="true">https://fargostreet.com/post/228002</guid><dc:creator><![CDATA[D Caravan]]></dc:creator><pubDate>Thu, 02 Oct 2008 23:53:57 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Thu, 02 Oct 2008 16:40:35 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Evan;239350 wrote:<br />
Ya 4 sorry. Could you possibly do flat black center with a gloss black lip?? If that is a pain in the ass, just all flat black? And how much would you charge roughly?</p>
<p dir="auto">If it's a 2 piece wheel...</p>
]]></description><link>https://fargostreet.com/post/227917</link><guid isPermaLink="true">https://fargostreet.com/post/227917</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Thu, 02 Oct 2008 16:40:35 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Thu, 02 Oct 2008 16:15:25 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">D Caravan;239399 wrote:<br />
I do some powdercoating with real small parts. My oven is a bigger toaster oven so its good for the stand up jetski parts i use it with but other than that not much fits is...<br />
I bought my gun from <a href="http://eastwoodco.com" rel="nofollow ugc">eastwoodco.com</a> and it works pretty good.<br />
Ive done some motorcycle parts and jetski parts is about it and i usually do chrome for a base coat for a candy blue or candy purple...</p>
<p dir="auto">Would it be expensive to wire a house oven? in the garage</p>
<p dir="auto">I'm pretty sure that's the place we got our gun from too...</p>
]]></description><link>https://fargostreet.com/post/227908</link><guid isPermaLink="true">https://fargostreet.com/post/227908</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Thu, 02 Oct 2008 16:15:25 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Thu, 02 Oct 2008 16:15:00 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">iluvracing;239352 wrote:<br />
can't do 2 diff. colors on something like that sorry man. a could do flat black. I will pm u a price. medium gloss last WAY longer and is easier. but its what YOU  wat and I can make that happen</p>
<p dir="auto">Cant u powdercoat one color and when that's done tape it off and do the other?</p>
]]></description><link>https://fargostreet.com/post/227907</link><guid isPermaLink="true">https://fargostreet.com/post/227907</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Thu, 02 Oct 2008 16:15:00 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Thu, 02 Oct 2008 16:08:29 GMT]]></title><description><![CDATA[<p dir="auto">Toaster oven? Never thought of that. Dang those would have to be small parts.</p>
]]></description><link>https://fargostreet.com/post/227906</link><guid isPermaLink="true">https://fargostreet.com/post/227906</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Thu, 02 Oct 2008 16:08:29 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Thu, 02 Oct 2008 15:46:07 GMT]]></title><description><![CDATA[<p dir="auto">I do some powdercoating with real small parts. My oven is a bigger toaster oven so its good for the stand up jetski parts i use it with but other than that not much fits is...<br />
]]></description><link>https://fargostreet.com/post/227904</link><guid isPermaLink="true">https://fargostreet.com/post/227904</guid><dc:creator><![CDATA[D Caravan]]></dc:creator><pubDate>Thu, 02 Oct 2008 15:46:07 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Thu, 02 Oct 2008 06:28:17 GMT]]></title><description><![CDATA[<p dir="auto">can't do 2 diff. colors on something like that sorry man. a could do flat black. I will pm u a price. medium gloss last WAY longer and is easier. but its what YOU  wat and I can make that happen</p>
]]></description><link>https://fargostreet.com/post/227857</link><guid isPermaLink="true">https://fargostreet.com/post/227857</guid><dc:creator><![CDATA[iluvracing]]></dc:creator><pubDate>Thu, 02 Oct 2008 06:28:17 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Thu, 02 Oct 2008 06:10:01 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">iluvracing;239348 wrote:<br />
pair is 2. i'm assuming 4.... what color and i don't really care what size we can do it if color is right.... if your looking for chrome then sorry. I can't help u there. black I can do very easily. lmk.</p>
<p dir="auto">Ya 4 sorry. Could you possibly do flat black center with a gloss black lip?? If that is a pain in the ass, just all flat black? And how much would you charge roughly?</p>
]]></description><link>https://fargostreet.com/post/227855</link><guid isPermaLink="true">https://fargostreet.com/post/227855</guid><dc:creator><![CDATA[Evan]]></dc:creator><pubDate>Thu, 02 Oct 2008 06:10:01 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Thu, 02 Oct 2008 06:03:06 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Evan;239345 wrote:<br />
Sorry I didnt post til now, just busy with school and everything but they would be pair of rims. If I remember right they would be 18x12. (Not sure on the size though)</p>
<p dir="auto">pair is 2. i'm assuming 4.... what color and i don't really care what size we can do it if color is right.... if your looking for chrome then sorry. I can't help u there. black I can do very easily. lmk.</p>
]]></description><link>https://fargostreet.com/post/227853</link><guid isPermaLink="true">https://fargostreet.com/post/227853</guid><dc:creator><![CDATA[iluvracing]]></dc:creator><pubDate>Thu, 02 Oct 2008 06:03:06 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Thu, 02 Oct 2008 05:51:39 GMT]]></title><description><![CDATA[<p dir="auto">Sorry I didnt post til now, just busy with school and everything but they would be pair of rims. If I remember right they would be 18x12. (Not sure on the size though)</p>
]]></description><link>https://fargostreet.com/post/227850</link><guid isPermaLink="true">https://fargostreet.com/post/227850</guid><dc:creator><![CDATA[Evan]]></dc:creator><pubDate>Thu, 02 Oct 2008 05:51:39 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Wed, 01 Oct 2008 03:47:29 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">bubba;238885 wrote:<br />
Ya only thing that sucks is the biggest wheel we can do are 16's, course for a civic that's perfect</p>
<p dir="auto">ya for sure man. but if you need anything bigger done just lmk. We can do damn near anything where I work. "might even be able to cut u a deal" lol</p>
]]></description><link>https://fargostreet.com/post/227542</link><guid isPermaLink="true">https://fargostreet.com/post/227542</guid><dc:creator><![CDATA[iluvracing]]></dc:creator><pubDate>Wed, 01 Oct 2008 03:47:29 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Tue, 30 Sep 2008 17:01:48 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">iluvracing;238771 wrote:<br />
that's sweet man. I work at midwest coatings in west fargo so I have access when I need. good to hear someone did this cuz it's a hella lot cheaper to do it your self. Well... small shit anyway.</p>
<p dir="auto">Ya only thing that sucks is the biggest wheel we can do are 16's, course for a civic that's perfect</p>
]]></description><link>https://fargostreet.com/post/227391</link><guid isPermaLink="true">https://fargostreet.com/post/227391</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Tue, 30 Sep 2008 17:01:48 GMT</pubDate></item><item><title><![CDATA[Reply to Powder coating? on Tue, 30 Sep 2008 03:16:56 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">bubba;238409 wrote:<br />
old house oven... idk where they got the gun... i just shelled out my share of the cash for it, lol... does great work, have done a set of wheels, and a few vc's and other little stuff with it</p>
<p dir="auto">that's sweet man. I work at midwest coatings in west fargo so I have access when I need. good to hear someone did this cuz it's a hella lot cheaper to do it your self. Well... small shit anyway.</p>
]]></description><link>https://fargostreet.com/post/227277</link><guid isPermaLink="true">https://fargostreet.com/post/227277</guid><dc:creator><![CDATA[iluvracing]]></dc:creator><pubDate>Tue, 30 Sep 2008 03:16:56 GMT</pubDate></item></channel></rss>
