<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CRX sputtering]]></title><description><![CDATA[<p dir="auto">Here's the deal, 1991 CRX D15, just did timing belt, head gasket, new spark plugs, some other gaskets.  Driving the car anything under 2500RPMs and over about 1/4 throttle it will sputter like its only running on 2 or 3 cylinders.  Plugs are fine, not sure about the plug wires or distributor though.  I believe the distributor is only a year old or so, if that.  I'm thinking is a spark problem because sometimes it smells a little like gas.  Anyone have an idea?  Or maybe a distributor or plug wires I could just try out?</p>
]]></description><link>https://fargostreet.com/topic/15224/crx-sputtering</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 22:50:44 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/15224.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Sep 2008 17:51:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CRX sputtering on Mon, 29 Sep 2008 22:08:53 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the info.  Even when I free rev it, it will sputter for a half sec and then rev just fine.  I might mess w/ the timing belt.  I just want to verify that the single cam will run just fine in certain RPM and throttle ranges when the timing belt is off.  That's quite a bit different than a DOHC cam motor which is what I'm used to.</p>
]]></description><link>https://fargostreet.com/post/227162</link><guid isPermaLink="true">https://fargostreet.com/post/227162</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Mon, 29 Sep 2008 22:08:53 GMT</pubDate></item><item><title><![CDATA[Reply to CRX sputtering on Mon, 29 Sep 2008 04:12:02 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">treimche;238457 wrote:<br />
Yeah I'm sure if the firing order was incorrect, the car would run like total horseshit.  Same with the timing belt, if it was off a tooth, it would probably run really badly.  I'll have to find some specs for the coil and try that out.</p>
<p dir="auto">if the timing belt is off it can run fine but studder through the entire rpm range.   take the dizzy cap off, the bolt that holds the rotor on, the rotor, then unscrew the two screws holding the wires on the coil, ohm it out, should be 16 ohms. if its lower your coil is weak.</p>
]]></description><link>https://fargostreet.com/post/227025</link><guid isPermaLink="true">https://fargostreet.com/post/227025</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Mon, 29 Sep 2008 04:12:02 GMT</pubDate></item><item><title><![CDATA[Reply to CRX sputtering on Mon, 29 Sep 2008 03:44:54 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">treimche;238465 wrote:<br />
Well I wasn't aware that it would run good at all w/ the timing belt off a tooth.</p>
<p dir="auto">Mine was off like 2 or 3 teeth... bogged out bad till bout 3-4k rpms then would go just fine...</p>
]]></description><link>https://fargostreet.com/post/227004</link><guid isPermaLink="true">https://fargostreet.com/post/227004</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Mon, 29 Sep 2008 03:44:54 GMT</pubDate></item><item><title><![CDATA[Reply to CRX sputtering on Mon, 29 Sep 2008 01:26:00 GMT]]></title><description><![CDATA[<p dir="auto">Well I wasn't aware that it would run good at all w/ the timing belt off a tooth.</p>
]]></description><link>https://fargostreet.com/post/226974</link><guid isPermaLink="true">https://fargostreet.com/post/226974</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Mon, 29 Sep 2008 01:26:00 GMT</pubDate></item><item><title><![CDATA[Reply to CRX sputtering on Mon, 29 Sep 2008 01:17:57 GMT]]></title><description><![CDATA[<p dir="auto">well i dont know about a honda,  but yes when my timing belt was off 1 cog the car did run and infact it did run like it had a limiter.  but,  Sorry for giving my advise on this subject,  apparently some know more about it,  ill step aside and let them fix it.  :icon_puke_r:</p>
]]></description><link>https://fargostreet.com/post/226972</link><guid isPermaLink="true">https://fargostreet.com/post/226972</guid><dc:creator><![CDATA[Goodnbuzzd]]></dc:creator><pubDate>Mon, 29 Sep 2008 01:17:57 GMT</pubDate></item><item><title><![CDATA[Reply to CRX sputtering on Mon, 29 Sep 2008 00:59:50 GMT]]></title><description><![CDATA[<p dir="auto">Yeah I'm sure if the firing order was incorrect, the car would run like total horseshit.  Same with the timing belt, if it was off a tooth, it would probably run really badly.  I'll have to find some specs for the coil and try that out.</p>
]]></description><link>https://fargostreet.com/post/226966</link><guid isPermaLink="true">https://fargostreet.com/post/226966</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Mon, 29 Sep 2008 00:59:50 GMT</pubDate></item><item><title><![CDATA[Reply to CRX sputtering on Sun, 28 Sep 2008 05:19:02 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">no_slow_clap;238329 wrote:<br />
check your firing order, and your timing</p>
<p dir="auto">Goodnbuzzd;238378 wrote:<br />
like clap says.  id double check the firing order,   as for the timing i had a car that did that.  mine turned out to be a intermediate shaft on the distributor.  seeing you did a belt make sure you arent a cog or two off.</p>
<p dir="auto">so the car is gonna run just fine above 2500rpm with a mixed up firing order huh??</p>
]]></description><link>https://fargostreet.com/post/226928</link><guid isPermaLink="true">https://fargostreet.com/post/226928</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sun, 28 Sep 2008 05:19:02 GMT</pubDate></item><item><title><![CDATA[Reply to CRX sputtering on Sun, 28 Sep 2008 02:53:53 GMT]]></title><description><![CDATA[<p dir="auto">take your coil out and ohm it out. sounds like ur problem, weak coil</p>
]]></description><link>https://fargostreet.com/post/226914</link><guid isPermaLink="true">https://fargostreet.com/post/226914</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Sun, 28 Sep 2008 02:53:53 GMT</pubDate></item><item><title><![CDATA[Reply to CRX sputtering on Sun, 28 Sep 2008 01:04:24 GMT]]></title><description><![CDATA[<p dir="auto">pull em out and check to make sure each of them is getting spark, it they are then your dizzy, wires, and plugs are good...double check the firing order just to be sure too.</p>
]]></description><link>https://fargostreet.com/post/226897</link><guid isPermaLink="true">https://fargostreet.com/post/226897</guid><dc:creator><![CDATA[DelSlow]]></dc:creator><pubDate>Sun, 28 Sep 2008 01:04:24 GMT</pubDate></item><item><title><![CDATA[Reply to CRX sputtering on Sun, 28 Sep 2008 00:08:09 GMT]]></title><description><![CDATA[<p dir="auto">like clap says.  id double check the firing order,   as for the timing i had a car that did that.  mine turned out to be a intermediate shaft on the distributor.  seeing you did a belt make sure you arent a cog or two off.</p>
]]></description><link>https://fargostreet.com/post/226890</link><guid isPermaLink="true">https://fargostreet.com/post/226890</guid><dc:creator><![CDATA[Goodnbuzzd]]></dc:creator><pubDate>Sun, 28 Sep 2008 00:08:09 GMT</pubDate></item><item><title><![CDATA[Reply to CRX sputtering on Sat, 27 Sep 2008 18:01:48 GMT]]></title><description><![CDATA[<p dir="auto">check your firing order, and your timing</p>
]]></description><link>https://fargostreet.com/post/226841</link><guid isPermaLink="true">https://fargostreet.com/post/226841</guid><dc:creator><![CDATA[no_slow_clap]]></dc:creator><pubDate>Sat, 27 Sep 2008 18:01:48 GMT</pubDate></item><item><title><![CDATA[Reply to CRX sputtering on Sat, 27 Sep 2008 17:53:38 GMT]]></title><description><![CDATA[<p dir="auto">Have scott call kyle and ask him!</p>
]]></description><link>https://fargostreet.com/post/226838</link><guid isPermaLink="true">https://fargostreet.com/post/226838</guid><dc:creator><![CDATA[King Ricer]]></dc:creator><pubDate>Sat, 27 Sep 2008 17:53:38 GMT</pubDate></item></channel></rss>
