<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2004 nissan sentra]]></title><description><![CDATA[<p dir="auto">2004 nissan sentra 1.8s in good shape.  Original owner. 70xxx miles. Excellent gas mileage (average 28-32 mpg city/highway).  Kelly Blue Book lists this car at $7740 in good condition.</p>
<p dir="auto">Good:<br />
-Mechanic owned.<br />
-Oil changed every 2.5-3k miles.<br />
-Air filter replaced 2k miles ago.<br />
-Spark plugs replaced 2k miles ago.<br />
-Battery replaced 15k miles ago.<br />
-Toyo Spectrum tires put on 15K miles ago.<br />
-Fuel pump was replaced at 35K miles under warranty due to a common problem with the fuel pressure regulator.<br />
-No leaks.<br />
-No rock chips/cracks/damage to any windows.<br />
-No rust<br />
-A/C recharged this past spring, blows ICE COLD.<br />
-Heat blows HOT.<br />
-Sony AM/FM/CD/MP3 player (I can put the OEM CD player back in if you want).<br />
-Front brake pads replaced 6K miles ago.<br />
-Has a block heater, but I've never had to use it.</p>
<p dir="auto">Bad:<br />
-Interior has quite a few stains, vehicle needs an interior detail (again, mechanic owned).<br />
-Vehicle has some scratches and dings.<br />
-Belts chirp if there is a lot of moisture in the air, this is a common problem with this engine and is a simple fix, I just haven't gotten around to fixing it. (nissan has redesigned the belts to fix this problem).</p>
<p dir="auto">$6500</p>
<p dir="auto">VIN:3N1CB51D44L855219</p>
<p dir="auto">PICS:<br />
<img src="http://i12.photobucket.com/albums/a238/darkelvis83/IMG_0850.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i12.photobucket.com/albums/a238/darkelvis83/IMG_0849.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i12.photobucket.com/albums/a238/darkelvis83/IMG_0848.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i12.photobucket.com/albums/a238/darkelvis83/IMG_0847.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/topic/15302/2004-nissan-sentra</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 00:18:51 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/15302.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 Oct 2008 00:47:31 GMT</pubDate><ttl>60</ttl></channel></rss>
