<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Why people need to build LSx instead of gay hondas]]></title><description><![CDATA[<p dir="auto">Combo is as follows.....</p>
<p dir="auto">2004 gm 5.3 lsx based truck motor(Cylinder heads have never even been off the motor)<br />
comp 212/218 and .522/.529 lift on 114 LSA<br />
Arp cam retainer bolts<br />
Arp rod bolts<br />
ls6 Corvette intake<br />
Ported Throttle body<br />
60lb injectors<br />
comp 918 beehive valve springs<br />
comp titanium valve spring retainers<br />
comp 7.4" hardened pushrods<br />
stock Ecm tuned by Horsepower Soloutions VIA EFI Live<br />
Custom turbo kit built by me<br />
Turbonetics Tc76mps Water cooled ball bearing turbo<br />
Turbosmart 38mm wastegate<br />
cheap blow off valve<br />
3" Open downpipe</p>
<p dir="auto">Never got a chance to turn the boost up anymore as food poisoning took me out of commission lol</p>
<p dir="auto">Cars best Et was 9.99@140.6 with a race weight of 3190 lbs and lots of 10.0 - 10.1 passes this year total I made right around 130-150 passes with ZERO breakage,aside from a couple of rubber intake boots.</p>
<p dir="auto"><img src="http://i10.photobucket.com/albums/a142/tirefryin_s10/Mailmanbest.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i10.photobucket.com/albums/a142/tirefryin_s10/Mailmanbeston165psiHOT.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<a href="http://s116.photobucket.com/albums/o4/puggs25/?action=view&amp;current=DynoDay2008008.flv" rel="nofollow ugc"><img src="http://i116.photobucket.com/albums/o4/puggs25/th_DynoDay2008008.jpg" alt="legacy image" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Car is a fox body notchback, stock suspension, really no mods as he did this as a budget build</p>
]]></description><link>https://fargostreet.com/topic/15364/why-people-need-to-build-lsx-instead-of-gay-hondas</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 00:32:20 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/15364.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Oct 2008 03:48:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Mon, 13 Oct 2008 02:02:28 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">zbrown;241209 wrote:<br />
Gary was close in $$ for what it cost me for what i had in my car earlier this year</p>
<p dir="auto">ARP rod bolts are your friend in these motors<br />
and so are motors that came out of cars that WERE NOT in a rollover :rolleyes:</p>
]]></description><link>https://fargostreet.com/post/229752</link><guid isPermaLink="true">https://fargostreet.com/post/229752</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Mon, 13 Oct 2008 02:02:28 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 20:41:21 GMT]]></title><description><![CDATA[<p dir="auto">Gary was close in $$ for what it cost me for what i had in my car earlier this year</p>
<p dir="auto">ARP rod bolts are your friend in these motors</p>
]]></description><link>https://fargostreet.com/post/229713</link><guid isPermaLink="true">https://fargostreet.com/post/229713</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sun, 12 Oct 2008 20:41:21 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 18:22:09 GMT]]></title><description><![CDATA[<p dir="auto">cool</p>
]]></description><link>https://fargostreet.com/post/229693</link><guid isPermaLink="true">https://fargostreet.com/post/229693</guid><dc:creator><![CDATA[no_slow_clap]]></dc:creator><pubDate>Sun, 12 Oct 2008 18:22:09 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 17:52:21 GMT]]></title><description><![CDATA[<p dir="auto">I would also say that a honda would cost more to  build and make that kinda power....</p>
]]></description><link>https://fargostreet.com/post/229682</link><guid isPermaLink="true">https://fargostreet.com/post/229682</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Sun, 12 Oct 2008 17:52:21 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 17:12:45 GMT]]></title><description><![CDATA[<p dir="auto">Yeah I was watching his build on ls1tech impressive! But you also have to add a tranny that will bolt up custom crossmember, driveshaft,coils,harness fabbed headers  etc etc etc. It does add up when you add all the shit you forget about. Pretty sure in order to run the ls6 intakes you need to run all the ls1 acc. to clear for the t body opening.</p>
]]></description><link>https://fargostreet.com/post/229675</link><guid isPermaLink="true">https://fargostreet.com/post/229675</guid><dc:creator><![CDATA[Christian]]></dc:creator><pubDate>Sun, 12 Oct 2008 17:12:45 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 16:44:39 GMT]]></title><description><![CDATA[<p dir="auto">For the motor its cheap, maybe zac will chime in on this, but its pretty much what he had this spring.  He had a better intake setup, but same engine, same cam, etc.<br />
Engine-$500<br />
Intake-450<br />
Injectors-375<br />
Cam-250<br />
ARP hardware-about 500<br />
springs/retainers/pushrods-550<br />
HPTuners-525<br />
Thats $3150, and im sure he got this stuff cheaper than that.  Add on whatever you can get a turbo setup for, like mine, $575 for a BW S400 and enough pipe for a merge and Downpipe using the stock manifolds.  Your still gonna be WAY below $5k<br />
Also some of this you dont need until you start to push over 12psi.  The stock springs and retainers will hold up to about 12psi, i was still using them.  And you guys saw my car, that was a completely stock 6.0L with a cam and boost.  You see i didnt have shit into it and it was fast as hell for being 3700+lbs.</p>
]]></description><link>https://fargostreet.com/post/229673</link><guid isPermaLink="true">https://fargostreet.com/post/229673</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Sun, 12 Oct 2008 16:44:39 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 15:48:00 GMT]]></title><description><![CDATA[<p dir="auto">Ya... i was looking in some v8 mag last night at work... saw the weight of a vega and started getting some ideas, lol...</p>
]]></description><link>https://fargostreet.com/post/229655</link><guid isPermaLink="true">https://fargostreet.com/post/229655</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Sun, 12 Oct 2008 15:48:00 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 14:59:11 GMT]]></title><description><![CDATA[<p dir="auto">So how much would it be to build an lsx like that? Maybe not quite that crazy but around there.</p>
]]></description><link>https://fargostreet.com/post/229646</link><guid isPermaLink="true">https://fargostreet.com/post/229646</guid><dc:creator><![CDATA[Bassplayer]]></dc:creator><pubDate>Sun, 12 Oct 2008 14:59:11 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 14:49:47 GMT]]></title><description><![CDATA[<p dir="auto">WOW! That car just twists. Sweet!</p>
]]></description><link>https://fargostreet.com/post/229644</link><guid isPermaLink="true">https://fargostreet.com/post/229644</guid><dc:creator><![CDATA[ruthless351]]></dc:creator><pubDate>Sun, 12 Oct 2008 14:49:47 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 05:54:49 GMT]]></title><description><![CDATA[<p dir="auto">i bet its not very much, probably 8k or so<br />
if your interested, full thread is here<br />
<a href="http://ls1tech.com/forums/showthread.php?t=706756" rel="nofollow ugc">http://ls1tech.com/forums/showthread.php?t=706756</a></p>
]]></description><link>https://fargostreet.com/post/229618</link><guid isPermaLink="true">https://fargostreet.com/post/229618</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Sun, 12 Oct 2008 05:54:49 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 05:38:00 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Slowica;241109 wrote:<br />
and cost of it all?</p>
<p dir="auto">its probably not as expensive as you would think</p>
]]></description><link>https://fargostreet.com/post/229615</link><guid isPermaLink="true">https://fargostreet.com/post/229615</guid><dc:creator><![CDATA[94civicex]]></dc:creator><pubDate>Sun, 12 Oct 2008 05:38:00 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 05:35:56 GMT]]></title><description><![CDATA[<p dir="auto">and cost of it all?</p>
]]></description><link>https://fargostreet.com/post/229613</link><guid isPermaLink="true">https://fargostreet.com/post/229613</guid><dc:creator><![CDATA[Slowica]]></dc:creator><pubDate>Sun, 12 Oct 2008 05:35:56 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 04:08:35 GMT]]></title><description><![CDATA[<p dir="auto">.<br />
.<br />
.<br />
.<br />
.<br />
.<br />
.<br />
.<br />
.<br />
.<br />
.<br />
.<br />
.<br />
.<br />
.<br />
.<br />
.</p>
<p dir="auto">yea.  do want!</p>
]]></description><link>https://fargostreet.com/post/229606</link><guid isPermaLink="true">https://fargostreet.com/post/229606</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Sun, 12 Oct 2008 04:08:35 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 04:08:15 GMT]]></title><description><![CDATA[<p dir="auto">do want?</p>
]]></description><link>https://fargostreet.com/post/229605</link><guid isPermaLink="true">https://fargostreet.com/post/229605</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Sun, 12 Oct 2008 04:08:15 GMT</pubDate></item><item><title><![CDATA[Reply to Why people need to build LSx instead of gay hondas on Sun, 12 Oct 2008 03:50:46 GMT]]></title><description><![CDATA[<p dir="auto">thats cool......  I guess</p>
]]></description><link>https://fargostreet.com/post/229602</link><guid isPermaLink="true">https://fargostreet.com/post/229602</guid><dc:creator><![CDATA[hondo04]]></dc:creator><pubDate>Sun, 12 Oct 2008 03:50:46 GMT</pubDate></item></channel></rss>
