<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Time Attack Subaru]]></title><description><![CDATA[<p dir="auto">Thanks to the boys at TM for this one.....<br />
<em>EDIT</em>(Thanks for the link Colin)</p>
<p dir="auto">The "Gobstopper" WRX</p>
<p dir="auto"><em>VID</em><br />
<a href="http://vimeo.com/1975245" rel="nofollow ugc">http://vimeo.com/1975245</a></p>
<p dir="auto">Homeboy can drive.</p>
<p dir="auto"><em>PICS</em><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/111.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/114.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/022.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/023.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/096.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/097.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/098.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/011.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/068.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/085-1.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/113.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/116.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/109.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/110.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/187.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/118.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/122.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v636/2wheeler/130.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><em>MOD LIST</em></p>
<p dir="auto">Body<br />
WRC steel arches WRC front and rear bumpers<br />
WRC carbon rear spoiler<br />
FIA T45 multi point welded in roll cage<br />
STi alloy bonnet with RCMS heat extraction vents and gas struts<br />
Heated front screen<br />
WRC non heated lightweight rear screen</p>
<p dir="auto">Engine<br />
2.0Litre closed deck subaru block<br />
RCMS extreme arrow rods<br />
RCMS 75mm steel crankshaft<br />
RCMS omega flat top pistons (coated) compression ratio 9.5:1<br />
V4 STi cylinder heads with WRC/RCMS O-ring head gaskets and gas rings<br />
One piece Nimonic exhaust valves<br />
One piece stainless inlet valves<br />
RCMS uprated valve springs<br />
Plasma nitrided titanium spring caps<br />
WRC main and big end bearings<br />
WRC R-Profile high wrap cam belt system<br />
RCMS modified oil pump to suit R-Profile belt<br />
WRC S10 inlet manifold<br />
RCMS eight injector kit<br />
RCMS 72mm throttle body<br />
RCMS 5.5 litre alloy sump<br />
WRC short runner exhaust manifold<br />
Garret GT 35-40 turbo with speed sensor<br />
K&amp;N air filter with RCMS 100mm inlet trumpet<br />
RCMS high flow intercooler with twin tube core<br />
70mm stainless steel intercooler pipe work</p>
<p dir="auto">Electronics<br />
M800 Motec ECU with traction control,nitrous control,anti-lag<br />
paddle shift control,and full engine management control and data login<br />
Motec dash with data login<br />
Defi gauges for turbo,oil,fuel pressure<br />
Interior<br />
FIA carbon kevlar recaro seats<br />
FIA sabelt 6-point harness<br />
Transmission<br />
R180 STi rear axle 3.9:1 cwp and plated modena LSD differential<br />
GKN rally drive shafts front and rear<br />
Torque line carbon fibre propshaft<br />
Six speed subaru gearbox casing modified for sequential housing<br />
Six speed modena gear kit<br />
Subaru 3.9:1 front cwp<br />
RCMS sequential system<br />
RCMS paddle shift system<br />
Plated centre diff with 1:1 uprated output modena gears<br />
Plated front modena differential<br />
Fuel System<br />
FIA spec 26 litre rubber/kevlar bag tank in aluminium cover<br />
Twin bosch fuel pumps (200 litre per pump)<br />
-8 Goodrich fuel feed pipe<br />
-6 Goodrich fuel return pipe<br />
-6 fuel cooler with cooling fan on return<br />
RCMS 8 injector distribution block<br />
2x SX fuel regulators running at 4 bar static pressure</p>
<p dir="auto">Suspension<br />
WRC spec exe-tc fully ajustable dampers<br />
High and low speed bump + rebound ajustment<br />
STi Rose jointed rear lateral links<br />
STi Rose jointed rear trailing links<br />
Exe-tc bottom rose jointed upright bushes<br />
STi alloy front arms (polished)<br />
STi quick-steer steering rack<br />
WRC roller bearing single piece steering column<br />
Momo suede steering wheel</p>
<p dir="auto">Nitrous<br />
NX full wet system<br />
121bs carbon bottle with heater jacket<br />
High flow shark nozzle<br />
Motec auto control or driver manual system<br />
Ajustable from +35bhp to +400bhp</p>
<p dir="auto">Clutch<br />
RCMS spec triple plate alloy cover OS GIKEN clutch and flywheel<br />
RCMS hydraulic light pressure system<br />
Quick release dry brake fluid connection</p>
<p dir="auto">Brakes<br />
AP 355mm six pot front (track and road use)<br />
AP 304mm four pot front (drag strip use)<br />
AP 290mm four pot rear with floating discs<br />
RCMS hydraulic carbon handbrake<br />
-3 stainless steel goodrich pipe work and fittings</p>
<p dir="auto">Wheels<br />
Road/Track use 19x8 forged alloy 1 piece rims<br />
Drag strip use 15x8 spun alloy 3 piece rims</p>
<p dir="auto">Power=850 bhp<br />
Weight=2500 lbs</p>
]]></description><link>https://fargostreet.com/topic/15401/time-attack-subaru</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 07:33:04 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/15401.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 16 Oct 2008 22:23:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Time Attack Subaru on Sat, 18 Oct 2008 22:06:41 GMT]]></title><description><![CDATA[<p dir="auto">add to cart and check out!!!</p>
]]></description><link>https://fargostreet.com/post/231167</link><guid isPermaLink="true">https://fargostreet.com/post/231167</guid><dc:creator><![CDATA[tmoney]]></dc:creator><pubDate>Sat, 18 Oct 2008 22:06:41 GMT</pubDate></item><item><title><![CDATA[Reply to Time Attack Subaru on Sat, 18 Oct 2008 18:01:53 GMT]]></title><description><![CDATA[<p dir="auto">That thing scoots!!!</p>
]]></description><link>https://fargostreet.com/post/231138</link><guid isPermaLink="true">https://fargostreet.com/post/231138</guid><dc:creator><![CDATA[capitlj]]></dc:creator><pubDate>Sat, 18 Oct 2008 18:01:53 GMT</pubDate></item><item><title><![CDATA[Reply to Time Attack Subaru on Sat, 18 Oct 2008 16:49:06 GMT]]></title><description><![CDATA[<p dir="auto">Guys got some skills. Drives on the edge fo sho!!</p>
]]></description><link>https://fargostreet.com/post/231122</link><guid isPermaLink="true">https://fargostreet.com/post/231122</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sat, 18 Oct 2008 16:49:06 GMT</pubDate></item><item><title><![CDATA[Reply to Time Attack Subaru on Sat, 18 Oct 2008 15:13:36 GMT]]></title><description><![CDATA[<p dir="auto">Ballin!</p>
]]></description><link>https://fargostreet.com/post/231117</link><guid isPermaLink="true">https://fargostreet.com/post/231117</guid><dc:creator><![CDATA[Afsil80]]></dc:creator><pubDate>Sat, 18 Oct 2008 15:13:36 GMT</pubDate></item><item><title><![CDATA[Reply to Time Attack Subaru on Sat, 18 Oct 2008 04:47:43 GMT]]></title><description><![CDATA[<p dir="auto">Gobstopper = Scooby with rabies. :3gears:</p>
]]></description><link>https://fargostreet.com/post/231045</link><guid isPermaLink="true">https://fargostreet.com/post/231045</guid><dc:creator><![CDATA[ichibankilla]]></dc:creator><pubDate>Sat, 18 Oct 2008 04:47:43 GMT</pubDate></item><item><title><![CDATA[Reply to Time Attack Subaru on Sat, 18 Oct 2008 00:56:00 GMT]]></title><description><![CDATA[<p dir="auto">Dead sexy</p>
]]></description><link>https://fargostreet.com/post/231025</link><guid isPermaLink="true">https://fargostreet.com/post/231025</guid><dc:creator><![CDATA[Sweet-WRX-Lovin]]></dc:creator><pubDate>Sat, 18 Oct 2008 00:56:00 GMT</pubDate></item><item><title><![CDATA[Reply to Time Attack Subaru on Fri, 17 Oct 2008 02:36:21 GMT]]></title><description><![CDATA[<p dir="auto">The way he drives you'd think he made a deal with the man downstairs. Holy Shit!</p>
]]></description><link>https://fargostreet.com/post/230901</link><guid isPermaLink="true">https://fargostreet.com/post/230901</guid><dc:creator><![CDATA[ichibankilla]]></dc:creator><pubDate>Fri, 17 Oct 2008 02:36:21 GMT</pubDate></item><item><title><![CDATA[Reply to Time Attack Subaru on Fri, 17 Oct 2008 02:01:38 GMT]]></title><description><![CDATA[<p dir="auto">god damn, bitch can drive</p>
]]></description><link>https://fargostreet.com/post/230896</link><guid isPermaLink="true">https://fargostreet.com/post/230896</guid><dc:creator><![CDATA[Slowica]]></dc:creator><pubDate>Fri, 17 Oct 2008 02:01:38 GMT</pubDate></item><item><title><![CDATA[Reply to Time Attack Subaru on Thu, 16 Oct 2008 22:57:54 GMT]]></title><description><![CDATA[<p dir="auto">The gobbstopper is what a WRC subaru would be without any of the restrictions.  In my opinion it's even cooler that the 2 door evo.</p>
<p dir="auto">here's the build thread:  <a href="http://forums.nasioc.com/forums/showthread.php?t=1023928" rel="nofollow ugc">http://forums.nasioc.com/forums/showthread.php?t=1023928</a></p>
]]></description><link>https://fargostreet.com/post/230859</link><guid isPermaLink="true">https://fargostreet.com/post/230859</guid><dc:creator><![CDATA[Colin]]></dc:creator><pubDate>Thu, 16 Oct 2008 22:57:54 GMT</pubDate></item><item><title><![CDATA[Reply to Time Attack Subaru on Thu, 16 Oct 2008 22:38:21 GMT]]></title><description><![CDATA[<p dir="auto">Hawt damn! Thats awesome!</p>
]]></description><link>https://fargostreet.com/post/230852</link><guid isPermaLink="true">https://fargostreet.com/post/230852</guid><dc:creator><![CDATA[D S ohM]]></dc:creator><pubDate>Thu, 16 Oct 2008 22:38:21 GMT</pubDate></item><item><title><![CDATA[Reply to Time Attack Subaru on Thu, 16 Oct 2008 22:33:18 GMT]]></title><description><![CDATA[<p dir="auto">That's pimp as hell.</p>
]]></description><link>https://fargostreet.com/post/230851</link><guid isPermaLink="true">https://fargostreet.com/post/230851</guid><dc:creator><![CDATA[Bassplayer]]></dc:creator><pubDate>Thu, 16 Oct 2008 22:33:18 GMT</pubDate></item><item><title><![CDATA[Reply to Time Attack Subaru on Thu, 16 Oct 2008 22:31:06 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">integra_gsr98;242345 wrote:<br />
fucking -sick-</p>
<p dir="auto">^^^^qfmft^^^^</p>
]]></description><link>https://fargostreet.com/post/230850</link><guid isPermaLink="true">https://fargostreet.com/post/230850</guid><dc:creator><![CDATA[2wheeler]]></dc:creator><pubDate>Thu, 16 Oct 2008 22:31:06 GMT</pubDate></item><item><title><![CDATA[Reply to Time Attack Subaru on Thu, 16 Oct 2008 22:26:04 GMT]]></title><description><![CDATA[<p dir="auto">fucking -sick-</p>
]]></description><link>https://fargostreet.com/post/230848</link><guid isPermaLink="true">https://fargostreet.com/post/230848</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Thu, 16 Oct 2008 22:26:04 GMT</pubDate></item></channel></rss>
