<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Toyota 4Runner O&#x2F;D problem]]></title><description><![CDATA[<p dir="auto">I recently bought a '94 4Runner and have a couple questions.</p>
<p dir="auto">First, I haven't owned an obd1 car in 10 years. With all the obd2 cars I've owned, I could just go to OReilly's or any other parts store and pull the cel codes. Where can you pull obd1 cel codes for free or cheap?</p>
<p dir="auto">Second, the truck has a problem shifting into 4th gear when it is cold. If I drive around town for 5 minutes and warm the truck up, it shifts into 4th just fine. If I drive straight to the interstate when its cold, it won't shift into 4th until it warms up. Any ideas what it might be?</p>
]]></description><link>https://fargostreet.com/topic/15699/toyota-4runner-o-d-problem</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:35:40 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/15699.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 20 Nov 2008 20:20:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Toyota 4Runner O&#x2F;D problem on Fri, 21 Nov 2008 14:16:38 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">PSiedTSi;247305 wrote:<br />
Agreed to above statements...I'm sure thats exactly what it is...</p>
<p dir="auto">For codes, look online for a site that specializes in 4runners as there might be a pin or two to jump with say a paper clip to get the code to flash on the dash like on other older OBDI cars...</p>
<p dir="auto">BTW, How do you like the 4runner? I've kinda been lookin at em since they are cheap for 94-95($1500 or so), but have heard they are underpowered...whats your thoughts?</p>
<p dir="auto">I really like some things, others not so much. It's a little underpowered with the small v6 but it rides 10x nicer than the other early-mid 90s SUVs I drove. Also, there don't seem to be many out there without rust above the rear wheel wells. I'll probably have it at tailgating on Saturday Tony so you can check it out then.</p>
]]></description><link>https://fargostreet.com/post/235846</link><guid isPermaLink="true">https://fargostreet.com/post/235846</guid><dc:creator><![CDATA[HandoEX]]></dc:creator><pubDate>Fri, 21 Nov 2008 14:16:38 GMT</pubDate></item><item><title><![CDATA[Reply to Toyota 4Runner O&#x2F;D problem on Thu, 20 Nov 2008 23:00:03 GMT]]></title><description><![CDATA[<p dir="auto">Agreed to above statements...I'm sure thats exactly what it is...</p>
]]></description><link>https://fargostreet.com/post/235784</link><guid isPermaLink="true">https://fargostreet.com/post/235784</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Thu, 20 Nov 2008 23:00:03 GMT</pubDate></item><item><title><![CDATA[Reply to Toyota 4Runner O&#x2F;D problem on Thu, 20 Nov 2008 21:13:42 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">MisterCMK;247290 wrote:<br />
That might not be a problem at all.  I know that our Dodge trannys do the same thing.  They will not shift into overdrive until they are warmed up.</p>
<p dir="auto">yep, no OD or TC lockup till they warm up.... i wont get OD or lockup for atleast 5 miles when it is cold.... longer when colder</p>
<p dir="auto">on earlier dodges like cmk said</p>
]]></description><link>https://fargostreet.com/post/235775</link><guid isPermaLink="true">https://fargostreet.com/post/235775</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Thu, 20 Nov 2008 21:13:42 GMT</pubDate></item><item><title><![CDATA[Reply to Toyota 4Runner O&#x2F;D problem on Thu, 20 Nov 2008 20:28:09 GMT]]></title><description><![CDATA[<p dir="auto">That might not be a problem at all.  I know that our Dodge trannys do the same thing.  They will not shift into overdrive until they are warmed up.</p>
]]></description><link>https://fargostreet.com/post/235769</link><guid isPermaLink="true">https://fargostreet.com/post/235769</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Thu, 20 Nov 2008 20:28:09 GMT</pubDate></item></channel></rss>
