<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Honda abs removal??]]></title><description><![CDATA[<p dir="auto">A friend has a 91 Accord as a winter beater. Its got like 350K on the car and we've been helping it along. Actually still pretty nice for the miles. Well the abs pump assembly has developed a leak, and didn't work in the first place. Remaned unit is $500 and I have been unable to locate a used one. Can I just pull the unit and put t's in the lines from the master cylinder, so it basically does not have abs anymore? Or is there built in porportioning valves and stuff, so it will not work right? Anyone have any ideas?</p>
<p dir="auto">Mike</p>
]]></description><link>https://fargostreet.com/topic/15726/honda-abs-removal</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 14:17:22 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/15726.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Nov 2008 16:33:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Honda abs removal?? on Wed, 03 Dec 2008 20:46:58 GMT]]></title><description><![CDATA[<p dir="auto">accord abs pump $40 shipped<br />
<a href="http://www.hondamarketplace.com/showthread.php?t=2443862" rel="nofollow ugc">http://www.hondamarketplace.com/showthread.php?t=2443862</a></p>
]]></description><link>https://fargostreet.com/post/237245</link><guid isPermaLink="true">https://fargostreet.com/post/237245</guid><dc:creator><![CDATA[g2gs]]></dc:creator><pubDate>Wed, 03 Dec 2008 20:46:58 GMT</pubDate></item><item><title><![CDATA[Reply to Honda abs removal?? on Wed, 26 Nov 2008 19:35:43 GMT]]></title><description><![CDATA[<p dir="auto">theres an accord for sale in the for sale section.  Maybe it has abs.  and its less than a reman unit</p>
]]></description><link>https://fargostreet.com/post/236433</link><guid isPermaLink="true">https://fargostreet.com/post/236433</guid><dc:creator><![CDATA[Rexwagon]]></dc:creator><pubDate>Wed, 26 Nov 2008 19:35:43 GMT</pubDate></item><item><title><![CDATA[Reply to Honda abs removal?? on Wed, 26 Nov 2008 14:18:46 GMT]]></title><description><![CDATA[<p dir="auto">after checking around, I found there isn't much for metric brake line parts. So I can't really make anything to take the abs unit out. So I guess I have to buy a used unit. This that sucks is I cannot find anything locally, gunna have to order one from halfway across the country.</p>
]]></description><link>https://fargostreet.com/post/236350</link><guid isPermaLink="true">https://fargostreet.com/post/236350</guid><dc:creator><![CDATA[wa2fastcamaro]]></dc:creator><pubDate>Wed, 26 Nov 2008 14:18:46 GMT</pubDate></item><item><title><![CDATA[Reply to Honda abs removal?? on Wed, 26 Nov 2008 10:16:57 GMT]]></title><description><![CDATA[<p dir="auto">You shouldn't need a new master cylinder, ABS master cylinder are usually slightly larger so it will be fine.</p>
]]></description><link>https://fargostreet.com/post/236322</link><guid isPermaLink="true">https://fargostreet.com/post/236322</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Wed, 26 Nov 2008 10:16:57 GMT</pubDate></item><item><title><![CDATA[Reply to Honda abs removal?? on Tue, 25 Nov 2008 22:57:15 GMT]]></title><description><![CDATA[<p dir="auto">i think you should be able to just get rid of it...i know during the summer i just pull my abs fuse as the bumpy ride causes it to go off ALL the time <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/236240</link><guid isPermaLink="true">https://fargostreet.com/post/236240</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Tue, 25 Nov 2008 22:57:15 GMT</pubDate></item><item><title><![CDATA[Reply to Honda abs removal?? on Tue, 25 Nov 2008 22:42:19 GMT]]></title><description><![CDATA[<p dir="auto">I had a 91 accord without abs so yeah you can get parts for it no problem.  If anything i would say just pull the lines and get a new master cylinder for a non-abs, but I dont think you would even have to do that.  Dont forget to pull the abs fuse too.</p>
]]></description><link>https://fargostreet.com/post/236236</link><guid isPermaLink="true">https://fargostreet.com/post/236236</guid><dc:creator><![CDATA[00Accord]]></dc:creator><pubDate>Tue, 25 Nov 2008 22:42:19 GMT</pubDate></item><item><title><![CDATA[Reply to Honda abs removal?? on Tue, 25 Nov 2008 16:47:11 GMT]]></title><description><![CDATA[<p dir="auto">Get one off a junk one for cheap/free, otherwise you should be fine to just remove it. Im not positive on accords, but most hondas you can just pull it with no problem.</p>
]]></description><link>https://fargostreet.com/post/236166</link><guid isPermaLink="true">https://fargostreet.com/post/236166</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Tue, 25 Nov 2008 16:47:11 GMT</pubDate></item><item><title><![CDATA[Reply to Honda abs removal?? on Tue, 25 Nov 2008 16:40:27 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://cgi.ebay.com/ebaymotors/HONDA-ACCORD-ABS-PUMP-MOTOR-ASSEMBLY-92-93_W0QQcmdZViewItemQQcategoryZ33560QQihZ019QQitemZ290276677973QQrdZ1QQsspagenameZWDVW" rel="nofollow ugc">http://cgi.ebay.com/ebaymotors/HONDA-ACCORD-ABS-PUMP-MOTOR-ASSEMBLY-92-93_W0QQcmdZViewItemQQcategoryZ33560QQihZ019QQitemZ290276677973QQrdZ1QQsspagenameZWDVW</a></p>
]]></description><link>https://fargostreet.com/post/236163</link><guid isPermaLink="true">https://fargostreet.com/post/236163</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Tue, 25 Nov 2008 16:40:27 GMT</pubDate></item><item><title><![CDATA[Reply to Honda abs removal?? on Tue, 25 Nov 2008 16:35:53 GMT]]></title><description><![CDATA[<p dir="auto">did they offer an accord that didn't have ABS in 91?  If so, you could check to see of the M/C part numbers are the same.  If they are, i think you'll have no problems.</p>
]]></description><link>https://fargostreet.com/post/236161</link><guid isPermaLink="true">https://fargostreet.com/post/236161</guid><dc:creator><![CDATA[thrash]]></dc:creator><pubDate>Tue, 25 Nov 2008 16:35:53 GMT</pubDate></item></channel></rss>
