<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[compressor map]]></title><description><![CDATA[<p dir="auto">ok so im still trying to learn, but i found a TD06 20G for pretty cheap, and im just getting into this whole turbo thing, still trying to learn. and i need some help. so ok here are the numbers im using. at 7000rpms(redline) it would be making 472.8cfms at 20psi, and at 3500rpms it would be of course 236.4cfms at 20 psi. and of course the pressure ratio would be 2.36. and according to the map i would be at 76% effecency at 20psi and 7000rpm. according to the map it would be a little laggy at 3500rpms but, idk. just give me any imput. good or bad. Thanks!</p>
<p dir="auto">oh and here is a link to the compressor map</p>
<p dir="auto"><a href="http://www.lovehorsepower.com/MR2_Docs/compressor_flow_maps.htm" rel="nofollow ugc">http://www.lovehorsepower.com/MR2_Docs/compressor_flow_maps.htm</a></p>
]]></description><link>https://fargostreet.com/topic/15811/compressor-map</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 07:43:35 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/15811.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Dec 2008 11:22:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to compressor map on Tue, 23 Dec 2008 02:33:38 GMT]]></title><description><![CDATA[<p dir="auto">o and zach you were  right. it used to have an internal wastegate. flap is welded. any you can see the mounting holes for it lol</p>
]]></description><link>https://fargostreet.com/post/241423</link><guid isPermaLink="true">https://fargostreet.com/post/241423</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Tue, 23 Dec 2008 02:33:38 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Tue, 23 Dec 2008 00:10:28 GMT]]></title><description><![CDATA[<p dir="auto">lookey at what came in the mail today</p>
<p dir="auto"><img src="http://i173.photobucket.com/albums/w52/hunter200524/001.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/241403</link><guid isPermaLink="true">https://fargostreet.com/post/241403</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Tue, 23 Dec 2008 00:10:28 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Fri, 12 Dec 2008 15:36:36 GMT]]></title><description><![CDATA[<p dir="auto">I have a KLDE out of a probe in the mx-3.  I have to finish putting the headers in to finish up the exhaust.  I have a B6T sitting in my garage, but I don't think I should say what that is for, might get some funny looks.</p>
<p dir="auto">I figured you knew all that stuff about the trannies, but figured I should through it out there just in case.  If you think the G-series tranny is not very strong, you should see what the festiva guys are doing to the E-series tranny (which came stock in the festiva, and is alot weaker).</p>
]]></description><link>https://fargostreet.com/post/239040</link><guid isPermaLink="true">https://fargostreet.com/post/239040</guid><dc:creator><![CDATA[nonamekid]]></dc:creator><pubDate>Fri, 12 Dec 2008 15:36:36 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Fri, 12 Dec 2008 07:36:05 GMT]]></title><description><![CDATA[<p dir="auto">finally got things figured out with paypal and turbo is on its way <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /> next purchase most likely gona be pistons, rods. oh any recomendations on where to take the block to? i was probably just going to go to m&amp;j. any idea on cost for it to get bored out .20 , cleaned, deck checked for trueness, crank balanced, freeze plugs and whatnot. and dont worry i will be using arp main studs.:)</p>
]]></description><link>https://fargostreet.com/post/238728</link><guid isPermaLink="true">https://fargostreet.com/post/238728</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Fri, 12 Dec 2008 07:36:05 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Fri, 12 Dec 2008 00:16:41 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">nonamekid;249979 wrote:<br />
The stock G-series tranny is not that bad.  I know guys putting 250-300 hp through that tranny and not having a problem.  Wheel hop is what will kill you.  If your are concerned about the tranny, get the G-series out of the Kia, it has bigger axles and the tranny is beefier.</p>
<p dir="auto">You would get alot more laughs at your car if you were putting that motor in a festiva.  It would be fairly fast as the BP is double the horsepower of the stock motor.</p>
<p dir="auto">thanks for the info. but i already know this lol. well yes there are guys that dont have problems and there are guys that do. actually the kia axles are smaller they just have a bigger spline count, and the only thing stronger about the tranny is the case. witch is one of the biggest problems with ruined gearboxes. but up here it isnt very easy to find the intermediate shaft for the kia gearbox. and yes im going full poly everything to help with wheel hop. but sweet to know someone else knows about this. and im gettin me an helical lsd from mfactory. like you said the tranny isnt that bad, but at the same time isnt that great. oh ic you have an mx-3, whats it got in it.</p>
]]></description><link>https://fargostreet.com/post/238462</link><guid isPermaLink="true">https://fargostreet.com/post/238462</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Fri, 12 Dec 2008 00:16:41 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Thu, 11 Dec 2008 21:51:45 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Bp-08;249093 wrote:<br />
... but the tranny is made outa glass.</p>
<p dir="auto">The stock G-series tranny is not that bad.  I know guys putting 250-300 hp through that tranny and not having a problem.  Wheel hop is what will kill you.  If your are concerned about the tranny, get the G-series out of the Kia, it has bigger axles and the tranny is beefier.</p>
]]></description><link>https://fargostreet.com/post/238407</link><guid isPermaLink="true">https://fargostreet.com/post/238407</guid><dc:creator><![CDATA[nonamekid]]></dc:creator><pubDate>Thu, 11 Dec 2008 21:51:45 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Thu, 11 Dec 2008 04:56:58 GMT]]></title><description><![CDATA[<p dir="auto">thanks man i cant wait either. i wish i had more money lol. i buy something new for it every two weeks lol. hopefully it will be running this summer.</p>
]]></description><link>https://fargostreet.com/post/238289</link><guid isPermaLink="true">https://fargostreet.com/post/238289</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Thu, 11 Dec 2008 04:56:58 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Thu, 11 Dec 2008 04:49:03 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Bp-08;249850 wrote:<br />
lol jon im kelly this is my im still mad i lost that ford aaa competition that im gona make a fast turd project lol.</p>
<p dir="auto">Yes! i was like that's fucking kelly's old car haha nice to have you on the site man. Can't wait to see what this thing turns out like.</p>
]]></description><link>https://fargostreet.com/post/238286</link><guid isPermaLink="true">https://fargostreet.com/post/238286</guid><dc:creator><![CDATA[Bassplayer]]></dc:creator><pubDate>Thu, 11 Dec 2008 04:49:03 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Thu, 11 Dec 2008 04:16:49 GMT]]></title><description><![CDATA[<p dir="auto">lol jon im kelly this is my im still mad i lost that ford aaa competition that im gona make a fast turd project lol.</p>
]]></description><link>https://fargostreet.com/post/238278</link><guid isPermaLink="true">https://fargostreet.com/post/238278</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Thu, 11 Dec 2008 04:16:49 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Thu, 11 Dec 2008 04:15:54 GMT]]></title><description><![CDATA[<p dir="auto">Sweet build man, my favorite cars in the world are the last ones you'd expect to be fast. When did you graduate from South? X2 on the car looking familiar.</p>
]]></description><link>https://fargostreet.com/post/238276</link><guid isPermaLink="true">https://fargostreet.com/post/238276</guid><dc:creator><![CDATA[Bassplayer]]></dc:creator><pubDate>Thu, 11 Dec 2008 04:15:54 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Thu, 11 Dec 2008 03:57:23 GMT]]></title><description><![CDATA[<p dir="auto">oh yea it will definatly be fun:)<br />
i dont have it yet but here are some pics from the guy im buying it from. i will take my own pics when it gets here. in the thir</p>
<p dir="auto"><img src="http://i173.photobucket.com/albums/w52/hunter200524/Picture060.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i173.photobucket.com/albums/w52/hunter200524/Picture061.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i173.photobucket.com/albums/w52/hunter200524/Picture062.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/238271</link><guid isPermaLink="true">https://fargostreet.com/post/238271</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Thu, 11 Dec 2008 03:57:23 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Thu, 11 Dec 2008 02:58:48 GMT]]></title><description><![CDATA[<p dir="auto">that should do you pretty good.</p>
]]></description><link>https://fargostreet.com/post/238255</link><guid isPermaLink="true">https://fargostreet.com/post/238255</guid><dc:creator><![CDATA[no_slow_clap]]></dc:creator><pubDate>Thu, 11 Dec 2008 02:58:48 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Thu, 11 Dec 2008 02:35:49 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">no_slow_clap;249810 wrote:<br />
yea, it was a fun car. not so good for anything but a straight line. but it was a pig</p>
<p dir="auto">that poped out of gear when it felt necessary. i remember staying on that sti's a$$ when we were doing pulls..and getting the hotside glowing red.</p>
<p dir="auto">i hate paypal, but it works. put up pics when you get the turbo.</p>
<p dir="auto">isnt the td05 a t3?</p>
<p dir="auto">yes its a t3</p>
]]></description><link>https://fargostreet.com/post/238251</link><guid isPermaLink="true">https://fargostreet.com/post/238251</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Thu, 11 Dec 2008 02:35:49 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Thu, 11 Dec 2008 02:10:01 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Bp-08;249630 wrote:<br />
you had a turbo probe?</p>
<p dir="auto">yea, it was a fun car. not so good for anything but a straight line. but it was a pig</p>
<p dir="auto">DrifterExtreme;249644 wrote:<br />
he was the last owner.</p>
<p dir="auto">good old ford ferrari, thing could hang with evo's. not bad for a 3k lb beast. with a manual "4speed"  hahah</p>
<p dir="auto">Bp-08;249805 wrote:<br />
update. paypal was being gay so i wont be getting the turbo for like another week. found out is a tdo5 not a tdo6 oh well still big enough for me, and 200 bucks is still pretty cheap. oh and i noticed i forgot to say its a sbr 20g</p>
]]></description><link>https://fargostreet.com/post/238238</link><guid isPermaLink="true">https://fargostreet.com/post/238238</guid><dc:creator><![CDATA[no_slow_clap]]></dc:creator><pubDate>Thu, 11 Dec 2008 02:10:01 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Thu, 11 Dec 2008 01:58:48 GMT]]></title><description><![CDATA[<p dir="auto">update. paypal was being gay so i wont be getting the turbo for like another week. found out is a tdo5 not a tdo6 oh well still big enough for me, and 200 bucks is still pretty cheap. oh and i noticed i forgot to say its a sbr 20g</p>
]]></description><link>https://fargostreet.com/post/238233</link><guid isPermaLink="true">https://fargostreet.com/post/238233</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Thu, 11 Dec 2008 01:58:48 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Wed, 10 Dec 2008 06:29:27 GMT]]></title><description><![CDATA[<p dir="auto">he was the last owner.</p>
]]></description><link>https://fargostreet.com/post/238072</link><guid isPermaLink="true">https://fargostreet.com/post/238072</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Wed, 10 Dec 2008 06:29:27 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Wed, 10 Dec 2008 05:12:29 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">no_slow_clap;249376 wrote:<br />
i still miss that god damn car.</p>
<p dir="auto">you had a turbo probe?</p>
]]></description><link>https://fargostreet.com/post/238058</link><guid isPermaLink="true">https://fargostreet.com/post/238058</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Wed, 10 Dec 2008 05:12:29 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Tue, 09 Dec 2008 01:07:48 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">DrifterExtreme;249374 wrote:<br />
i had a turbo probe that was "sweet" so i know about cheep turbo cars, the last owner dubed it the ford ferrari for good reason, lol</p>
<p dir="auto">i still miss that god damn car.</p>
]]></description><link>https://fargostreet.com/post/237805</link><guid isPermaLink="true">https://fargostreet.com/post/237805</guid><dc:creator><![CDATA[no_slow_clap]]></dc:creator><pubDate>Tue, 09 Dec 2008 01:07:48 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Tue, 09 Dec 2008 00:49:42 GMT]]></title><description><![CDATA[<blockquote>
yes i cringe at those types of set up's, but then again i was in your shoes before i learned to weld.</p>
<p dir="auto">i had a turbo probe that was "sweet" so i know about cheep turbo cars, the last owner dubed it the ford ferrari for good reason, lol</p>
<p dir="auto">i can weld. just not cast. and im not the greatest. i work at a fab shop and there are a couple guys i know and trust to weld cast but they are just too busy. anyways heres where it gets worse lol, im using a t3 adapter plate somebody made up to bolt onto the maniflold. becasue well you should know its for a vj20, and im going to be using a 20g, and yeaa... lol its horrible i know</p>
]]></description><link>https://fargostreet.com/post/237804</link><guid isPermaLink="true">https://fargostreet.com/post/237804</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Tue, 09 Dec 2008 00:49:42 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Tue, 09 Dec 2008 00:44:17 GMT]]></title><description><![CDATA[<p dir="auto">yes i cringe at those types of set up's, but then again i was in your shoes before i learned to weld.</p>
]]></description><link>https://fargostreet.com/post/237803</link><guid isPermaLink="true">https://fargostreet.com/post/237803</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Tue, 09 Dec 2008 00:44:17 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Tue, 09 Dec 2008 00:34:42 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">DrifterExtreme;249368 wrote:<br />
see i was hoping you knew what you were doing, and would acually give me some feedback to the question i posed on getting the manifold set up to work well.</p>
<p dir="auto">if you didn't know i make manifolds for a living, so this stuff interests me.</p>
<p dir="auto">oh really? well i might have to talk to you when the time comes for an actual manifold. you dont even want to know how ghetto rigged this manifold is going to be. you will probably laugh. its actually probably the wost set up i could have on my car being the gtx manifold is crap. definatly not efficent at all lol. just cheap <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/237802</link><guid isPermaLink="true">https://fargostreet.com/post/237802</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Tue, 09 Dec 2008 00:34:42 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Tue, 09 Dec 2008 00:19:58 GMT]]></title><description><![CDATA[<p dir="auto">see i was hoping you knew what you were doing, and would acually give me some feedback to the question i posed on getting the manifold set up to work well.</p>
]]></description><link>https://fargostreet.com/post/237797</link><guid isPermaLink="true">https://fargostreet.com/post/237797</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Tue, 09 Dec 2008 00:19:58 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Tue, 09 Dec 2008 00:10:26 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">DrifterExtreme;249364 wrote:<br />
being fine, and working effeiciently are two totally different things.</p>
<p dir="auto">but then again you would know that.</p>
<p dir="auto">what? im not made out of money man. im working with what i got. it may not be the most "efficent" but it will work for now. im not goin for no super car here. just something for fun.</p>
]]></description><link>https://fargostreet.com/post/237795</link><guid isPermaLink="true">https://fargostreet.com/post/237795</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Tue, 09 Dec 2008 00:10:26 GMT</pubDate></item><item><title><![CDATA[Reply to compressor map on Mon, 08 Dec 2008 23:53:32 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Bp-08;249293 wrote:<br />
it should be fine, and your right there is a guy that is using a 20 year old cast manifold and running 12's weekly during racing season. so im not really worried.</p>
<p dir="auto">being fine, and working effeiciently are two totally different things.</p>
]]></description><link>https://fargostreet.com/post/237793</link><guid isPermaLink="true">https://fargostreet.com/post/237793</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Mon, 08 Dec 2008 23:53:32 GMT</pubDate></item></channel></rss>
