<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[D16A1 engine problem]]></title><description><![CDATA[<p dir="auto">I'm posting this on behalf of a buddy from <a href="http://Probetalk.com" rel="nofollow ugc">Probetalk.com</a> with a 1st-gen Integra. It has the D16A1 engine and it won't idle and it backfires through the intake. It's throwing codes for the TDC and crank angle sensors, but both of the sensors have been replaced. The MAP sensor, distributor, and fuel filter have been replaced, all electrical connections, ground wires, and fuses were checked. There is fuel and spark and the timing is good. Is there anyone here who knows this engine and/or can give some suggestions to get this car running? Thanks.</p>
]]></description><link>https://fargostreet.com/topic/1603/d16a1-engine-problem</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 01:18:56 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/1603.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Feb 2005 06:52:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to D16A1 engine problem on Thu, 10 Feb 2005 14:10:24 GMT]]></title><description><![CDATA[<blockquote>
<strong>Wrong</strong>, there is next to no information on 1g integra's on H-T.  I own one and there's not much information about them or many active owners on any boards.</p>
<p dir="auto"><a href="http://www.g1teg.org/phpbb/index.php" rel="nofollow ugc">http://www.g1teg.org/phpbb/index.php</a><br />
Is the best resource I have found for 1g questions.</p>
<p dir="auto">Bottom line is the d16a1 was not specific to the 1g Integra.  On top of that this question is not even specific to the motor.  It's a general, help my car doesn't sound good kinda question.  One doesn't need to be an expert on the d16a1 or even hondas to be able to help troubleshoot.  However, honda-tech does have a lot of knowledgable enthusiasts who can probably help you out.</p>
<p dir="auto">Well if he doesn't want to compression test the car because of how it sounds he may as well start taking stuff apart.  Take off the valve cover, and check out the head, or have a machine shop inspect it.  Like Wes said, I would make the valves one of the first things I would check.</p>
]]></description><link>https://fargostreet.com/post/29322</link><guid isPermaLink="true">https://fargostreet.com/post/29322</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Thu, 10 Feb 2005 14:10:24 GMT</pubDate></item><item><title><![CDATA[Reply to D16A1 engine problem on Thu, 10 Feb 2005 05:36:23 GMT]]></title><description><![CDATA[<p dir="auto">Well if it is indeed backfiring, then I suspect a bent valve if not a timing issue. try to do a compression test. If possible, do a leakdown test. That will tell you if theres something amiss on the bottom end.</p>
]]></description><link>https://fargostreet.com/post/29273</link><guid isPermaLink="true">https://fargostreet.com/post/29273</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Thu, 10 Feb 2005 05:36:23 GMT</pubDate></item><item><title><![CDATA[Reply to D16A1 engine problem on Thu, 10 Feb 2005 05:02:29 GMT]]></title><description><![CDATA[<p dir="auto">Just to clarify, he's sure the timing is not the problem. He understands the difference between cam timing and distributor base timing. We got to talking about compression testing and he told me he'd hate to even try cranking it over because it sounds bad. That made me wonder if something in the bottom end is bent or broken.</p>
]]></description><link>https://fargostreet.com/post/29254</link><guid isPermaLink="true">https://fargostreet.com/post/29254</guid><dc:creator><![CDATA[pin]]></dc:creator><pubDate>Thu, 10 Feb 2005 05:02:29 GMT</pubDate></item><item><title><![CDATA[Reply to D16A1 engine problem on Thu, 10 Feb 2005 03:43:59 GMT]]></title><description><![CDATA[<p dir="auto">Setting base timing is still just adjusting the distributor. It really has nothing to do with the cam timing. You can have the distributor on tdc for the can that the distributor rides on but that still leaves the other cam that could be off. I wold just be sure of even the most easily overlooked things.</p>
]]></description><link>https://fargostreet.com/post/29223</link><guid isPermaLink="true">https://fargostreet.com/post/29223</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Thu, 10 Feb 2005 03:43:59 GMT</pubDate></item><item><title><![CDATA[Reply to D16A1 engine problem on Thu, 10 Feb 2005 00:38:44 GMT]]></title><description><![CDATA[<p dir="auto">My buddy told me he has set the base timing at the belt many times in the past week. He's sure it's not a timing problem.</p>
]]></description><link>https://fargostreet.com/post/29193</link><guid isPermaLink="true">https://fargostreet.com/post/29193</guid><dc:creator><![CDATA[pin]]></dc:creator><pubDate>Thu, 10 Feb 2005 00:38:44 GMT</pubDate></item><item><title><![CDATA[Reply to D16A1 engine problem on Wed, 09 Feb 2005 22:12:40 GMT]]></title><description><![CDATA[<blockquote>
Maybe not for integras...but there is tons of information on the D-series platform.</p>
<p dir="auto">I laughed when I read the title "D16a1" and "problem" in the same sentence...thats an oxymoron.<br />
This is very true about d-series engines, but not so much for the d16a1.  Its the red headed step child of the d-series.</p>
<p dir="auto"><a href="www.D-series.org">www.D-series.org</a> Also has some information.</p>
]]></description><link>https://fargostreet.com/post/29174</link><guid isPermaLink="true">https://fargostreet.com/post/29174</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Wed, 09 Feb 2005 22:12:40 GMT</pubDate></item><item><title><![CDATA[Reply to D16A1 engine problem on Wed, 09 Feb 2005 22:00:13 GMT]]></title><description><![CDATA[<p dir="auto">Maybe not for integras...but there is tons of information on the D-series platform.</p>
<p dir="auto">I laughed when I read the title "D16a1" and "problem" in the same sentence...thats an oxymoron.</p>
]]></description><link>https://fargostreet.com/post/29172</link><guid isPermaLink="true">https://fargostreet.com/post/29172</guid><dc:creator><![CDATA[seanjohn]]></dc:creator><pubDate>Wed, 09 Feb 2005 22:00:13 GMT</pubDate></item><item><title><![CDATA[Reply to D16A1 engine problem on Wed, 09 Feb 2005 21:35:00 GMT]]></title><description><![CDATA[<blockquote>
also if you haven't already, try posting on <a href="www.honda-tech.com">www.honda-tech.com</a>.  There's alot of knowledge and resources on that board.<br />
]]></description><link>https://fargostreet.com/post/29156</link><guid isPermaLink="true">https://fargostreet.com/post/29156</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Wed, 09 Feb 2005 21:35:00 GMT</pubDate></item><item><title><![CDATA[Reply to D16A1 engine problem on Wed, 09 Feb 2005 15:15:17 GMT]]></title><description><![CDATA[<p dir="auto">I agree with what Wes says...</p>
<p dir="auto">also if you haven't already, try posting on <a href="www.honda-tech.com">www.honda-tech.com</a>.  There's alot of knowledge and resources on that board.</p>
]]></description><link>https://fargostreet.com/post/29120</link><guid isPermaLink="true">https://fargostreet.com/post/29120</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Wed, 09 Feb 2005 15:15:17 GMT</pubDate></item><item><title><![CDATA[Reply to D16A1 engine problem on Wed, 09 Feb 2005 08:36:25 GMT]]></title><description><![CDATA[<p dir="auto">I will relay your question to the owner and post a reply later. Thanks.</p>
]]></description><link>https://fargostreet.com/post/29108</link><guid isPermaLink="true">https://fargostreet.com/post/29108</guid><dc:creator><![CDATA[pin]]></dc:creator><pubDate>Wed, 09 Feb 2005 08:36:25 GMT</pubDate></item><item><title><![CDATA[Reply to D16A1 engine problem on Wed, 09 Feb 2005 06:56:47 GMT]]></title><description><![CDATA[<p dir="auto">When you say timing is good, is that just ditributor timing or did you check the belt? It sounds like your belt jumped a cog or two.</p>
]]></description><link>https://fargostreet.com/post/29107</link><guid isPermaLink="true">https://fargostreet.com/post/29107</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Wed, 09 Feb 2005 06:56:47 GMT</pubDate></item></channel></rss>
